Question about Bissell 6591 Power Trak Revolution Bagless Upright Vacuum
When you remove the hose to use the utensils, the dirt is flying out of the hose at the bottom where the utensil is removed from
  • Official Brand Answer
  • 315 Answers
Hi Karen. I understand how frustrating this can be. Dust blowing from the bottom hose is normal because the brush is still rotating. If there's excessive dirt flying out, then you may have a clog in the bottom hose.
Here's a quick link to check for clogs: http://www.bissell.com/FAQDetail.aspx?id=1419&cid=ccsocial
Posted on Apr 25, 2013
Why won't it suck
Hey there! It's possible that you may still have a clog in your vacuum somewhere. The filters can also cause the vacuum to lose suction. Try these steps to restore suction to your cleaner.
1. Remove the dirt cup canister from the vacuum. Remove the dirt cup lid.
2. Remove the primary foam filter. Rinse the filter under running water until it runs clear. Allow 24 hours to air dry outside of the vacuum.
3. Slide the Hepa filter out. Tap the filter against the trash can until dirt stops falling. Replace the Hepa filter. (Do not wash) Filters should be replaced once a year.
4. Remove the hose from both ends. Use a broom stick to gently loosen and clear any clogs from hose.
5. Remove the bottom plate and brushroll. Use a wooden spoon or something similar to loosen and remove any clogs from the lower hose.
6. Check that the brushes are still spinning. If not, replace the belt.
Hope this helps!
Jun 20, 2014 | Hoover UH70120 WindTunnel TSeries Rewind...
How to replace thermal overload switch pacvac 700
Hey there! The thermal protector sensor can not be replaced. It protects the vacuums motor from overheating and burning out. If the vacuum is overheating, follow these quick trouble-shooting steps.
1. Remove the hose from the vacuum from both ends.
2. Use a broom stick to gently loosen and remove any clogs from the hose.
3. Remove the bottom plate and the brushes. Use a wooden spoon to gently break up and remove any clogs from the lower hose.
4. Clean the pleated filter inside the dirt cup by tapping it against the trash can until the dirt stops falling. This filter should be replaced at least once a year.
5. The pre-filter can be cleaned with a brush and then rinsed with water. Allow 24 hours to air dry outside the dirt cup.
6. Clean the secondary filter located behind the grill in the bottom of cleaner cavity. Remove the screw, and grill to access filter.
7. Rinse the filter in cold water with a mild detergent to clean. Allow 24 hours to air dry outside the vacuum.
Following these steps should stop the cleaner from overheating. Hope this helps!
Jun 16, 2014 | Hoover Self-Propelled WindTunnel Bagless...
No dirt in cup and the red thing does not turn
Hello! It sounds like your vacuum has lost suction. This is caused by either a clog or a filter that needs to be cleaned or replaced. Please try these brief trouble-shooting steps.
1. Remove the dirt cup. Twist off the dirt cup lid.
2. Remove the filter cartridge from dirt cup.
3. Separate the foam and cartridge filters. Wash foam filter under running. Allow 24 hours to air dry outside the vacuum.
4. Tap the excess dirt out of Hepa filter. Hepa filter may also be washed. Allow 24 hours to air dry.
5. Check the secondary filter by removing the filter cover from base. Rinse the foam filter under running water until it runs clear. Allow 24 hours to air dry.
6. The red baffle tube inside of the dirt cup is apart of the filtration of the vacuum and needs to be cleaned as well. Twist out the baffle tube by turning 1/4 turn clockwise. Remove any hair or debris wrapped around baffle tube. Baffle tube can be rinsed if needed. Allow to dry thoroughly.
7. Remove the hose from both ends. Use a broom stick to loosen and remove any clogs from the main hose.
8. Remove the bottom plate and the brushes as instructed in the owner's manual. Use a wooden spoon or something similar to gently break up and remove any clogs from the lower hose.
If the filters are too dirty they may need to be replaced. With regular maintenance the filters should be replaced about once a year. Follow the links below to order replacement filters for your UH20020.
Exhaust Foam Filter
Primary Filter
Hope this was helpful!
May 10, 2014 | Hoover Nano Cyclonic Compact Bagless...
It's blowing dirt out the bottom/back
this is caused by a plugged up suction hose AND / OR a dirty filter.
clean the filter - and remove the bottom floor plate and clean out the hose where it bends down to the floor unit ( this is always where the dirt collects when the filter gets dirty and suction is low ).
c...
Feb 22, 2011 | Bissell 6594 PowerForce Bagless Upright...
When I vacuum the dirt and trash come flying out the back of the vacuum, what can I do to fix this?
The filter behind the unit is out of alignment or damaged.
so remove and clean the collected dirt, replace the filter, look for damage here to make the sucked dirt fly over.
Sep 14, 2010 | Eureka Whirlwind 4388 Bagless Upright...
I have Bissell Powerforce Bagless Upright Vacuum. it doesn't suction well. I checked the belt. It is ok. may be clog in the hose.I don't no how to clean. can you help me please?
- Check the dirt cup to make sure it is empty.
- Your vacuum has 3 filters. Dirty filters will restrict air flow. The filters may be hand washed in cold water with mild detergent. Allow them to completely dry prior to reinstalling them. The white HEPA media post-motor filter is not washable.
- Lift the upholstery hose from the bottom holder. Check for suction at the end of the hose.
If there IS good suction at the end of the hose, please unplug your machine from the outlet and try the following:
- Ensure the hose is firmly pressed into the lower hose outlet on the back of the vacuum.
- Check to ensure the brush is rotating. If it is not, remove the plate on the bottom of the vacuum. Check the belt and clean the roller of dirt and debris.
- Check the lower hose for clogs by removing the screw which attaches it and lifting the hose up to clean it out. Also, remove the larger hose by twisting it off and using a broomstick handle, push any dirt and debris through the hose.
Aug 05, 2010 | Bissell Vacuums
My vacuum wil not pick up and I would like to know how to change the belt.
You must remove the bottom plate for access to the belt area. You may have clogged the dirt path ... as long as the bottom is removed, clean the dirt path (hose and fittings)
Feb 15, 2010 | Dirt Devil M084600 Dynamite Bagless...
Vacum not sucking the dirt and the light is not turning on
loss of vaccum brush head not spinning check belt turn over remove bottem plate check belt assmble. remove any string or hair build up sear is the best bet for the belt
Mar 31, 2009 | Kenmore 34923 / 34925 Progressive Bagged...
Dirt devil ultra vision turbo model #087300
As it turns out I didn't clean the hose as well as I thought, The second time I fully removed the hose and found that where it bent was where my problem was. Along with a pen I found about three inches of dirt clogged in the hose. After removing the pen and dirt along with a new filter the vac works like new.
Dec 06, 2007 | Dirt Devil Vision Turbo W/Bonus Upright...
My dirt devil vacuum won't suck up anything and its brand new!!
Take the vac bag off and turn on the vac , it should blow air out, if not unclogg the hose where the bag connects, also when you check the roller and belt, unclog the flex hose(located inside base near roller assembly) that sucks up the dirt. As long as the motor works fine the rest is just maint.
Mar 30, 2007 | Dirt Devil M085805 Upright Vacuum
Bissell 6591 Power Trak Revolution Bagless Upright Vacuum Logo
51 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
