Question about HP PSC 1210 All-In-One InkJet Printer
Color intensity= poor
Psc1210---
prints black just fine
but trying to print color anything comes out very faded [low saturation]
the colors ARE correct and evenly 'faded'
color amounts look ok...any ideas
  • 523 Answers
Shake the cartridges well, it seems that they become dry, try to replace them and check again, go to driver there is setting makes u clean and test the nozzels which makes the color more rich and at the same time it check the state of the cartridges.
Best Regards
Posted on Mar 11, 2009
Does an old PHD cause faded colors?
the PHD transfers the image to the printed page and when it starts to go bad the images can become dull or faded and even blurry or totally missing. Id recommend the PHD be replaced and it should resolve your issues.
Feb 24, 2012 | Dell 2135cn All-In-One Laser Printer
Black print is faded on my HP deskjet 6980 printer. Whenever I print a word document it will have sporadic fading. It will be fine in one place then all faded in another. I've cleaned the cartridges and...
Here are some steps you can check to resolve your issue.
Check if the ink cartridges are low, specially the color black since if the black is empty, you are using the colored cartridges to print black. If the cartridges are newly replaced check the cartridges by reseating it. Try to consider changing the print quality high but doing so will use more ink. If still the same try to clean your printer heads.
Here are the instruction for cleaning your printer.
Open the printer tool box. (open a word, then click on file then print, choose properties, then services)
click on clean the print cartridges, then clean. Do test printing as well to check if the color is correct. If still the same calibrate the color which can be found in the same menu.
For more information here is the link for step by step instruction with visuals.
Hope this will help you resolve the problem.
Thank you for choosing fixya
Mar 03, 2011 | HP Deskjet 6980 InkJet Photo Printer
HELP- Hi my CLX-2160 prints a fine clean textpage - copy function in B/W is also ok - print sharp, well formed,characters - BUT COLOR COPIES ARE PRINTED TOO DARK - printing color from photoshop or other...
there is small preset in LSU pcb (laser scanning unit) exist at lower side of printer for laser intensity
try to adjust that preset slightly low level (anti clockwise)& check the result both color & b/w
Feb 10, 2011 | Samsung CLX2160 Multifunction Color Laser...
My HP 3550 won't print black when it is out of a color.
restore the properties.... set as "print in grey scale" or "print color as b/w images"...
also if the print become less or more dark you can change the settings to print whit more intensity or less...
there is no necesary change all your documents as "watter ink" only change the print options to fade to black
May 15, 2010 | HP Color Laserjet 3550 Printer
Printer doesn't print well
Hav you replaced with original cartridges or 3rd party/refilled ones? This is a common problem when using generic/refilled cartridges. Let me know that first..
When you say poor quality, do you mean faded printouts, or broken print? Kindly explain in detail, so I can assist you further.
Nov 07, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
Hp psc1210 will not print black but will print gray
Gray print does not use black ink. It only uses the color cartridge. I assume you already changed the black cartridge. Make sure it is the right one for your printer and it is not a generic refill. The generic might be OK but I wouldn"t trust it complety. Make sure your cartridge is properly seated in the holder.
Aug 17, 2008 | HP PSC 1210 All-In-One InkJet Printer
HP psc1210 not printing in Black
u better try this ,remove color catridge from the printer,switchoff n switch it again with black catridge only,the printer will give catridge error dont worry ,n try to print any black font document from the printer n see does it print black,n reply
thnx
Jan 28, 2008 | HP PSC 1210 All-In-One InkJet Printer
Computer doesn't print color
Hi, the problem seems with the logic board inside the printer, are you in a position to open the printer and try some stunts, that is only if you have done it earlier.. let me know??
Dec 17, 2007 | HP PSC 750 All-In-One InkJet Printer
HP PSC 1210 All-In-One InkJet Printer Logo
96 people viewed this question
Seeker5211
Seeker5211
