Question about Toshiba 43H70 43" Rear Projection Television
Toshiba 55 cinema series
I have a blue shadow. I tried the convergence screens and can't get the blue to move in the right direction. the set is 8 years old and the service center wants $500.00 to repair it...........Please help!
  • 398 Answers
If the blue color is curving inward on one side, this is caused by one of the convergence IC's which has burned out. There are 2 large black convergence IC's mounted on large metal heat sinks and one of them will have to be replaced and that should be done by someone experienced in repairing and realigning convergence circuits. Some shops prefer to go ahead and replace both at the same time, removing the STK392-110's and installing 2 updated STK392-150's, which is not such a bad idea. When I do a housecall to repair a set like that I charge $150, since the IC's are about $7 each and it takes about an hour to change them, so ask around the shops in your area and see if anyone's price is better than $500, which sounds way too high.
Posted on Aug 04, 2007
SOURCE:
Mitsubishi RPTV has a blue shadow/image alignment problem
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projeciton sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right. And you should be able to get the grid straight.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a fix
69189a5.pngCONVERGENCE SOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you are handy and can follow directions. You can get complete repair kits from TvRepairKits.com or click here. They have put together DIY repair kits that include the OEM parts and step by step photo instructions for each repair. If you are not handy or can't follow directions we would suggest calling a shop.
May 23, 2010 | Mitsubishi WS-65809 65" Rear Projection...
Color convergence issue.
Yes,U know how to solders?Must replaced 2 convergence ICS,and some or all it resistors.Tries websites Tv repair World.com,Tvrepairworld.com to buy a convergence to repair it ur self.The shop will cost U $300 for parts and labors.
Mar 27, 2010 | Toshiba 55H70 55" Rear Projection...
Has blue shadows
  • Screen looks 3D
Jan 09, 2010 | Hitachi 50UX26B/27K 50" Rear Projection...
HITACHI 57UWX20B has blue ghost shadows how do I
  • Screen looks 3D
Jan 05, 2010 | Hitachi 57UWX20B 57" Rear Projection...
Blue Shadowing on Flat Panel 50"
  • Screen looks 3D
Jul 26, 2009 | Sony KP-41T65 41" Rear Projection...
Have colored shadows around everything on my Mitsubishi HDTV 1080
  • Screen looks 3D
Jun 24, 2009 | Mitsubishi WS-55613 55" Rear Projection...
Blue shadow
Your TV most likely has a convergence failure. ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
Using your original remote go-to the tv settings then goto the convergence section.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
0667c5f.pngSOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses. Its a fairly easy DIY job or you can call in a pro. If you want to do the repair yourself check the site www.TvRepairKits.com. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, thermal paste, email/phone support, etc.
Jun 20, 2009 | Hitachi UltraVision CineForm 55VG825 55"...
Shadows on left side of screen,right side has no shadows
  • Screen looks 3D
Nov 28, 2008 | Hitachi 53SWX10B 53" Rear Projection...
Toshiba cinema series convergence problem
If you wish to get some details; visit the site linked here. Pull up older posts.
http://electronicshelponline.blogspot.com/ Convergence adjustment procedure to many brands of projection TVs are given in detail.
Jul 10, 2017 | Toshiba CX36F84 TV
Red double picture with green and blue
convergence problem there are 2 integrated circuits inside the set needs to be replaced
Aug 25, 2008 | Toshiba TZ50V51 50" Rear Projection...
Toshiba 43H70 43" Rear Projection Television Logo
48 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
