Question about KitchenAid "KHHC2090sss Microwave Hood Combination / 30"""
Service manual for khhc2090sss
Need service manual for the KitchenAid KHHC2090SSS. My microwave won't work at all and the fuse is fine.
2 Suggested Answers
MicrowaveSvc
  • 9047 Answers
SOURCE: I need a Kitchenaid Microwave service manual for model KHHC2090SSS
You can find helpful exploded view diagrams and order parts by entering your full model number here.
This model is inverter-based, so it does not use the larger, exposed capacitor that transformer-based models do. It uses one or more small capacitors hidden on the inverter board.
As long as the high voltage section was not energized within about a half-hour of disassembly, and one does not contact the high voltage connections, there's really no need to discharge high voltage capacitors.
They have built-in bleeder resistors that bleed off the charge in seconds. But there is that one in a zillion chance the resistor inside is defective, etc.
The shock from stored DC high voltage isn't what hurts you. What hurts is getting sliced up by the sharp metal chassis when you reflexively pull back your hand after the shock.
I'm also curious as to what problem you're troubleshooting.
We're
happy to help you with free advice and we'd appreciate your thoughtful rating of our answer.
Posted on Dec 18, 2011
Testimonial: "Expert help with great details about the project I am attempting. Even answered questions that I should have asked, but did not know enough to ask."
Our microwave does not consistently come on. When we put in the time to cook it tells us to open/close door. If the cavity light comes on then it works, if not it doesn't work. Please HELP! Thank you
Sounds like you have one or more faulty micro-switches for the door. They are not expensive to get, but your service center will likely charge you a lot to fix it. If you are handy, you can pull the case off and replace them yourself.
Oct 18, 2016 | KitchenAid "KHHC2090sss Microwave Hood...
KItchenAid microwave KHMS1850S: interlock switches replaced, but fuse keeps blowing
http://kitchen.manualsonline.com/manuals/mfg/kitchenaid/khms1850s.html
Jan 27, 2015 | KitchenAid Microwave Ovens
Kitchenaid microwave open door switch does not work
on my microwave, the door sticks some times & I put my fingers under door on latch side & push up, & I can hear it release & open. other than that there may be a broken part. follow the link below.
KitchenAid Microwave Door Won Open
Jan 23, 2015 | KitchenAid Microwave Ovens
Microwave won't heat for first minute - starts working normally after that.
The magnetron may be defective. You can replace the magnetron, there is no other possibility.
Jan 16, 2013 | KitchenAid KHMC1857WSS Microwave Oven
Sharp microwave & convection & turn table on model R1874F won't work
That would be just a defective secondary interlock (bottom door switch) or its mount.
My help file on door switches is here.
The service manuals you need are here and here.
You can get other Sharp parts from Encompass here or you can call them toll-free at 866-779-5835.
Jan 07, 2013 | Microwave Ovens
Won't power on
I would first check the outlet "under load" to be sure it works. A quick & easy way is to use a toaster or hair dryer.
If the outlet is good, then it may be the microwave's fuse or the oven thermostat.
The service manual is here. It also has instructions for removing the oven from the wall, which you will need to do to check / replace the oven thermostat.
You can order parts from the Sears Parts Direct Web site.
Dec 01, 2012 | Microwave Ovens
Door open button won't work on KitchenAid microwave model YKCMS135H
Page 3 of the exploded view here shows the door open parts 24510L and 250201 (or 23551B if your full model number is YKCMS135HSS).
What look like part numbers seem to be reference numbers.
For further help you will need to contact Kitchenaid Canada here.
Sep 05, 2012 | KitchenAid KCMS1555RSS Stainless Steel...
KitchenAid Microwave KHHC2090
Remove the relay case and gently file the points until clean with a miniture file set from Radio Shack, and spray the points with electronic cleaning spray also available from the same location, try this if new relay won't work.
Aug 01, 2012 | KitchenAid Architect Series II KHHC2090S...
We're
Dec 13, 2011 | KitchenAid Microwave Ovens
I need owner manual for kitchenaid kesc308lsso
You can download Whirlpool / Kitchenaid owner's manuals and installation instructions here.
Oct 07, 2011 | KitchenAid KHMS155L Microwave Oven
KitchenAid "KHHC2090sss Microwave Hood Combination / 30""" Logo
79 people viewed this question
Top KitchenAid Microwave Ovens Experts
William Miller
William Miller
Stu Ungar
Darial Jr Lasaria
Darial Jr Lasaria
Are you a KitchenAid Microwave Oven Expert? Answer questions, earn points and help others
