Question about Husqvarna 42" Primary Deck Drive Belt Cz4217 ()
How do I replace the Primary (clutch to deck) blade drive belt on a craftsman LT100 - 21 HP 42" tractor
I have an old Craftsman 42" riding lawn mower LT100 - 21 HP Model 917.273522 Serial 030604C001076 The primary belt to engage the blade broke. I have a new one. How do I replace with the new one?
3 Suggested Answers
lester482529
  • 226 Answers
SOURCE: Knocking in mower deck or belt clutch when engaging blades, motor bogs / slows down
YOU MAY HAVE A BENT BLADE OR EXESSEIVE BUILD UP UNDER THE DECK
Posted on Jun 01, 2009
  • 767 Answers
SOURCE: We have a JD riding lawn mower, model G110,
Hello my name is Heath it will be my pleasure to assist you. If the pto will not engage first check the fuse for the pto if the fuse is good then check the bolts in the pto they are notorious for coming loose and causing problems. If the bolts are tight and the fuse is not blown then you may have a bad pto but if there is no power to the pto then its probably the fuse.
Posted on Sep 07, 2011
Need diagram installation. A drive belt.
If you have a Craftsman, under the seat is the model number. Go Here to get the operators manual. The manual will have all the belt diagrams. Water Filters Lawn Garden Appliance Parts
Oct 14, 2014 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
What would cause a heavy vibration on my craftman riding mower, not caused from the deck, but by the v-drive belt for the tractor. i replaced it and without even putting the mower deck back on the vi
You did not finish the statement about without the blades but if your saying what I thing you are...Ah Oh Sounds like you may have a bent crank..Did you hit something with the blades...take the belt off and start the motor..and Check for wobble of the V drive there should be NONE if it does it could be bent itself or the crank...good luck
Jun 16, 2014 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Ariens 19.5 hp drive belt slip
Question how old is the mower? Drive belt may need to be replaced due to being streched . Also is the clutch fully engaging , are there any worn pulleys?
Nov 10, 2013 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
I was mowing grass with my 21 hp 42 in electris start and my blades stop working
check for belt coming off blade drive......check the power to blade engage switch...... check electric clutch on front of motor
Sep 10, 2013 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Mower deck drive belt keeps breaking
I HAVE A CRAFTSMAN 18 H.P. 3 BLADE 46" MOWER DECK.
1. THE PLASTIC PULLEY COVERS ON BOTH SIDES OF MOWER...WILL TRAP STICKS AND DEBRIS WHICH VERY RAPIDLY WEARS THOSE BELTS..I REMOVED MINE
IF IT IS RUBBING:
1. EITHER THE BELT HAS STRETCHED-REPLACE
2.THE SPRING MOUNT (WELDED TO DECK) GOT BENT...STRAIGHTEN
Jul 21, 2013 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
HEAVY VIBRATION OF MOWER DECK (CRAFTSMAN17.5 HORSE TRACTOR?)
Even new blades can be out of balance, but my guess would be either the other blade spindle, or the tensioner pulley bearing.
Apr 05, 2012 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
I have a Craftsman 18hp Kohler engine. What is
there is no clutch drive belt needs replacing cost of drive belt $20.00
Sep 02, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman 42 inch deck won't run
Check proper belt routing. These models are a little tricky. Also check tensioner spring.
May 17, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Replace drive belt Craftsman 917-255572
First you have to remove the deck,then you may have to remove belt guards to install new one,then reinstall the deck
May 04, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Husqvarna 42" Primary Deck Drive Belt Cz4217 () Logo
49 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
