I have a sony ps-lx150h automated turntable, with a stylus and an amplifier model ta- fe230. I have plugged the turntable into the amp using the red and white cables into the 'phono' section b
Turntable refusing to spin
  • 42 Answers
SOURCE: sony ps-lx2 turntable clicks when spinning
It seems something may have come loose over time or history, but you will have to delve inside to see what it is. It sounds as though the fault should be obvious.
If you do not want to do this, a repair shop should have no problem. I assume that the deck is working ok otherwise.
Posted on Jan 25, 2009
  • 42 Answers
SOURCE: Just set up new turntable AT-PL50. Sound very distorted
Your query incomplete. Please resumit.
  • 88 Answers
SOURCE: Turntable wont spin
If everything seems ok with the power , there is usally a small microswitch that sends power to the motor when the tone arm is moved to the start of the record.
The switch might be bad or the lever that actuates it (connected to the tone arm) might be sticking. You may have to take the bottom cover off or remove the platter to see it.
Also make sure the belt is looped over the motor shaft. If the motor runs but the belt still doesnt turn, belt might be bad.
Posted on Mar 13, 2009
funkyparrot
  • 5 Answers
SOURCE: i hooked up my new stanton t-60 turntable to an
Are you using the phono input on the Sony? If so, you're getting too much gain, you've already got a phono pre amp in the Behringer. Try using the tape or C.D. input. That should solve it.
Posted on Jan 17, 2010
SOURCE: Just received our Sony PS-LX300USB
Hold the stylus at an angle, rear up/needle down. Put the rear of the stylus in first and then push the front of the stylus up and clip into place.
Which stylus number did you use?
D.
Posted on Dec 04, 2010
Can I use a turntable with this system?
If the Aux is Audio in then I don't see why not. The turntable would have to go via a magnetic cartridge pre-amp though. Or the sound would be too low to really hear.
Apr 30, 2015 | Bose Built-invisible Ta-1 Theater...
Power supply Sony PS-LX10
Connect the RCA phono plug wires usually red and white wires with plugs to a receiver or amplifier in the back of it to phono in. New receivers will not work unless you have a phono preamp. Best to buy a vintage stereo receiver or amplifier with the correct connections. Make sure you connect the ground wire which is usually a small black wire coming from the turntable to an receiver or amplifier. Turn the stereo receiver on phono. Connect it to any screw attached to metal on back or look for a ground screw. If you do not attach it it will hum.
http://www.hardwaresecrets.com/imageview.php?image=357
Apr 18, 2014 | Audio Players & Recorders
My turntable is hooked but it wont work.
Bog standard TT connected to a bog standard receiver. Hmmm.
I cannot figure out where you have the equalizer placed (or why, but that is another topic).
What exactly is beeping?
Jan 24, 2013 | Sony PS-LX250H Turntable
Need a new stylus for my turntable SONY PS-LX250H and cannot seemed to find a new one. where can I get a new one at.
Assuming it is the original ATN-3600 cartridge, a simple web search for "sony ps-lx250h replacement stylus" or "atn3600 stylus" locates some.
If the cartridge is something different you should search for that model's stylus, not one for the TT itself.
Sep 03, 2011 | Sony PS-LX250H Turntable
I have vestax 05pro2. Left channel works but out of one speaker. The turntable input is good. Im thinking Its either the channel fader, or the rca inputs for that side. Has anyone had this problem?
Here's a solution to see if you have a problem with either your receiver or turntable.
The turntable has 2 RCA's one red for right channel, and one white or black for left channel, which plug into the back of the amplifier.
  • Unplug both RCA from rear of amplifier.
  • Plug in a cd or dvd player into those inputs on the amplifier, the sound will be lower but it will give you an indication if the amplifier is ok or not.
  • If you have sound on both channels left and right then the amplifier is good
  • If you still only have sound on left channel, then there is a problem with the right channel input on the amp.
  • If your amp, is good, unplug the cd /dvd player.
  • Put a record on and start playing the record
  • Plug the white or black RCA from the turntable into the rear of the amplifier marked left, you should have sound.
  • now unplug it from the left and plug in into the right red RCA socket, if you have sound the amplifier is working fine.
  • if there is no sound there may be a problem with the stylus cartridge on the turntable
  • now lets reverse the test
  • unplug both RCA from amp.
  • Plug the red RCA into the left socket on amplifier, if there is sound, turntable is working fine, if no sound there is a problem with either the stylus cartridge or that red RCA cable.
  • now unplug the red RCA from the left side and plug it into the right side socket
  • if there is no sound there may be a problem with the stylus cartridge or RCA cable.
I hope this helps
MobileJB
Jul 15, 2011 | Audio Players & Recorders
Just received our Sony PS-LX300USB turntable, but cannot get the stylus to stay on. Any suggestions on how to install the stylus?
D.
Nov 09, 2010 | Sony PS-LX300USB Turntable
Sony PS-LX300USB Turntable, one channel not working
Have you tried swopping over the output leads from the turntable to the amp (normally one red and one white phono plug) so they are in each others socket? If you do this and you still get no sound from the right channel it is almost certain to be a faulty amp,or speaker.
If you swop and get no sound from the LEFT channel it is could be either a faulty lead or cartridge.
Apr 19, 2009 | Sony PS-LX250H Turntable
Needle replacement...missing part?
To replace the stylus (N-6516 from your Sony dealer)
1.Turn off the amplifier
2. Protect the stylus with the stylus cover (it flips down 90 degrees)
3. Grasp the stylus holder (exposed when cover was flipped down) and pull it away from the cartridge body
4. Insert the stylus by pushing it in to the cartridge receptacle. Flip the stylus protector up.
Nov 24, 2008 | Sony PS-LX250H Turntable
136 people viewed this question
 Grubhead
Grubhead
