Question about Dual Electronics N99i Cellular Phone
Battery life Mu battery life is ridiculously short. If it's fully charged, it will become uncharged after 25 mins of talking. Any suggestions?
  • 1 more comment
  • pedro16_d Mar 12, 2009
    Well the battery is brand new, that's why.
    I see, the manual said only from 2 to 3, that's maybe why...
    yeah, but still the first time I charged the first time, it said charge ready after like 1.5 hours, it wouldn't charge anymore
  • 6,784 Answers
This cell battery is near its end. i would purchase another fresh cell batt. seems to be a factory flaw in this battery cell core.
Posted on Mar 11, 2009
  • Michael Masters
    Michael Masters Mar 12, 2009
    oh, OK. you will have to charge for a 12 hour period to get the full charge life in this case.
  • Michael Masters
    that's the regular charge rate after you preform the 12 hour initial charge.
Some batteries has been stored for a long time and uncharged and even the aren't been used they are dead, try an other new battery. the one you have is probably dead. sorry.
Batteries that have been left in an uncharged state will sulfate the plates and render them useless. Only by removal of the sulfate will they be useful again. This is a
very expensive process only accomplished commercially.
Replace battery and keep it fully charged to prevent sulfation. This can be done using a battery maintainer not
to be confused with a trickle charger. Maintainer only charges battery when needed not all the time like a trickle
charger. A trickle charger will also cause a battery to become dry which also damages the cells.
Feb 07, 2018 | Cars & Trucks
New battery charged and it only runs a few mins and stops, what causes this
a fully charged or a new alkaline battery should power a remote for several hours non stop, if your's discharges in minutes either the battery cell is suspect or the charger or there is an undue load on the output. Try a new non rechargeable alkaline battery, if this behaves in the same way you have a fault on the handset, especially if the battery becomes warm during its short period of use. You could "pop" the handset open and check for liquid ingress around the keypad which could cause continuous operation, but the life span would suggest a greater drain than I would expect from this type of cause.
Jan 19, 2016 | Sharp Aquos Televison & Video
Hi, I have samsung SGH - X700, my phone gets switched off automatically when i speak for 15-20 min over the phone. When i put for charging, it shows full charged in 30 min.. Could you please...
The problem is with the battery. The battery life is down.
My advice is that you purchase a new battery from a recognised store.
When you have done that, before you use the phone, charge the battery fully. Also, ensure that the supply of power is steady.
In addition, to sustain your battery life, once in a whlie, like every 2 months, fully discharge then fully recharge your battery.
This should make it last longer.
Hope this helps?
Success.
May 15, 2011 | Samsung SGH-X700 Cellular Phone
My Cell phone battery get discharged very soon while talking on the phone for more than 10-15 min or listening to music for more than 2 min i even changed ma battery a number of time but that problem...
Your battery is just about dead. Time to replace it. The battery life depends on how you use it and how you charge it. You should typically be seeing at least 4-6 hours of talking and a lot more when not in use on a new fresh battery.Get a new battery and allow it to fully charge for 12-16 hours before using.
If you are a heavy user expect to replace the battery once a year.
Jan 20, 2011 | Health & Beauty
CHARGING
Seems like your phones battery is weak. Try these to increase the battery timings:
  • Let your phone to completely draw its battery, once its fully uncharged then recharge it completely and then use it. That will prolong the talk time and battery life too.
  • Lower the brightness of your phone, that will result in less consumption of battery.
  • If it does not helps then consider buying a new battery, but hopefully that wont be needed.
Thank You!
Jul 07, 2010 | LG Vu CU920 Cellular Phone
Can't charge battery
At a minimum your batteries need to be charged for 12 hrs a day for the first month if not they will not build the capacity and will dwindle and die for example it is at only 25% capacity it says it fully charged but will die quickly this happens because it is charged to its full capacity but that is only 25% of the batteries true potential resulting in short battery life. The best thing to do is contact your dealer, as I think you won`t be able to charge the batteries on your scooter as they will have no power. Thething with scooters is to put it on charge when not in use.
Sep 01, 2009 | Golden Technologies Compass Electric...
Batteries require several charges in order to reach fully capacity
I wont exactly call this solved but I called duracell and they think the batteries are old. They are sending me a new set of batteries.
Sep 08, 2008 | Duracell AAA NiMH Battery Charger with 4...
Short battery life
$orry, theres no fix to this, after a while batterys begin to die and the life becomes shorter. this could be due to leaving it on charge all day and night and not letting it frequently loose and gain charge again. even my laptop battery has began to lose its battery length - but ive had my battery for a long time. purchase a new battery and try to keep from leaving the A/C adapter in over night. you should notice alot longer battery length after that. rate me :)
Aug 25, 2008 | Apple MacBook Mac Notebook
Very short battery life on laptop currently lasts about 14 mins from being fully charged to empty
time to get a new battery. For future reference, do not use battery and AC at the same time b/c it will kill the battery. Use one or the other (unless battery is being charge).
May 12, 2008 | Computers & Internet
Short Battery Life
it is the matter of battery life time-nothing wrong
Aug 05, 2007 | Sharp EL-9600C Calculator
Dual Electronics N99i Cellular Phone Logo
80 people viewed this question
Top Dual Cell Phones Experts
William Alequin
Computer Repairing
Computer Repairing
270rexton
270rexton
Are you a Dual Cell Phone Expert? Answer questions, earn points and help others
