Baxi Luna 3 310fi error 03
Boiler is periodically going out on error 3 (flue temp sensor/ pressure switch) A tech recently replaced the pressure switch about 6 months ago.I feel he may have not diagnosed the problem correctly because the error code continued every month or so. I cant recreate the trip while Im there. I put it thru its paces running it in high fire and low fire with no avail.. Any suggestions? not one to be a parts changer
  • 15 Answers
SOURCE: My furnace, a goodman gmh951155dxa is not running
did the tech check the heat exchangers
Posted on Jan 02, 2010
heatman101
  • 43501 Answers
SOURCE: I have an ideal standard he30 boiler instaledi
You have a problem that the installer does not know how to fix so they are just stringing you along hoping that you will give up and find some one else or forget about it..
You need to tell them to
1. fix the boiler correctly
2.take it back out and give you a new one at their expense
3. or tell them you will call another comapny to fix it and will give the bill to them to pay.
You did not get what you have paid for... do not pay them any money to come out and troubleshoot the boiler.
The boiler should work as the instructions say or someone did something wrong...
Sometimes it is best to call the boiler company and talk directly to their Tech. Support people.
I hope that this will help you to solve your problem!
Thanks for using Fixya!!
Heatman101
Posted on Dec 24, 2009
Testimonial: "offerd good advice"
  • 3309 Answers
SOURCE: Baxi 130HE losing pressure
I would go with the valve first cheaper, then see if it still doing the same thing
Posted on Mar 04, 2010
  • 415 Answers
SOURCE: woke up the other morning with no heating or hot
Per the User's Operating Instructions you want to check the condensate drain. Make sure it is free and clear. Also check the ingnitor, ensure there is no debris or buildup that could prevent it from firing properly.
Also, here are the Installation and Service Instructions that might be of help to you.
Without being onsite with toolbox in hand, I hope this information is very helpful to you. :-)
Posted on Mar 31, 2010
  • 320 Answers
SOURCE: my pressure is low on my baxi boiler have attached
Does the water pressure before the heater is strong? if so then there is a problem with the entrance valve.There might be some object that blocks the entrance of water or the valve itself is not working properly.
Posted on Nov 04, 2010
How do I have my Luna Duo-Tech Baxi Boiler replaced while under warrantee?
Go back to the supplier . or to the company that fitted it in .
Jan 08, 2018 | Heating & Cooling
Baxi boiler
Make sure the gas inlet & outlet pressures are correct (manometer) & that the primary air mixture is adjusted correctly. Check to make sure you have 1 square inch of outside air for combustion per 2000 BTU's rating on the boiler.
Nov 24, 2013 | Heating & Cooling
Baxi duo tech he a range pressure rises from 1bar to 3bar when fired up and when off for say overnight pressure to low and have to re pressurise
Check for water leaks on boiler and system check to see if pressure relief valve is not passing .when boiler is off
Jan 29, 2013 | Heating & Cooling
Woke up the other morning with no heating or hot water from my 5 or 6 year old baxi 105e combi.i have,within the last 2 months, replaced the central heating temp sensor,and currently have the usual(and...
Mar 31, 2010 | Heating & Cooling
Baxi solo340p overheating no control
the gas valve is just a valve that open and shuts which lets the gas in,
the cylinber stat controls the hotwater
there must be a thermsat on the boilet that controls the water temp and a overheatstat thats controls the boile which should shut dow in the event of overheating if you go to the baxi wedsite you can down load the info for your boiler
Jan 15, 2010 | Heating & Cooling
My boiler(baxi luna HT330) keeps going into E1 fault mode.
After you pressure system do you bleed the rads then top up again .
Jul 19, 2017 | Water Heaters
Baxi solo 2 30pf will not fire up.. please help!
first off ensure water is getting to boiler, next, No pilot = pressure switch. On my baxi solo 40 pf pressure switch is replaced 8-10 times a year cures your problems,,,,,,,, momentarily , and have had all your other parts,but with no effect to speak of,.......sorry............ solution = [ change boiler ].sounds like gas pressure or lack of water to system or **** boiler like mine .........good luck.
May 15, 2009 | Water Heaters
Manual for Baxi Boiler
any merchant will get one mailed out to you
Jan 24, 2009 | Water Heaters
Heating & Cooling Logo
1,274 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
