Question about HP Wireless Headset H8000 opal
Microphone noise background - HP Wireless Headset H8000 opal
    Habit-Forming:
    New Friend:
  • 13 Answers
If you have noise background, you most likely have 1 of 4 problems.
1) (most likely) need to charge/replace the headphone batteries
2) there's a fan on in your room/workspace and you need to get a wind screen for your microphone
3) your equalizer settings for the program you're using are set incorrectly (probably too much gain)
4) (least likely) there is a magnetic/electrical device between your headset and the usb receiver that is causing interference
Posted on Apr 14, 2014
What is the purpose of a windbreak
Windbreaks are used on microphones to prevent wind noise being heard. Usually comprised of foam or formed feather like material, they are placed over a microphone to prevent noise from either a persistent wind or even spitting and lisps from users of the microphone. Most cellphones use electronic windbreaks, also known as noise cancelling technology to handle wind and background noise as well.
Dec 03, 2014 | Cell Phones
Back ground noise
You cannot remove the background noise of already recorded material unless you have special software for that purpose. It is available, but costly. To eliminate some background noise, you may in the future, try to muffle the microphone by turning down the volume and recording by moving the device closer to the sound sources. Some folks put a wind sock over the recorder, as you may have noticed during TV News recordings on street events or at a studio. Try a wool or thick sock over the recorder and see if that helps.
Apr 15, 2014 | Olympus VN-711PC Digital Voice Recorder...
I Purchased behringer c1 u microphone and I want to record my singing with karoke..Problem is that when I connect laptop with speakers my singing volume is coming louder but sound of background music is...
You need a mixer. Connect the microphone to the mixer and also the background music. That way you have separate control of volume for the voice and the music.
The background noise can come from different sources. One of them is from the laptop itself, if the laptop is noisy to begin with.
Mar 14, 2014 | Behringer C1U Microphone
Background noise recording with dell
Get a wired lapel microphone and plug it into the microphone input on your Dell. The onboard mic is designed to record all ambient sounds. You want a different product to get the result you're looking for.
May 20, 2017 | Dell Audio Players & Recorders
Can't get rid of background noise on my marantz pmd660
Did you ever find a solution to this problem? I have tried new AC adapter cord and it still has background noise. The only time it doesn't is with the batteries.
May 15, 2012 | Marantz PMD660 Digital Voice Recorder
Sometimes my AKG Perception 420 won't record properly, when played back it sounds like white noise with the faintest sound of what i'm trying to record in the background
All microphones have a signal to noise ratio. Basically defined as the level of desired sound to background noise (unwanted sound). Microphone phones also have self noise which should be considered when choosing a mic. There will be noise in every mic, some more audible than others. Condenser microphones require phantom power (48V). This can be supplied by mic prea
mps, mixers, and similar equipment. *Note that phantom power (mic pre amps) must be on or engaged, this can be specific to different types of equipment.
Troubleshooting:Has your microphone been dropped or exposed to moisture? Internal damage to your microphone will be hard to assess but this could possibly be the issue. Inspect the microphone cable, check for damages. Try using a another microphone cable-- preferably a new one. Next to check would be your mic's power supply. Make sure all connections are made properly (mic to cable to power supply). If you are using a mixer or pre amp with multiple inputs, test the mic on each input. (You should test by making recordings and comparing with each change to isolate possible causes). Also test the mixer or pre amp by slowly sweeping the input gain feature while recording an audible source such as singing into the microphone. Typically next in the audio recording chain would be your DAW (digital audio workstation) or computer, but problems with noise most likely precede this.
I could possibly provide more useful information if I know your exact setup.
Provided that you have your equipment setup properly, the microphone or mixer/preamp could possibly be damaged/malfunctioning. I suggest taking your equipment to a trusted repair shop, or if still under warranty, returning to the manufacturer for repairs or replacement.
Hope this helps
Apr 05, 2011 | AKG Perception 420 Microphone
An external microphone will not cut out the background noises, no matter what settings we change...the built in mic is disabled, but the noise in the background is very loud unless we are talking, and evn...
Most microphones (especially those made for use in a computer) do not remove any background noise. This is usually done via software, but it might not be available on every app out there.
If you can't talk properly using your current mic, your best option might be getting a headset. Headsets have a less sensitive microphone, which will tend to pick up only your voice. If you have a bluetooth headset, you can use it on your computer by adding a bluetooth dongle.
Mar 22, 2011 | Computers & Internet
I'm thinking of buying Logitech USB Desktop Microphone but I want to know if it works well with multiplayer games because that what i would use it for. I haven't been able to find any info on how the mic...
Yes, this mic does work well. Headset usually work the best, but I do know a few people who use this mic for their gaming.
Control and convenience
  • Advanced digital USB: Experience superior sound clarity with the simplicity of a single USB plug-and-play connection.
  • Noise-canceling microphone: Filters out unwanted background noise.
  • Power switch: Illuminates when microphone is active.
  • Adjustable microphone: Pivots on base to hold preferred position.
  • Eight-foot shielded cord: Gives you more desktop flexibility.
  • Mute switch on base: Instant and easy muting.
  • Weighted base: Adds stability.
Technical Specifications
    • Frequency response: 100 Hz–16 kHz
    • Input sensitivity: -67 dBV/µbar, -47 dBV/Pa +/- 4 dB
    • 8-foot shielded cord with USB connector
    • Connector: USB 1.1
YOU CAN GET USER REVIEWS HERE:
http://www.google.com/products/catalog?q=logitech+usb+desktop+mic&oe=utf-8&rls=org.mozilla:en-US:official&client=firefox-a&um=1&ie=UTF-8&cid=16452149199579405298&ei=GyxWSr-ePIrQM7aJvZ0I&sa=X&oi=product_catalog_result&ct=result&resnum=5#ps-sellers
Jul 09, 2009 | Logitech USB Desktop Consumer Microphone
Background Microphone Noise
The problem is that your microphone is generation feedback when the talk because you have the speaker volume turned up. Try lowering the volume. If this doesn't work I suggest you use a set of headphones and it will eliminate this problem completely.
Hope this helps. Bud
Feb 01, 2009 | Microsoft LifeCam VX-3000 Web Camera
HP Wireless Headset H8000 opal Logo
81 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
