Question about Samsung SSC DVR Digital Video Recorder with 80 Gb Removable Hard Drive
Hard Rack Key
Need key for hard rack on sscdvr . Any help ?
    Problem Solver:
  • 7 Answers
The ssc-dvr use the same key as all the other harddrive racks out there and the same keys as the locks on the antique computers..they should be easy yo find!!!
Posted on Apr 03, 2009
Is a master switch expencive are hard to replace
It's located inside steering column and activated by a pushrod or rack and pinion type mechanisim on key switch. It requires that you drop and partially disassymble steering coulumn. I hope that is helpful, I don't know your level of mechanical ability
Mar 10, 2014 | 1994 Oldsmobile Cutlass Supreme
I was driving making a turn It felt like I lost control of car the steering wheel was hard to turn like locked up. had to put it in N and park it Audi a6 1996 I do need to change water pump but it was...
Check the power steering fluid level and add fluid if it is low. Check to see if the steering rack is leaking. You can check it by removing the tie rod boots to see if fluid comes out. Make sure the belt is tight. If the pump works and no leaks, you may need steering rack replacement. If you do need to replace your Steering Rack, this site looks like it has cheap prices, free shipping and great reviews http://www.buyautoparts.com/power-steering-rack.html
Jul 22, 2013 | Cars & Trucks
Bought a barrecrafter car rack off craisglist...i bought it with no keys because the ownr lost them...i need a replacement
look and see if there are any letters and numbers scribed on the face of the lock cylinder, this is the key code-- with this code you should be able to go to your local locksmith and they will be able to cut you a ' key by code ' and it will work. if there is no code on the lock then you can also just take the rack to the lockshop and they will be able to pick and remove the cylinder from the lock and fit a key to it by hand. normal shop rates for making a key in this fasion is about $12-$15 dollars and if you want more than one key - duplicate keys cost about $1.75 to $ 2.50.
(( even if the lock does have numbers on it -- take the rack to the shop with you to make sure the key that they cut by code works before you leave the shop,,, saving you a second trip ))
c...
Jan 05, 2011 | Barrecrafters /sportrack, Sx-12...
Its not a problem to begin? I just want to buy 1 rack like for a SATA III 6 gbps Hard Drive. Will it affect the Hard Drive Speed, reducing it to 3gbps? Or is it just a Rack to support the Hard Drive...
As long as the connector and build quality is good, a rack should work fine.
If the connectors are shoddy, or the fit of the connectors isn't good, then you will have speed issues, or even outright failures.
Aug 29, 2010 | Mobile Rack SNT-125 SATA Plastic for...
Am trying to covert an ML370 server I got yesterday to a rack mountable but finding it difficult to take off the cover.
Use the key to open the front door of the server. Lift the door and remove it. locate the screws that hold the cover remove the screw and remove the cover.
Note that you need to have MS370 rack Kit to be able to successfully do the conversion.
Jul 06, 2010 | Compaq ProLiant ML370 G3 Rack-Mount + Free...
05 silverado hard to turn. new pump! is it a bad rack?
since the rack is used it could be defective. aligning the vehicle will not loosen the steering up
Jan 20, 2010 | Chevrolet 1500 Cars & Trucks
89 Bronco, ignition spins freely, replaced ignition key lock with no results
It sounds like the rack is broken inside the column.The gears would bind from old,hard grease and cause the already thin pot metal rack to break.The steering wheel and the upper column has to come apart to replace the rack,brass gear and the actuator/gear.
Oct 03, 2009 | 1989 Ford Bronco
Steers hard to the left normal to the right
Hello vdc442: My name is Roger and I will answer your question. The steering rack is most likely your problem. The rack has seals inside of it. They start to leak internally and this causes the hard steer to one side. To repair the rack and pinion takes special equipment.The easiest way to repair is to replace the rack. This also takes special equipment in that the car will need realignment when done. Also this is a messy job.The changing of the rack can be difficult. But if you are mechanically inclined you should be able to do this. Make sure to chalk the tires and be sure to use Jack stands to support the car while working under the car.
Should you need further help please just ask. Please rate the quality of the answer you received. THis way we know your answer helped. Thank You for using Fix Ya. Roger
Sep 05, 2009 | 2000 Buick LeSabre
Toyota rav4 removable roof rack
also you need 4 rubber pad's looking is attached on the base of the racks, and 4 clips (conected the roof rack w/ the brackets on the roof on you rav) and the key (is the roof rack are locked).
Mar 26, 2009 | 2000 Toyota RAV4
RACK AND PINON DODGE RAM 1500 2005
if you have a leak from the back of the rack your sector shaft seal is defective. to replace it you need to remove the rack and do it on the bench.remove the locking nut and pull the seal from inside.if you are a rooky replace the rack with a rebuild one. good luck.
Jan 27, 2009 | 2004 Dodge Ram 1500
Samsung SSC DVR Digital Video Recorder with 80 Gb Removable Hard Drive Logo
122 people viewed this question
Top Samsung Home Security Experts
Gary Banta
Level 1 Expert
Cesar Quant
Cesar Quant
Are you a Samsung Home Security Expert? Answer questions, earn points and help others
