Question about Dryers
Can I use timer from Maytag LDE512 in maytag LDE309
  • Mark Oconnell Apr 21, 2013
    Timer is physically broken. My ? was are they interchangable?
Have a maytag heavy duty dryer model lde512 07 series and it is not getting clothes all the way dry what could be wrong
Problem might be with your washer not spinning them dry enough..or your vent is plugged up with lint
May 06, 2017 | Maytag Dryers
How do I change the belt ona maytag dryer LDE512?
Take of the main cover and you can change the belt ,
No problem at all it is easy to do.
Jan 09, 2015 | Maytag Dryers
Maytag washer MAH4000AWW timer will not advance. Washer will operate if I manually advance timer. Have changed timer, followed Drive System diagnostic test, the wax motor and control board were replaced a...
there is a motor inside the timer that turns the knob. the problem must be the replacement timer. was it a brand new timer from maytag or a 2nd hand? also double check your timer is connected correctly.
Nov 08, 2013 | Maytag Washing Machines
Maytag dryer LDE512, 20 years old. Buzzer is stuck and won't turn off when door is shut....
Motor centrifugal switch may be stuck. End of motor where switch is may be full of lint
Oct 16, 2010 | Maytag Dryers
Maytag LDE512 wont dry clothes, and the drum does move the clothes around.
sounds like a thermal fuse problem!
whens the last time you had the vent cleaned
this failure’s usually not the thermal fuse’s fault, but the real cause lies in a partially (or completely) clogged dryer vent system. In those cases, the thermal fuse is just doing the job it was designed for.
Oct 07, 2009 | Dryers
Maytag Atlantis MDE7400AYW timer has been replaced but the dryer won't stop drying on it's own. What is the reason? I have the same problem... the timer on mine doesn't seem to work. Any ideas?
The wire connections to the timer may have not been made correctly when it was replaced bypassing the OFF contact in the control circuit.  There should be a wiring diagram inside the front or back panel that you can check.
Jun 02, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
Dryer will only dry clothes half way, then when i go to continue drying,dryer will not turn back on until cooled down
Hi, the motor is overheating. i recommend inspecting the motor windings for splits or separation within the strands. make sure all wire connectors to the motor are not corroded or lose. replace the motor if there are signs of windings failures or discolored copper strands.
May 28, 2009 | Maytag Dryers
Dryer makes rumbling sound when starting
If you remove the front cover and access the blower fan and see if it is still tight on the shaft. if it isn't it makes a rumble sound when started due to vibrating and after a while it makes more noise as it goes. Now I removed the fan and placed a shim in the flat area and matched the flat area of the shaft and replace it back on the shaft and it should solve it.
Mar 21, 2009 | Maytag MDE2600 Electric Dryer
Timer won't stop
If the timer is still running thru stop points and continues running thru you timer is definitely bad.YOU EASY PURCASE ON AT YOUR LOCAL MAYTAG DEALER OR ONLINE. Glad to be of service.
Jan 08, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Dryers Logo
26 people viewed this question
Top Dryers Experts
