VIBRATION DURING SPIN CYCLE
ATF8000FE FRIGIDAIRE FRONT LOADER. VIBRATION OR WOBBLE DURING SPIN CYCLE. WORKED FINE AT FIRST THEN STARTED AND GETTING WORSE. WE'VE HAD 2 SERVICE CALLS ON IT AND STILL NO SOLUTION. HELP PLEASE! WE HAVE LEVED IT MOVED IT AND LEVED IT SOME MORE, IT AIN'T GETTING ANY MORE LEVEL.
  • 6,784 Answers
I would check the drum screws for tight fit. they might be a bit lose.
Posted on Mar 11, 2009
What causes my frigidaire top load washer to vibrate and make rattling noise during spin cycle
There are springs and bumpers/shocks in the machine that hold the tub. When they break or come loose, the tub wobbles.
Jan 03, 2016 | Frigidaire FAHE4044MW Affinity High...
My frigidaire fron loader will not spin during wash cycle but will spin when placed on spin
If the drain pump is working correctly and you can get it to spin manually, then the board is faulty. Had the exact same problem with an Lg front loader 40 min. ago.(have to replace the board.)
Jun 14, 2010 | Frigidaire Affinity ATF7000E Front Load...
An extreme vibration in spin cycle. It makes the
Because front load washers are VERY HEAVY, they shake if you have a wooden floor. If your front loader sits on concrete and it still shakes, then you have to make sure all is balanced. If it still shakes, then inside the system there are shock absorbers that need to be checked.
Nov 12, 2009 | Frigidaire Affinity ATF7000ES Front Load...
Vibrates during spin cycle
front loaders are made to sit on concrete they probably didnt tell you when you purchased it if its on wood floor not much you can do
Jul 05, 2009 | Kenmore 3.8 cu. ft. HE4t Front Load Washer
During spin cycle washer spins fine but toward the end of the cycle it spins out of control like it is out of balance? Any help is greatly welcomed.
Some front loaders have a super high speed at the end of the spin. Front loaders don't like small loads, the laundry does not spread out evenly enough for a balanced spin.
May 08, 2009 | Frigidaire ATF6000ES Front Load Washer
Vibration during spin cycle
Unless your front loader is set firmly on concrete and leveled to perfection, the force of a heavy wash load spinning in excess of 1000rpm will create a bit of vibration and noise.A firm footing is your best defense against to much movement.
Also due to the earlier movements during the spin cycle, the shocks that are used to dampen the spin cycle might have been broken or damaged.
If the problem persists inspite of proper levelling, please do check for the shocks or might have them replaced them for good.
Dec 13, 2008 | LG WM2688HWM TROMM SteamWasher
My washing machine will not spin, it will wash and then make a buzzing sound during the spin cycle
Dec 12, 2008 | Frigidaire Affinity ATF7000E Front Load...
Brand new front load kenmore wobbles and moves across floor
Dec 09, 2008 | Kenmore 24032\24036 Top Load Washer
Whirlpool LHW0050PQ Front Loading Washer VERY NOISY during spin cycle
remove the top access panel 3 screws in top rear.
now look around and push on the drum from top
it has suspension shocks and springs like your car they should resist any movements.
look/wiggle the concrete balance blocks , no cracks or loose.
inside the tub are the arm solid /not loose.
run it with the top open what do you see/hear and where
look under the rubber flap in front did anything get under the tub
Dec 29, 2007 | Whirlpool LHW0050PQ Front Load Washer
Washing Machines Logo
215 people viewed this question
Top Washing Machines Experts
