Question about LG LHY-518 System
Home surround system
Hi when playing a dvd i can here all the trailers and then when the movie starts i can here everything what is going on in the background but not the main characters on the lcd screen it says CHPTRK this has only come on in the last few days and i dont know what it means or how to get rid of it hope you can help it is a LGDVD RECIEVER LH-T550 THANK YOU
  • 4 more comments
  • Niki_01 Jul 16, 2008
    Hi, I have a problem with sound on LG DVD model LH-W551. It has appeared CHPTRK there. It is definatelly contain with 5-channel movie.In taht case, I can not hear vois of person. Please, could you help me, how to correct it?Thank you very much!
  • Anonymous Jul 24, 2008
    Hi I have the same problem with an LG HT502 home cinema and it occured after a cut in the electricity. The service said it might be a software problem, I am trying to find out more at the moment.
  • Anonymous Oct 31, 2008
    Got now CHPTRK on a LH-T755TB. When I play a music CD the sound volume slowly goes down (as if SLEEP was activated, which isn't) to MIN.
    Any idea how to get rid off it?
  • Anonymous Nov 27, 2008
    Hi
    Iam having exactly the same problem as juicy jade is there a solution or will i have to buy a new one
    Iain
  • iainab Nov 27, 2008
    Hi
    I am having exactly the same problem as juicy jade
    Can it be fixed
    Iain
  • Anonymous May 12, 2009
    i have lg ht502 and when playing a dvd i can hear everything but the voice and i have tried everything i can think of but nothing works! does anybody know what the scoop is with this **** cos its getting abit over the top having to replace a unit for a stupid little problem!
    thanx in advance.... i hope anybody can help me
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 41 Answers
Do a master reset of the system.
Posted on Oct 28, 2017
SOURCE:
  • 105 Answers
SOURCE: LG LH-D6230
The life of LG optical pick-up is Aprox.1000hours if it is more then 1000 hours used then just replace optical pick-up.
Posted on Feb 07, 2007
SOURCE: Lg LH-D6230. How to hook up? PLEASE HELP! NO INSTRUCTION MANUAL!!
je kan met 2 tulp aansluitingen via de dvd speler audio out naar je tv gaan en dan de instelling aux van de dvd speler gebruiken zo kan je surround tv kijken
Posted on Aug 18, 2008
  • 120 Answers
SOURCE: Sound to mute
i would suggest turning off the system, disconneting it from the outlet and plugging it back in, the should reset the settings, please post with what you try to do.
Thanks and i look forward to your post.
Posted on Nov 13, 2008
SOURCE: resetting the progressive scan mode on an LG lh-d2645 home theatre system
the above is correct but you need to have the dvd player on with no disc in so "no disk" is shown on the front display. then hold down the stop button for 5 secs to reset the display mode back.
Posted on Jan 02, 2009
ruwidperd372
  • 279 Answers
SOURCE: Every dvd we play starts freezing sometimes not
Try to clean the optical lens with CD Cleaner kit first. It's a CD with tiny soft brush on it
Posted on May 05, 2010
Do I need a remote control to control the Philips magnavox model DVD 815AT. It plays the commercials on the video disc. When it comes to playing the movie, it keeps repeating itself and it won't go...
Usually most DVD's play movie trailers and sometimes advertisement before the movie will play. Once the ads or trailers are done it should go to the menu screen and at that point "play" or something like that should be underlined. If it is you can press play or select on the DVD player then the movie should start : )
Jul 27, 2011 | Philips DVD815AT DVD Player
My home theatre was connected successfully playing the cd movie, but after turning off the dvd and go back to watching tv the sorroung system speakers do not give a sound to the television. is it that i...
hi,
select tv input on ur theater system. u can hear audio fro the frond left and right speakers. if u want to hear the audio from the surround speakers, then press the A-MODE button on ur remote to select different type of sound modes. press again and again to select different sound field. select one which suits u.
ok
Dec 27, 2010 | Curtis DVD5091 Theater System
Nexxtech ESDVD100 DVD player gone bad, how to replace?
You can try cleaning it with a dvd disk cleaner first. If that dont work by a cheap dvd player and run it to the inputs on the back of the surround player.
May 24, 2010 | NexxTech ESDVD100 System
Surround sound hok up
try using a HD plug in cable that should solve ur problem
Mar 01, 2009 | Hitachi 55HDM71 55 in. HD-Ready Plasma...
How do I get my tv to play through the surround sound
If you have direct cable into the television, you will need to use an audio output if available on the back of your set into your HT system.
If you are using cable w/ a cable box you have two options. You can still connect everything directly into the TV then reroute the audio to the HT system... or, you could hook only video to the TV and audio from the cable box to the HT system. Really up to you.
Mar 04, 2008 | Panasonic SC-HT680 System
Dvd player is locked
Ideas
1/ Turn power off for a while at powerpoint for as long as you want 5mins should be fine then turn on and try again.(which youve probably done already) as well as looking up your model number on the net to attain a info on your system.
Does the remote still work if so try to find unlock in menu/setting/functions but if it requires a digit code then youll need the manual as it could have an override built for cases such as yours.
start at jvc.com/dvd5.1 surround and find your model
good luck
Clapster
Jan 28, 2008 | JVC FS-S77 Micro 5 Disc DVD Audio/Video...
SANSUI 5.1 HOME THEATER SYSTEM WITH TWO 8
Sounds like it is in the dvd player. Does it loose power completely? Let me know. Thank you Guru Jay
Jan 24, 2008 | Audio Players & Recorders
Not playing voice but playing music/surround
sounds like you may have a dodgy scart lead.check that none of the pins are loose/damaged. Also check the sound settings on the tv, it may have reset itself to the default sound setting. Or it might just be the audio settings on your dvd player have been adjusted,almost all dvd movies have there own audio adjustments.
Jan 13, 2008 | Audio Players & Recorders
Movie freezes, skips.
Does sound like the laser. Realitically, not worth repairing. I'd say you'd be worth connecting a cheap DVD player to the system - then the Sony can carry on providing the surround sound audio and the new DVD player can provide the video. Then, if the cheap DVD player is still going, it can move to a bedroom TV if and when you replace the surround system....
Otherwise, I would imaging the speaker set (and even the non-working DVD player) on its own might fetch a reasonable price on an auction site - anyone who has a stolen DVD unit will probably be desparate for the speakers as Sony don't sell them separately!
Jan 04, 2008 | Sony DAV-S500 System
LG LHY-518 System Logo
352 people viewed this question
Top LG Audio Players & Recorders Experts
Marvin
Marvin
patseamur
Level 1 Expert
PNiss
Are you a LG Audio Player and Recorder Expert? Answer questions, earn points and help others
