Question about Panasonic DMRES15 DVD Recorder
No power. Dead/ it kinda got shocked.
Got over amped with 220v. It was not on at the time but was plugged in.
Can it be repaired? I really want to fix it.
Does it have a fuse?
Panasonic Double cassette, CD, Reciver
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 112 Answers
There is a small fuse on the circuit board - a 20cm F5A - that has probably blown. Unfortunately, though, the PCB (506E) may also have blown and may need replacing.
Posted on Apr 20, 2009
110v base plugged into 220v
Hi Allen,
Yes you can fix.
please go to repair personal with power adapter or buy same type one or by alternative power adapter but output must be same as the original and 220v as in .i think buying new one is a good idea.
regards,
nuwan.
Jan 09, 2014 | Panasonic KX-TG9341T Cordless Phone
Plugged 120V appliance into 220V socket
Its dead, and whatever you do, DO NOT plug it into any power again, it could cause a fire so fast that you would be in mortal danger.
Most of the world uses 'real' levels of power, your american appliances cannot handle it.
Dec 19, 2013 | Blenders
GoPro HD Hero repair power button???
Do you know A thing that there's inside some lighters, those lighters, I mean, it isn't a lighter stone, it's other kinda lighter, it's a lighter that you have to push the button and it gives a "shock" at the gas, and the fire come out, well, you need to disassemble that kinda lighter and get the thing that makes shock when you push it, and give a shock in your go pro by the usb, it works if you do correctly.
I have a broken gopro, and I just get the way to give shock and do it at the usb on gopro, and the gopro turns on!
Mar 08, 2012 | GoPro HD Motorsports HERO Camcorder
My charger is accidentaly connect into 220v and this is burn. im here in philippine. its this to repair and i use again...
Is this a 110Volt version that you plugged into 220v?
There is a ceramic Fuse inside the unit that might be blown. It is the first thing on the circuit board near the power cord connection.
Open the unit up and post a photo of any burned components ?
Jul 10, 2011 | Makita 2 Bl1830 18v Battery,dc18ra Charger...
Someone just plugged my120V Yamaha RX-v850 into a 220V outlet by mistake. Did it burn the whole thing or is there a fuse I can replace and all will be well?
there is a fuse however, depending or if it was turned on afterwards , it will be much much worse.
it is possible there is damage as it will be likely that the fuses are not a semiconductor type ( really fast ) so overvoltage will have reached the secondary of the transformer and onwards to the rectifiers and capacitors and then to the voltage regulators untimately ending up on the boards via the DC rails.
This can cause significant problems with circuit components and more problems with the low voltage micros inside.
If you are really lucky changing the blown internal fuses may work, but could cause even more damage, so be prepared for an expensive repair.
If none of the above makes any sense then you need a tech or repair shop.
Hope this helps
Thanks for using FixYa
Aug 19, 2010 | Yamaha Audio Players & Recorders
What will happen if I plug my 110V tv into a 220V receptacle?
If you want to fry your electronics or appliances that's it's a sure way to accomplish that.
While appliance working ONLY at 220v will just not work or under perform (like a hair drier) when plugging electronic equipment that runds ONLY at 110v then that item will be "fried" as all its electric components will be burnt as it will receive twice the power that it was build to receive. Should that happen the safety switch on the 220v circuit where the item was MISTAKENLY plugged will be triggered (hopefully or there will be risk of fire and serious injuries, even death) and the power will be shut off. That's a major but possible mistake.
If traveling abroad those who come to US will unlikely damage their appliances (like electric razors) as they will receive less power (110v vs 220v) and usually these items are protected against these mistakes by the specifications of their own design. The opposite is not true of course as just mentioned above.
So do not play around with dangerous items please! ;) On a positive note though: Nowadays most appliances have dual power and should work whether plugged in a 110v, 60Hz (most common in US) or 220v 50Hz (most common in Europe). So nothing really happens... it just works as long as you have the proper adapters to plug the appliance to the different receptacles.
Note: One of the differences is that (without going into the math of it all), an appliance working at 110v will draw x2 times the power than it draws when working on 220v so if an appliance was drawing 3A at 110v it will only draw 1.5A when working at 220v.
Best.
Jul 05, 2010 | Televison & Video
Line 6 Spyder 112 got plugged into 220v now just smokes.
The power supply is bad. The transformer more than likely survived however some fuses and possibly filter caps could have been blown. Also some of the regulatory circuitry for switching or digital lines could have been damaged. This being said you should be able to get the amp working again without any problems.
Jan 09, 2010 | Music
Absolutely nothing happens when i turn it on, it says to check fuse. how do i figure out where the fuse is
The fuse is contained in a compartment just above, but integral to the plug receptecle on the unit (where the cord plugs into the unit). First unplug the cord from the unit. Next pry the fuse out with a small straight screw driver. If you own the 110v version (as opposed to the 220v unit) you'll need the 1.6 amp slow blow fuse. For the 220v unit use the 1 amp slow blow fuse. Just match up the fuse you remove from the unit. The above information was found in the manufacturerers owner manual. Found online at: http://www.ecoquestintl.com/support/US40135_Fresh_Air_Owners_Manual.pdf
page 7 - Changing the Fuse
Nov 17, 2009 | Ecoquest Flair Air Purifier
10,000 watt generator 220 plug doesn't work
Most generators have several circuits incorporated within the windings. There are usually two 115v windings, one or two windings that produce power and sensing voltage for the regulator that supplies power to the armature (produces magnetic force) and sometimes a 12v winding to supply power to charge the battery. The two 115v windings power one 115v plug each and together power the 220v plug. Each outlet has a breaker and or ground fault. Since the 115v plugs are working indicates that the 220v plug must have an open/broken wire or faulty breaker. Easy to check, however you must open cover to wiring compartment and trace wires. Should be easy fix. You do not have to start engine to find broken wire. Use ohm meter instead. With engine off, Insert probes into 115v plug and obtain ohm reading. Then insert probes into second 115v plug and obtain similar reading. Look for same reading at the 220v plug (remember 2 circuits of 115v, ground and neutral). Good luck with your repair and email if you have other question.
May 09, 2009 | Electrical Supplies
Panasonic DMRES15 DVD Recorder Logo
74 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
