Question about Apple Mighty MA086LL/A Mouse
Green light on Mighty Mouse blinks two times
And it doesn't work. What do these two blinks mean?
  • 1 more comment
  • Anonymous Mar 30, 2009
    Won't sync and blinks twice
  • Anonymous Apr 27, 2009
    Mouse is not working and green light is blinking twice--space--twice.
  • Brian Sandridge
    Brian Sandridge Jul 27, 2014
    I was about to freak out! But rebooted system and fine! Whew.
Since I posted "have the same problem" I found out what that problem was for me: Mighty Mouse is Bluetooth enabled, and my Bluetooth was off. That was all!
Posted on Apr 27, 2009
The red light on my mouse keeps on blinking
Here's a guide;
What do the battery lights mean on my mouse? Some keyboard and mouse models feature a battery light that shows the current status of the batteries. The following table describes the different lights and states.
Light
Device Model Status Single long green blink Rechargeable Batteries are good. This occurs when batteries are first installed or every time that the device is turned on. Slow green blink Rechargeable Device is docked in the charging station and is charging properly. Steady green Rechargeable Device is docked in the charging station and does not need additional charging. Steady green Presenter Mouse (Japanese version) Laser pointer is on. Red/green blink Wireless Device is discoverable (trying to connect to the transceiver). Slow red blink Non-rechargeable Batteries are low and need to be replaced. Slow red blink Rechargeable Batteries are low and need recharging. Fast red blink Rechargeable Device is docked in the charging station, but there is a charging error.
Reasons for errors: The wrong type of battery is installed; the battery or batteries are missing; or the battery connection is bad.
Solutions: Make sure that the correct battery or batteries are installed, and are installed correctly. If necessary, remove the batteries, wipe them with a clean cloth, and reinsert them. Steady red Presenter Mouse (Standard version) Laser pointer is on.
Oct 18, 2014 | Computers & Internet
NIKON MH26 BATTERY CHARGER BLINKING GREEN LIGHTS
A blinking green light means the charger is charging the battery. A steady green light (same LED) means that charging is complete. If the light never stops blinking and we assume that your charger is working correctly, you may have a defective battery. Rechargeable batteries do not last forever. After a few years, there ability to take and hold a charge declines. It may be time to buy a new battery.
Apr 10, 2013 | Nikon D Cameras
I have a compucessory wireless mouse and keyboard. Mouse model 40918. My mouse just stopped working this morning. How do I get it to reconnect?
check the batteries on the mouse
usually on the underside of a mouse possibly under a plastic sticker rub your fingernail across the top to locate a small (phillips screw) star screw make sure they are connected you can do this by spinning them around and fully charged
hope this heps
Oct 25, 2011 | Compucessory Wireless Optical Mouse...
Blinking/flashing lights(orange & green) & won;t pring. Have rebooted computer and unpluged printer. still won't print.
that is because ur head of ur printing cartridge is damaged.
remove ur cartridges black as well as color
n install only black cartridge n check d blinking of lights on ur printer if it doesn't blinks it's mean ur black cartridge is OK but ur blinking of light on ur printer is same it's mean ur head of black cartridge is damaged
after this process remove the black one cartridge and install the color one cartridge n check d blinking of lights on ur printer if it doesn't blinks it's mean ur color cartridge is OK but ur blinking of light on ur printer is same it's mean ur head of color cartridge is damaged
now take a dry cotton cloth n gently clean ur cartridges head install both cartridges on ur printer n check ur blinking light on ur printer that will work only if u r too lucky other wise u have to purchase a one cartridge.
May 29, 2011 | HP DeskJet 5550 InkJet Printer
I put new batteries in and everthing lights up. The mouse worked at one time but I haven't used it in a few years. I've pushed both buttons (1) on the mouse and (2) on the USB adapter, the adapter blinks...
disconnect the usb adapter from the system connect it again mean while remove the mouse batteries re insert or better change batteries then perform the step that you ahve already tried
Oct 17, 2010 | Kensington 72219 Mouse
How do i connect a mighty mouse on my computer
Hello Sir,
plug in the cable into USB or PS2(green) slot on the back of your computer.
Cheers,
Mike
May 08, 2010 | Apple Wireless Mighty Mouse
MOUSE LIGHT FLASHES red and green; does not function
The flashing red and green lights means that now it's in discoverable mode and it's time to add it as a bluetooth device.
Mar 14, 2009 | Microsoft Wireless Laser Mouse 5000
I have purchased a Microsoft Wireless Optical Desktop 700 (Keyboard & mouse). I have plugged the wireless receiver in, and get a flashing green light when I press the button on the front. The green...
When you say you pressed the connect buttons on both the keyboard and mouse, do you mean you pressed the connect button on the receiver, and then you pressed the connect buttons on the mouse and keyboard? If not, then that's what you have to do. The 30 seconds of blinking on the receiver is normal, as it gives you time to find and press the buttons on the mouse and keyboard.
I hope this helps, and good luck!
Jul 16, 2008 | Computers & Internet
Mouse not working
Mouse not being detected in Windows 9x, ME, 2000, XP, or Vista. If the other mouse works in this computer attempt to use the mouse not working in another computer.
How to navigate Windows using a keyboard. Not only does this help users who do not have access to a mouse, it can also save you a great deal of time when working with text documents.
Autoexec.bat and config.sys help and instructions If the mouse drivers are not loaded properly you will not have the .... line is the name of the CD-ROM driver on the particular system we are working on.
Good Luck/Please dont for get to Vote.Thank You
Dec 19, 2007 | Computers & Internet
Apple Mighty MA086LL/A Mouse Logo
11,488 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
