Question about Car Audio & Video
Gas gauge not working proper - Car Audio & Video
Gas float
Posted on Apr 23, 2013
  • Tammy Salyer Apr 24, 2013
    How can I change or fix the float? Thank you for helping me.
Gas gauge not working properly?
This is caused by a defective fuel level sending unit inside the fuel tank.
Sep 12, 2016 | 2002 Oldsmobile Silhouette
2000 Buick Lesabre rpm and gas gauge not working properly
Probably corrosion in connections from sensors to the dash circuit board. Could be components in the dash circuit board.
Mar 06, 2015 | 2000 Buick LeSabre
Gas gauge has ouit working
Like most all vehicles, it could be the sending unit in the tank or the gauge on the dash. The sending unit would be disconnected and the circuit checked.
Feb 24, 2014 | Dodge Cars & Trucks
The float wasn't put back in properly. good luck
Dec 07, 2013 | 2006 Mazda 6
I have a 2000 buick Le Sabre. gas gauge does not work properly. i filled the tank and the gas gauge reads full. and it works properly past half. then it starts flucturating. i disconnected the gas gauge...
There are three possibilities. The gauge could be defective. The instrument panel voltage regulator could be bad or not grounded or (most expensive) it might be the sending unit.
Mar 11, 2011 | 2000 Buick LeSabre
1987 ford e350 gas tank filler pipe had a ping pong sized ball inside. was this attached to something else? gas is coming out of the filler when you run the engine. what is stuck in there? do you have a...
Does your fuel gauge work properly? If not, the "ball" could be the float from the gauge sender. If the gauge does work properly, then you may have foreign objects in your gas tank. If so, then you should remove the tank (preferably when it is empty) and clean it (and the filler tube) out thoroughly.
Aug 21, 2010 | 1987 Ford F 350
Fuel gauge stops working at half empty and will not let you fill up gas tank at full outlet speed from gas pump
you have 2 recalls
pcm update fuel pump replacement
fuel pump module replacement and pcm software
May 05, 2010 | 2006 Chrysler Pacifica
Gas gauge does not work
was the gas tank empty or full some times the gauges won't work untill the tank is full or the wire for the gauge was not put on properly
Aug 18, 2009 | 2002 Chevrolet Cavalier Coupe
check with GM on a recall
Dec 06, 2008 | 2005 Chevrolet Impala
Car Audio & Video Logo
184 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
