Question about Proform Discount GR 80 Recumbent Exercise Bike
Seat movement on proform 80
How do you move the seat back?
Cub Cadet LTX 1040 misfires when forward pedal is pushed. Smoothes out when pedal is released for no movement.
When you say that it misfires, is it a misfire that happens until it moves, or does it misfire and not move?
If the seat is too far back and you move your backside whilst letting off the brake/clutch the safety switch that is in the seat may think you have got off the the seat and will cut out the engine. Please give a few more details of the situation
Aug 22, 2017 | Cub Cadet Garden
1997 Jaguar XK8 Cant move seat forward to get to bolts
found you are not the only owner with this problem
Seat removal frustration Jaguar Forums Jaguar Enthusiasts Forum
from this diagram
I cant see any way of dis- engaging the motors
to get movement on the rail
Nov 10, 2016 | Jaguar Cars & Trucks
The seat goes up and down but wont go back and forth
check fuses and relays --check and test the switch and check connections --under seat you also have connections and motors that move the seat check the channel for debris which can jam the movement
Aug 18, 2016 | Seat Cars & Trucks
Power driver seat will not fully move forward or backward.
make sure nothing is lodged under the tracks this is common things get thrown under the seat and stops them in the track
Mar 31, 2014 | 2002 Chevrolet Tahoe
Passenger seat in 1999 Pontiac sunfire is jammed forward
normally the seat tracks are bolted to the floor or riser. It is possible that when the seat was moved forward the track moved over the head of a mounting bolt and will not return. check for interference between track and rail while trying to return seat.
Jan 06, 2013 | 1999 Pontiac Sunfire
Pro-Form Crosswalk 395 - Incline goes up and down with no tread movement. Calibration doesn't work - only on display.
test the main board, with the output voltage from board for input voltage motor. If there are NOT voltage the board is faulty.replace see the block diagram, how the main boad control about 80% of the machine motion.
God bless you
Sep 29, 2012 | Proform Crosswalk 395 Treadmill
Belt won't move
does is just not move when you're standing on it, or not even move when you're not standing on it. It may be a simple belt adjustment or if the motor is running but there's no track movement you may be looking at a loose/broken drive belt. Take the cover off, start it up and look at the motor/drive pulley assembly. If the motor turns and the front roller doesn't, tension the drive motor by moving it back. If the front roller turns but the track doesnt, do a track adjustment as per your users manual.
May 26, 2010 | Proform CrossTrainer Treadmill
Forward and back movement is only 2 inches
sounds like youve got a kiddy toy stuck in the rail ,4 bolts and the seats out !! BE CARFUL of the spring loaded slider ( if it is spring loaded ) it will *** you if given the chance.
Jan 17, 2009 | 1998 Ford Explorer
Front seat
the rare several motors under seat to control movement in different positions. try to lift seat all the way up and tap lightly on motor not working wihile toggle switch to move forward sometimes works
Jun 16, 2008 | 1995 Cadillac DeVille
Proform Discount GR 80 Recumbent Exercise Bike Logo
24 people viewed this question
Top Proform Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Matt Olenzek
Matt Olenzek
Electro Med Services...
Are you a Proform Exercise and Fitnes Expert? Answer questions, earn points and help others
