Question about Brother MFC 210C All-In-One InkJet Printer
Paper won't feed
I have had my printer for a couple of years now and this is the first time I have had a problem. All of the sudden it acts like it is going to print something and then it beeps repeatedly and says that the paper did not feed. This has never happened before. We have tried to print with only one piece of paper, with a few pieces and also with a small stack. It does the same thing no matter what we do. Please help.
  • Paula Kanouse Aug 03, 2007
    I checked the rubber wheel and when I did I discovered that there was something stuck in the groove of the wheel that the rubber is on. It was preventing the wheel from turning. It was something as small as the tip of a pencil. The rubber seems fine and the paper now feeds, but if you wouldn't have suggested checking the rubber, I would never have discovered the problem. Thank You
    New Friend:
  • 3 Answers
My old Brother printer stopped feeding paper. Finally after i cleaned the rubber rollers with the solution used to clean ink printing heads (not alcohol) it seems to be working fine. I also filled the ink cartridges and this may have helped since I've seen reports that low ink could cause these printers to act funky.
Posted on Apr 23, 2012
    Novelist:
  • 135 Answers
The paper is pulled in with rubber traction wheels on a rotating rod where the bottom of the paper sits in the loading area. If these rubber wheels get slick or hard, they won't pull. Buffing the rubber wheels lightly with fine sandpaper will restore the wheels to the rubbery texture they need to pull the paper. But be SURE to completely clean any abrasive dust out of the machine before use.
Posted on Aug 02, 2007
  • Kevin Omel
    Kevin Omel Aug 04, 2007
    Well, I'm glad your problem is fixed now, even if it wasn't the feeder rollers causing it. ;)
SOURCE:
Canon ip2600 won't feed paper
I fixed mine!! I cut a letter size paper in half lengthwise (so it was skinny and long). Held the printer on my lap with both top and bottom trays open. I noticed the white pegs and skinny black roller inside were turning when I turned it on, so I waited til they were spinning and slid the paper between them along the right side. (Kind of a reverse feed). Had to do it between the crazy ink returns. Yes, the paper crumpled a little, and I did it a couple of times with a couple of papers. Something gave, because after that it started feeding properly again!
Oct 10, 2011 | Canon Pixma iP2600 Photo InkJet Printer
Paper won't feed properly and jams. the paper starts to feed then twists and jams.
There are a couple of possibilities. First is a little piece of paper could be stuck somewhere along the paper path and is causing one of the feed rollers to not grab the paper evenly, which will make the page twist on most of the models in this series, if you pull the paper out and take a flashlight and look up the feed path you will usually see anything in the feed path near/on the rollers at the top.
Another possibility is one of the feed rollers is old and worn out (If machine gets heavy use) and it will cause same issue.
Also light paper stock can sometimes be too thin for the rollers to grab properly and cause it to twist and slide around. This is usually more of an issue with gravity/drop feed printers but can also occur on front feed style too. Usually 20lb stock is good, but if thats doing it, you can try going to a 24lb.
May 06, 2011 | Epson WorkForce 600 All-In-One InkJet...
Paper not feeding correctly
try to clean the carriage and see if a Q-TIP will reach the feed rollers. They probably still have some ink still on them.
I’m happy to help further over the phone at https://www.6ya.com/expert/eric_7148ad2a373711a3
Jul 31, 2009 | Lexmark X5470 All-In-One InkJet Printer
Paper feed problem with Dell 922
Take a cotton swab and some alcohol and clean the rollers. They may be filled with paper fibers.
May 03, 2009 | Dell 922 All-In-One InkJet Printer
Will only print in blue ink
most likely you are out of ink other than blue, try to refill the other colors or get new cartridges.
Mar 26, 2009 | Canon Office Equipment & Supplies
Paper Jam on
most printers are pretty cheap now so replacement is always an option....on the other hand, I will spend countless hours trying to figure out what is wrong first. Remove all paper first, open printer and check for pieces of torn paper or debris, if you have a can of air you can blow out the insides to clean. Put 3 or 4 sheets of paper in, print a test page and watch carefully how paper advances...is it straight or crooked when being loaded? Is printer trying to pull more than 1 sheet at a time? Good luck
May 14, 2008 | HP OfficeJet 7310 All-In-One InkJet...
Paper won't feed
You could try cleaning the rubber feed roller with a slightly damp rag, or even having feed assy replaced but you are right probally better off replacing it.
Dec 25, 2007 | Samsung ML 1430 Laser Printer
Error light & 7 beeps
geez, going back in time,but it is a print position fault, head is not traveling correctly , make sure rail is lubed and carriage can move back and forth without obstruction,
Oct 26, 2007 | Canon BJC 80 InkJet Printer
Brother MFC 210C All-In-One InkJet Printer Logo
115 people viewed this question
James Cagle
James Cagle
Jim Keysor
ctnozil
