Question about HP W2007 LCD Monitor
Hp w2007 moniter is on but no light
It comes on for a minute then goes black with flashlight i can see that its on just no light
    New Friend:
  • 40 Answers
Try connect it to other pc or laptop, sometimes your pc video card won't work replace it
Joel
Posted on Apr 22, 2013
chalkperson
  • 147 Answers
SOURCE: my hp w2007 moniter keeps going black after about
Where you go to select "no" screen saver, there should be a "Power Settings" button. Press this and in there you can set the power save feature to "never" switch off monitor. Hope this helps. Ian.
Posted on Oct 22, 2009
Testimonial: "thx"
SOURCE: power light or screen will not come on my hp w2007
Possible answer as I had same issue. I found the button you press has small tip that presses the actual switch to turn the monitor on. My tip broke off so switch can not be made. Hp does not sell button as that is what I am looking for myself.
Posted on Dec 18, 2009
Bay Ridge
  • 102 Answers
SOURCE: HP w2007 LCD monitor goes off Monitor going to
Make sure that everything is connected to the monitor properly. Go to the back of it and make sure the VGA or DVI cables are secured and then check the back of the computer to do the same.
Posted on Sep 16, 2009
  • 732 Answers
SOURCE: my monitor, hp w2007, shows
tommyguns 14, If "old" known good monitor works well with your pc, (pc not problem) then you should do lots of reading here: http://www.lesliewong.us/blog/2005/05/02/hp-pavilion-f1703-flat-panel-display-blackout-solution/ Let me know if you need more info, or you solve problem, or not.
12fixlouie
Posted on Oct 24, 2010
  • 26 Answers
SOURCE: Hp lcd w2007 moniter keeps
Check the power saving option of your computer. You can find it under the Control Panel. Just look for Power Option then Turn off monitor. Just set it to never or the time you want your monitor to be on.
Hope that works for you.
I'll appreciate the feed back and the thumbs up.
Thanks.
-jash
Posted on Apr 27, 2011
HP W2007 + Xbox 360 = Constant Sleep Mode
the monitor is bad
if it will not power on,
or show NOSIG< with XBOX on then turned off the monitor must show NOSIG>
why not test the monitor on any pc made even laptops VGA jacks works, so that works, its not the monitor.
and bad xbox video caused. but is not it. as you said.
the menu needs sync lines active. to pops the OSD button menu.
so the monitor is bad.
or the cable.
what is w2007, lets see.?
its old. at 1680 x 1050 @ 60 Hz
this old monitor runs CCFL lamps.]
im shocked it glows at all up to now.
ever do flash light trick test?
see got data, but no back light, CFFL is dead.
HP W2007
users guide last page.
This HP product contains mercury in the fluorescent lamp
in the display LCD that might
require special handling at
end-of-life:
that means CCFL died, also all do, soon.
(as short as 2 years, full time , they die. 20k hours)
out of your service manual it shows.
ccfl-wcj1avqu0msqxnqr1cdquwfl-1-0.jpg what any running pc connected the OSD menu most work
not in sleep mode.
if there is sinc, H/V pins active
that OSD must work or the blacklamp is dead
use flashlight see, there is data there, see?
Sep 09, 2017 | HP W2007 LCD Monitor
Hp lcd w2007 moniter keeps going to sleep. Please help!
Thanks.
-jash
Apr 27, 2011 | HP W2007 LCD Monitor
My monitor, hp w2007, shows for about 20 seconds when turned on then goes blurry then black how do i fix???
The most common problem that causes the screen to go to a black screen is due to bad capacitors in the screen's power supply board. The bad caps are the cylindrical and will appear to have bulging tops. 66c561df-0d01-416a-ae23-71f3b3965c88.jpg
Oct 24, 2010 | HP W2007 LCD Monitor
It makes a buzzing sound then goes black!!
nogooddeed, Yes, You too, will need to visit this blog that is quite old, but still of some importance!!! http://www.lesliewong.us/blog/2005/05/02/hp-pavilion-f1703-flat-panel-display-blackout-solution/ And if you need more info on bad capacitors or poor soldering (failed solder joints of active or passive electronic components to printed circuit boards) you will need to visit YOUTUBE for video clips of DIY repair of black and or blank n black screen "cold-cathode-fluorescent-lamp" back-lit lcd monitors. Keep in mind that your W2007 is no different than any other brand of ccfl lcd monitor in it's basic design and operation!!! When you understand the "flashlight test" that every ccfl back-lit lcd owner should know, then come back and let us know what your plans are for your display. To read my profile or any other fixya tech's profile just type their fixya nickname in the above fixya taskbar where it says "search for solutions or" .. Read the profiles of these tech's also: "buddymc" , "budmrtn" and my old file "louie12fix"
After you have done your research and you feel this response was of some help, please rate this response on fixya for others who will be looking for info about their monitors. Bye for now. I'm 12fixlouie
Apr 27, 2010 | HP W2007 LCD Monitor
Picture goes black after a minute or so...
your problem come from the back light source
call ballast power supply or side neon are burn
you probly need a tech to fix it.
hope that will help
Apr 23, 2010 | LG 42LC2D 42 in. LCD HDTV
Power light or screen will not come on my hp w2007 monitor. It's only 13 months old.
Dec 13, 2009 | HP W2007 LCD Monitor
My hp w2007 moniter keeps going black after about 10 mins. of idle .turned off screensaver because i want moniter to stay on but it doesnt.
Oct 21, 2009 | HP W2007 LCD Monitor
Sep 16, 2009 | HP W2007 Desktop Monitor
Hp w2007 blank screen
we have here , like 1000s of black screens posted here now.
all the same all with CCFL lamps. that die. same solution.
older monitors have a power saver mode inside it,
push the front button called menu, then see OSD menu
then find and turn off power saver.
if the OSD fails to show up; the CCFL are dead.
this monitor was made in 2007, and 2010 is the starting year
for ending the usage of CCFL (starting on large screens working to small)
im reading your manual for you now, free.
page 4 tells you it has CCFT (T mean Tube, L means lamp)
same same.
https://www.manualslib.com/manual/1110533/Hp-W2007.html?page=4#manual
now lets look at the page on saver. power
page 7, (its on by default ) oops !
https://www.manualslib.com/manual/1110533/Hp-W2007.html?page=7#manual
turn saver OFF
see next page 8 and turn DDC ON.
see sleep timer and turn that all off.
if you push factory reset, it the problem begins again.
bad. for you.
https://www.manualslib.com/manual/1110533/Hp-https://www.manualslib.com/manual/1110533/Hp-W2007.html?page=8#manual
you can in fact download the whole manual.
for free. here. the site on the internet in this regard.
all old HP monitors are made for old PC 2000 year.
your PC is not 17 years old i bet.
so all this old saver stuff is now WRONG.
(all this is old school Energy Star , malarkey, )
Nov 13, 2017 | HP W2007 LCD Monitor
HP W2007 LCD Monitor Logo
79 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
