Question about Uniden Cordless Phone
Uniden phone - replaced battery & plugged and unplugged everything on all three phones - still says "searching"
Uniden Cordless Phone - replaced battery & plugged and unplugged everything on all 3 phones - still says "searching". What else can I try?
    New Friend:
No dial tone
Posted on Jun 19, 2013
JannEd
SOURCE: 2 uniden cordless phones aren't working
I don't know if this helps, but perhaps the problem is using two or more phones. On a whim, I charged a Uniden EXP 970 that my daughter gave me a few years ago. Charged right up and it has been working for about two days. I didn't think it would charge at all but to have it actually work, I was amazed!! Will post if it quits anytime soon.
FYI I bought two phones from AT&T, each around $200 and neither of them worked after a week. I was not happy! These less expensive phones seem to do a much better job!
Jann
Posted on Mar 06, 2008
  • 218 Answers
SOURCE: Need an owner's manual for Uniden EZ1996 Cordless Phone
Here it is.
http://www.uniden.com/pdf/EZI996om.pdf
Posted on Dec 28, 2008
SOURCE: Hi my uniden cordless phone
You have to go to menu on your head set and on the phone that is hooked up to the wall and go to menu on it then go to register base on both phones and hit that and then it will register your hand set. That should fix your problem.
Posted on Aug 08, 2010
  • 268 Answers
SOURCE: retrieve deleted messages from uniden cordless phone
After its deleted then its deleted forever. These are not like the old answering machines that all you did was pull the plug and plugged it back into the wall outlet to retrieve old messages was were deleted. When digital you can not do that....Sorry
Posted on Sep 18, 2010
amenchoid
SOURCE: our 5.8gh uniden phones all have static one land phone 3 extension.
disconnect the ac adapter from the base - before you plug the phone back in with power - press and hold down the menu button (center silver button under the led display) and the number "1" and then plug it back in - keep holding those two buttons until the date and time reappears - it worked for me and it didnt erase the phone numbers stored in the base unit.
Posted on Sep 26, 2011
My handset is display only searching, I cannot make or recieve calls & it is just flashing 88
when I press talk I get connectin9..handset out of range..searcgin9
when I press end I get Searching
Jan 30, 2013 | Uniden DECT 6.0 Cordless Phone
Handset says searching
Searching means its searching for a signal. If the phone cant contact the base it will say searching. Make sure the handset is in range of the base and the base is connected to the power.
May 16, 2012 | Uniden DECT 6.0 Cordless Phone ID
Hi I have a Cordless Uniden Dect 6.0 and also another one that sitts on a bitter base. My problem is this: the cordless with the smaller base shows the message 'Searching' and wont do anything,...
Welcome to FixYa.
Reset the units/set up by doing the following:
  • Turn OFF all the HANDSETS.
  • Remove the batteries of the HANDSETS.
  • Unplug the power source of the BASE.
  • Unplug the phone line of the BASE.
  • Let it stay that way for 30 mins.
  • Insert the battery again of the HANDSETS, make sure it is charged properly.
  • Plug back the power source of the BASE.
  • Plug back the phone line to the BASE.
  • Register any handset that is unregistered (refer to manual).
Keep me posted.
Jas247
Sep 11, 2011 | Uniden D1680 Cordless Phone
How do i recharge my uniden phone battery
Phone's "Status Light" Not Illuminating or Battery Failing to Charge
  • 1.Check that the base unit's AC adapter is plugged into the both the base unit and electrical outlet firmly.
  • 2.Wipe the base unit's handset holder's connectors and the connectors on the bottom of the handset with a soft cloth/rag or pencil eraser to remove any loose dust and dirt from the metal connectors.
  • 3.Place the handset firmly in the base unit holder until the "Status Light" illuminates, indicating the battery is charging.
    4.Replace your Uniden cordless phone's battery, by purchasing a compatible battery from an electronic supply store or directly from Uniden. Turn your phone's handset unit over and remove its battery door. Lift the phone's battery pack up and gently unplug the battery's wire connector by pressing in on the connector's side and pulling the connector free from the phone's circuit board. Battery installation is the reverse of removal.
    Read more: Troubleshooting a Uniden Cordless Phone ' eHow.com http://www.ehow.com/how_7252483_troubleshooting-uniden-cordless-phone.html#ixzz1Wkmk0pxX
    Sep 02, 2011 | Uniden Cordless Phone
    It is buzzing and it won't turn on or off if you unplug the battery and plug it back in it still buzzes and the screen light is on all the time. you put it on the base it does the same thing. is there a...
    just a suggestion... unplug everything, phone an power on base and remote. Remove batteries. Wait 5 minutes reinstall batteries, and plug everything back in so that the base has to search for the remote or the remote has to search for the base. After all you have tried and after this if you still have a problem, I would assume that the phone is not longer working correctly.
    Sep 22, 2010 | Uniden Cordless Phone
    Often one of the three phones will display searching and I cannot use any of my phones in the house.
    Try to take out the batteries of all the phones. Unplug the phone base for 1 minute. Plug all the batteries back in to the phones. plug the power back in to the phone base. That should reset your phone set up thus eliminating the problem.
    Mar 13, 2010 | Uniden DECT 6.0 Cordless Telephone...
    GE 5.8 ghz cordless phone
    Get another telephone and connect the telephone cord from your cordless phone to it. If it works, then you know the problem is with your GE cordless phone. If it doesn't, try replacing the telephone cord. If still no good, call your telephone company.
    Nov 05, 2007 | Uniden Cordless Phone
    I always tell people NOT to buy new batteries to try and fix their cordless phone. It seems to rarely solve the problem and you are usually better off just spending the money on a new phone. Unfortunately 5 years is a long time for cordless phones these days. There are so many brands, and so many thousands of models, it's impossible to keep track of them all.
    Jul 04, 2007 | Uniden Cordless Phone
    Uniden Cordless Phone Logo
    136 people viewed this question
    Top Uniden Lands Phones Experts
    Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
