Question about Grilling
Ignitor not working on char griller - Grilling
SOURCE: char griller patio pro Model 1515
You can get a PDF file off of chargriller.com I believe.
Posted on May 28, 2008
SOURCE: Conversion kit or fix for LP to NG for the Char-Griller
I removed the jets and drilled them out, #54 is what I started with and then moved up from there to get a good flame( gas pressure may be diffrent in your area). I went to lowes and purchased the universal gas line for grills. Item #: 206469 from lowes, I removed the hoses from the valves, and proceeded to remove the regulator from the hose. After that, i used a 1/4" npt coupling, and a 1/4/" NPT to 3/8" Flare fitting( fits to hose). I drilled a hole in the brace that is under the clamshell(it says UP) that way I had a place to relive stress from the hoses. I threaded the Coupler to the Y then threaded the Flare fitting thru the sheet metal and then the coupling. This was an easy mod minus the garage in disarray, my precision calipers on loan, and 3 trips to the hardware store. The connection that goes to the house is a 3/8" NPT Female, my house has 1/2" pipe, The one wasted trip to the store is because i didnt bring the fitting with me to the store and assumed the size was 1/2 to 3/4(Rookie Mistake). 46e03a6.jpg846ce6e.jpgb1bb7d1.jpg
It was 35 degrees when I finished this mod, and on high for all 3 burners, I got it to 675F in a hurry. the needle was still creepin up, but that is when I said that was good enough for me.
I used my lathe to drill out the jets, ksware is correct with how easy the jets break. I broke the one in the side burner. I will make another one when I get an hour or two. Good luck to you and happy grilling.
Little Elm, Tx.
Posted on Jan 03, 2010
  • 105 Answers
SOURCE: How to find serial number for char griller super
Dear, the serial is located on one of its metal legs, stamped on it. It's not so easy to find, so a bright light may be useful. Also you can find it on the box, if you still have it. Good Luck, Peter_Rei
Posted on Aug 02, 2010
  • 4736 Answers
SOURCE: I need assembly instructions for the Char-Griller
Here's a website where you can find what you're looking for.
www.chargriller.com/store/product_info.php?cPath=23&products_id.
Posted on Feb 18, 2011
  • 4736 Answers
SOURCE: MY CHAR GRILLER 5050 WONT STAY LIT WITH NEW BOTTLE
More than likely, the regulator is locked up.
Turn of the propane tank, disconnect the hose from the tank, Wait five minutes and reconnect the hose. Turn the tank valve on VERY, VERY SLOWLY, until it's fully open. Light each burner individually (that's assuming you have more then one burner), the one furthest from the tank, first. Turn it to the highest flame height and then light the other burners using the same procedure.
If that solves your problem, remember whenever the tank is turned off, turn the tank valve on VERY, VERY SLOWLY.
If that didn't solve your problem, you need to remove and clean all the burners, as well as the venturi valves.
Hope this helped to solve your problem.
Posted on Feb 28, 2011
Manual for char griller 3008 king griller
I could not locate a model 3008. Their gas grill line,starts at 3001 and then jumps to 4001. The only difference is the number of burners.
Here is a link to the 3001, which should be your grill or very similar. You can download & print the manual for future reference.
http://ftp.chargriller.com/manuals/3001_OM_12-11-07_Eng.pdf
I hope this helped you and Happy Grilling. Thanks for choosing FixYa.
Aug 08, 2011 | Char-Griller CharGriller Grillin Pro 3001...
Can you email me the instructions to put together the char grill santa fe series
Try here - they don't list a Sante Fe series, but they do have an Outlaw & a Wrangler listed so they may just have different regional names for marketing. Most of the designs have the same basic layout so look thru the lists & I bet you'll find directions for your Sante Fe series. Good Luck.
http://www.chargriller.com/index.php?option=com_content&view=article&id=16&Itemid=18
Jul 04, 2011 | Char-Griller Char Griller Pro Deluxe...
No grates in box when purchased
If you purchased the grill from a brick and mortar store. Return to the store with your Proof of Purchase and they may supply the grates to you, from another un-assembled grill. Also, most Owner's/Assembly Manuals have a number to call if you're missing parts.
Hope this helps you.
Jun 30, 2011 | Char-Griller Char Griller Pro Deluxe...
Which way do the burners attach on a King Griller Stealth Model#3008
I mounted them ignite side down and used channel locks to flatten the metal ears and attach the coterpin simultaneously ... worked first try
May 08, 2011 | Char-Broil CharBroil 4637318 Grill
Lost my owner manual model #2121
Here it is.
ftp.chargriller.com/manuals/super-pro-manual.pdf
Mar 24, 2011 | Char-Griller Char Griller Pro Deluxe...
How to find serial number for char griller super pro grill
Aug 02, 2010 | Char-Griller Super Pro
How do i replace the batteries in a gas grill's ignitor?
Many grills just use a standard 9 volt battery. Trace the wire from the bottom of the igniter button you push. One of the wires from this button also attaches to the battery compartment. Simply remove the battery and replace. It's usually under the shelf near the igniter button.
May 15, 2010 | Char-Griller Super Pro
Char griller patio pro Model 1515
May 04, 2008 | Char-Griller Smokin' Pro CG010
Grilling Logo
99 people viewed this question
Top Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
Are you a Grilling Expert? Answer questions, earn points and help others
