Question about Garden
Need service manual for a GT2550H White outdoor mower
Didn't get manual from seller when I bought. Want to service mower myself. Thanks.
  • 3 Answers
SOURCE: Webb Diplomat 350 Petrol Lawn Mower stops running 10 minutes
The 'DIPLOMAT' series of WEBBs is bad news, its NOT a WEBB! Webb were swallowed by qualcast-atco-suffolk, who dunped Webbs tooling, & dressed up punches & commodores in thin disguises, dumped the briggs & stratten engine for their own alloy job, & charged a rip off premium for the Webb decals!
The qualcast suffolk alloy engine suffers from a WIPAC electronic ignition unit. As it gets old, it fails, sometimes completely, sometimes as it warms up. Once cool, it works for a while again.
Not too hard to replace, but hard on the wallet, £69 genuine, £40 fake! On the whole its not too bad an engine if cared for & oil changed often. better to look on ebay for a cheap used HONDA engine & transplant! R-E-L-I-A-B-L-E !............I did! ( £35 honda gc series, 5,5hp! )
Posted on Apr 02, 2010
Testimonial: "Thanks very useful information.....Many Thanks"
How long is the Belt for a White Outdoor Mower, LT 5420-G?
get the model number of the mower and take it to a mower parts store they can tell you
Jul 15, 2016 | Mtd 22" White Outdoor Self Propelled High...
My 18 hp white outdoor lawn mower when cranked continues to rev until I am forced to turn it off
Adjust your throttle cable . Your owner's manual shows and tells you how.
Jun 27, 2013 | Garden
No sprk 6.5 brigs and straton self propelled white outdoors mower
remove the upper cover from the engine then unplug the small wire from the side of the coil then look for spark if still no spark the coil is bad
Aug 15, 2012 | Mtd 22" White Outdoor Self Propelled High...
Wont start and lost manual for a mtd yardmachine 8/26
Sounds like you will need to clean your carburetor.
Sometimes you can get by with priming it a few times, and letting it run a few times like that and it will flush the gunk out of the jets...but most of the time you will need to rebuild the carburetor. If the mower is over a couple years old, then I also recommend that you buy and install a new carburetor repair kit, because the diaphragm will get hard and that will cause it to be hard to crank. When you clean your carburetor and remove the jet screws, count the number of turns it takes to seat the jets from their original position. That way when you go to put the jets back in, you know how many turns they were in/out. Please rate me, Thanks Good Luck, I hope this helped
Dec 24, 2009 | Mtd 22" White Outdoor Self Propelled High...
13.5 OHV B&S won't stay running, blows gas out carb.
Sounds like you have a blown valve. I'm assuming this is a 4 stroke motor, if it was 2 stroke then it would be the reed valves. But either way it's the valves.... unfortunately that will require a mechanic :(
Jul 19, 2009 | Parks Optical 13.5hp Briggs And Stratton...
We just bought a Troy Bilt 6.75 self propelled mower. I have not used it yet myself, my husband has. He is out of town and I am having trouble starting. It does not have a primer or choke. Is there...
Read the manual for starting procedures, if you are following the stated procedures and the mower will not start then contact Lowes and explain the issue.
Depending on the store they may offer to have you bring it in so that they can see what may be the issue, if they are not interested in offering some customer service after purchase they will give you a 1-800-TUF-LUCK number to find a servicing dealer. A brand new mower should not be difficult to start even for those with short arms. I have the same mower except non propelled and it has been the best starting mower I've ever owned for the five years since purchase. I have always found it best to deal with a local hardware store or dealer when purchasing items such as chain saws, mowers or other outdoor power equipment, I pay a few more dollars (and I do mean a few) but the direct customer service is well worth every extra penny!
May 12, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Changing batteries in black and decker cordless lawnmower
You can find parts information and exploded views for your mower here. You'll need to pick the series mower you have from the list. The service site's home page is here. At the bottom of the center pane is box where you can enter your model number to find the manual. With the views they give, you should be able to get the mower apart to replace the batteries yourself. Good luck on the project!
Apr 17, 2009 | Black & Decker Garden
Mower Dies after choke Releases
Hi, check that your carberter has not got the pipe from it to the engine either cut or loose as it seems that your engine is getting to much air.
May just be the hose clip around the intake tube a little loose.
If this is not the problem check with the seller whom you bought it off as the carb may need reset.
Nov 17, 2008 | Craftsman Woodstock Percussion Crcbm ...
Garden Logo
209 people viewed this question
Top Garden Experts
EugenesDIYDen
EugenesDIYDen
Dennis Key
Dennis Key
john h
