Question about Refrigerators
Commercial refrigerators traulsen G10010 is not cooling properly.
I have cleaned the coils and i am not sure how to operate the micrprocessor control unit to see about the temperature settings.
4 Suggested Answers
briarwood556
SOURCE: My commercial refrigerator (Traulsen) has
Check your coil inside fridge to ensure this is clear of ice, as above said check condenser coil is clean as this will prevent fridge from cooling. If this fails you may need a engineer to further fault find where are you based. Alternatively visit www.yorkool.co.uk they have a great range of commercial refrigerators.
Posted on Dec 15, 2012
freetek
  • 5568 Answers
SOURCE: Traulsen g10010 troubleshooting
Don't know this maker or model but if it is constructed like most modern units, the evaporator is under the bottom of the refrigerator and uses a fan to circulate air past it to dispose of heat taken from inside.
If this fan fails, either completely or because of excessive dust, the coolant is circulating via the compressor but the removed heat from the inside is not being removed from the evaporator.
Check for the presence and operation of this fan.
If failed, it can cause the problem you are having.
Most are accessible from the rear of the unit and are plugged in to permanent wiring so replacement might be quite easy.
Posted on Jun 15, 2008
  • 4736 Answers
SOURCE: Refrigerator stopped working Followed
Hi! It sounds as if, after you followed everything recommend in the Owners Manual and it still doesn't work, than either one of the relay circuits to the compressor or the compressor itself, has failed. As far as troubleshooting this problem is concerned, it's a process of elimination. Check the circuits first with a multimeter. If you have power on the incoming side of the relay circuit, but none on the outgoing side to the compressor - it's a circuit problem. If you have power on both sides, then but the compressor fails to turn ON, it's the compressor.
U-Line has discontinued this model, but parts are still available thru one of their service centers around the country.
Below is a link to there Customer Service Contact page. There you can locate a service center near you.
http://www.u-line.com/customer/contact.cfm
Hope this helped you. Please let me know. Thanks.
Posted on Jun 15, 2011
Traulsen reach in 2 door refrigerator is freezing up . What could be the problem
This Traulsen 3 door was freezing up due to bad expansion valve.
Oct 04, 2014 | Traulsen Refrigerators
Freezer not cooling properly
check your condener coil and make sure it is not plugged, also check your evap coil and see if it is froze up. need more info
Mar 14, 2014 | Traulsen G20010 Commercial Refrigerator
Frozen the coil and leaking water
Turn it off, let the coil defrost completely. After the dripping has stopped completely, check to see that paper and dirt is cleared from the air inlet side of the evaporator. Put a red stick thermometer inside the cooler and don't let the temperature go below 37 degrees F. Make sure the condenser is clean, the door gaskets are good and the doors are closing properly. Last thing is its low on gas and needs a service call. Good luck hope this helps.
Oct 08, 2012 | Traulsen G30010 Commercial Refrigerator
Traulsen g200 not running. Bypassed control box and compressor ran and cooled. Could it be evap sensor or control box
not sure what you mean by "control box" but it sounds like you may be refering to the thermostat. If you bypassed that, and the unit comes on, thermostat is bad. Don't believe that there are any controls in the evap. Only the freezers have evap controls that I know of. Let me know if you need more.
Feb 22, 2011 | Traulsen G20010 Commercial Refrigerator
Traulsen commercial fridge will not cool
As the weather is getting warmer for many people their freezer2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator2_bing.gif Condenser Coil Cleaning Refrigerator2_bing.gif Repair
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
Refrigerator Troubleshooting2_bing.gif Refrigerator Compressor
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
Refrigerator Compressor Start Capacitor and Start Relay
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Jul 31, 2010 | Traulsen G20010 Commercial Refrigerator
Traulsen refrigerator too warm the unit is only 2 years old and current temperature is 44
start with the easy fixes. Check and be sure that the condenser coil, the one by the compressor, is really clean. The system needs to "Breathe" in order to do it's job.
Start there and let me know if I can be of further help.
Mar 23, 2010 | Traulsen G20010 Commercial Refrigerator
Compressor keeps running but no cooling?
Check this video, might give you better idea what could be wrong with that compressor. We cut this one open, found couple issues.
Feb 10, 2010 | Traulsen G10010 Refrigerator
Traulsen reefer iced up,
electric heater must activate and warm to de-ice the evap coil in the correct amount of time ..elements setting under evap coils.ck for voltage to element leads while in defrost.You may wish to remove X terminal wire from defrost clock in order for the clock not to terminate early
Jun 17, 2009 | Traulsen G10010 Refrigerator
full service call video. Traulsen Refrigerator. Found bad motor and replaced. I hope it will help.
Jun 15, 2008 | Traulsen G10010 Refrigerator
Refrigerators Logo
206 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
