Question about Garden
My Little Giant OPWG-71 after six months of trouble free use has stopped pumping my pond. It comes on, with no obstructions allows water to be pushed through it but won't pump. And yes even when
  • 7,482 Answers
Hi don-eyre300.
Double check your suction side of the pump for obstructions if not then it is time to replace your pump...sounds like the impeller and housing is worn beyond repair.
Bud
Posted on Apr 29, 2013
dragonsthatk
  • 547 Answers
SOURCE: pw5500 Calpump not working
replace the breaker with a higher amp breaker . Thank you for useing fixya please take the time to rate me
Posted on Feb 12, 2009
clyde2j2
  • 137 Answers
SOURCE: How do I prime my outside of the pond waterfall pump?
I would take the intake hose off the pump and fill it with water and with the pump running I would hokk upthe intake hose.
I also would if possible have the pump lower than the pond.
Posted on Mar 28, 2009
SOURCE: savio waterfall pump not pumping strong enough
This might be like the problem I experienced ... the 3600 gph SAVIO pump I have needs to be primed to get rid of the air in the pipe.
Posted on Jun 10, 2009
  • 990 Answers
SOURCE: need to add oil to a little giant pond pump
If you have to add oil it is time to replace pump.
Posted on Aug 25, 2009
  • 10 Answers
SOURCE: My waterfall pond pumps keep burning out. The
I found that little giant pump are oiled filled and if it gets hot it frys itself... As for submersible pumps Magnetic drive Beckett Pumps are nice. My Beckett pump has been going for 4 years now it pumps 4800ghp. the cost $269 last I looked.
Posted on Oct 16, 2009
How to disassemble Little giant pump model#psm006?
thats why i like the little giant pumps they are put together with phillips screws not glued like them other guys , i do suggest that if you dissasemble pump and water has gotten inside , replace it not just seal it up and go , wont last long as that means the pump shaft seal has leaked , ther e has been a few folks that add dietary mineral oil to the inside , for use in very deep ponds (over 3 feet) they believe that helps keep the water out
Jun 11, 2014 | Little Giant Submersible Fountain Pump
My pump is running but not sucking up water
well if possible look into suction screen and see if Impeler is turning , I'll bet not , most of the lil giants come with a easy to remove pump cover (screw) so one can access the pump cavity to remove forign debris , also one can manually rotate impeller with finger (unplugged) to ck for free movement , if its hard to move your pump needs replacement
May 10, 2014 | Little Giant Submersible Fountain Pump
Littlle giant pump model 2e-ndvr what oil goes inside this pump
"pump oil" usually is a fire redardant mineral type , ive seen good uses of dietary mineral oil avail at local phamacy , but is sort of pricey if filling a total pump up with it (allways allow for heat expansion)
Apr 01, 2013 | Little Giant 5-MSP Water Wizard...
Little gaint 3e 34 n pump has started cycling off for 1 to 2 minutes the back on. this happens once every 2 or 3 days.
this sounds as if the thermal switch is being activated , this ocurrs when an obstruction has entered pump , by design the pumping media (water?) is the cooling for the pump , low to no flow no cooling !!
Aug 19, 2012 | Little Giant 3e 34n, 1/15 Hp, 670 Gph Dual...
My little giant just stopped working, impeller turns ok by hand, no blockage, 110v to outlet ok. Always under water, never ran dry... Walter
inside the pump on the motor is a thermal cut out if the motor has over heater from running a long time the cut out pops and it may not pop back in again? its that or there is a motor fault like brushes worn out
Aug 28, 2010 | Little Giant 5-MSP Water Wizard...
Oct 14, 2009 | Little Giant Submersible Fountain Pump
PUMP RUNS BUT DOES NOT **** UP WATER
I have experienced this same problem and all I needed was to prime the pump. Unless your pump cannot pump up that high.
Jan 09, 2009 | Little Giant Opwg 71 71 Gpm Out of Pond...
Pond pump types
There are basically two types of pond pumps to choose from - externally mounted and submersible. External pumps were traditionally used in water gardens. They sit outside the pond, with a hose that leads from a strainer in the pond to the pump. From there the water is forced either to a waterfall, stream or fountain. Because external pond pumps are often noisy and require extra plumbing, they are usually not suited for most backyard ponds. Due to easier accessibility and ease of repair, however, external water pumps are often the best choice for larger water gardens and public installations. Submersible water pumps are usually preferred by most do-it-yourselfers. They sit underwater where they are quiet and unseen. These pumps are easy to install, require no priming and stay cool thanks to the surrounding water. Submersible pumps draw water from the bottom of the pond, either through a strainer or biological filter. A hose attached to the outlet then feeds water to whichever water feature you have installed.
Aug 27, 2008 | Little Giant Opwg 71 71 Gpm Out of Pond...
Garden Logo
402 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
