Question about Garden
John deere sabre ignition switch - Garden
SOURCE: john deere lt120 , 2004
my zero turn z5426 keeps moving on the left side even when its engaged in neutral
Posted on Nov 05, 2008
  • 133 Answers
SOURCE: John Deere Sabre 14.5/38 HYDR lawn tractorWont't
See if there is a plastic connector on the wires leading to the seat switch. If there is try disconnecting it and use a piece of wire (with insulation on it) to use a jumper. There is probably two wires coming from the tractor to the seat. After disconnecting Place one end of wire into the wire connector coming tractor and the other end of wire in the same connector on the other side. That will act like the seat switch is closed like you are setting on it. Try and start. Had the same problem on an electric hyster at work and that was the fix we used because the switch is pretty expensive and a hassle to change.
Hope this helps
roundo4
Posted on Aug 04, 2009
  • 133 Answers
SOURCE: I have a john deere sabre 15.5/42 and cant figure
Remember to always put the V side of belt (inside of belt) into the pulleys and put the flat side of belt (outside of belt) up against the idler pulley (the one that moves to make belt tight to engage blades) Make sure you have the right belt and follow those guidelines and the belt should go right on. If you happen to have alot of slack then you have to figure out a different routing around the idler. Make sure the blades are NOT engaged. When on properly the belt will be snug.
Let me know if this helps.
roundo4
Posted on Aug 29, 2009
bargainbin2
  • 123 Answers
SOURCE: need a diagram on how to put a drive belt back on
It is a hard one to put on co look at the picture carefully there are two pulleys one that one side of the deck that are trickey.
Posted on Sep 01, 2009
nova2nv
  • 197 Answers
SOURCE: John Deere 425 AWS no start, no nothing???
If engine cranks over and have no spark try a time delay module located under thermostat housing.
Posted on Nov 13, 2009
What kind of oil is used in a sabre hydrostatic transmission
John Deere transmission fluid recommendations
For Sabre? and Scotts? garden tractors and commercial mowers
This bulletin serves to clarify the transmission fluid service requirements for several models of lawn and garden product and commercial mowing equipment that were recently introduced. The operator's manuals for these products call for 20W50 synthetic oil, which is not carried in the John Deere parts system.
The following chart has been developed from the factory and engineering as approved replacements for 20W50 in each application, and should supplement the information previously published. Transmission fluid recommendations Machine Model Recommended oil for service requirements Sabre
2048HV
2148HV
2254HV
2354HV
2554HV
Plus-50®, 0W-40
or -John Deere Hy-Gard®
(bothoils are for top-off only) Sabre All other models Turf-Gard? 10W30
- or -
Torq-Gard Supreme?, 5W30 Scotts S2554 Plus-50®, 0W-40 Synthetic
- or -John Deere Hy-Gard®
(both oils are for top-off only) Scotts All other models Turf-Gard? 10W30
- or -
Torq-Gard Supreme?, 5W30 Mid-Ztrak
Mini-Z M653 through M665
737/757
717/727 Plus-50® II, 15W-40
Plus-50®, 0W-40 Synthetic Front-Ztrak F620
F680/F687 Plus-4?, 10W40
- or -
Plus-50® II, 15W-40 QuikTraks 647/657/667 Plus-50®, 0W-40 Synthetic Last modified: 23Jan10.
Apr 03, 2017 | Garden
John Deere sabre runs for a while then sputters to a halt. Won't restart until it cools down
check coil , ignition control module
This is an indication of component over heating and breaking down.
splutters as the circuit becomes unstable and eventual failure and refusal to start until cool
Jul 07, 2016 | John Deere Garden
When I turn my john deere sabre off at the key the engine shuts down, however ten seconds later the fuse blows. Also brand new safety switches are killing engine when released. Suggestions?
Somewhere, probably in the ignition switch circuit there is a short circuit - otherwise the fuse would not blow. You'll need to take a test meter to each circuit in turn to isolate the circuit and then find the short. Be logical and patient!
Apr 29, 2015 | John Deere Garden
John deere sabre 17 hs
sounds like the safety switches have been by-passed
not shutting off at switch may be the switch
Nov 19, 2013 | Garden
Do you know if I can put a motor off of a John Deere GX 85 onto my John Deere Sabre
as long as the lenth and diamather of the crank shaft are the same
Oct 25, 2012 | John Deere Garden
Sabre lawn tractor 1438 gear manual
John Deere Sabre 1438, 1542, 1642, 1646 Lawn Tractor Service Technical Manual TM-GX10238 * - Download Documents / eBooks
hello arthur, john deere does not post manuals on line,this is all i could find or see your local dealer,hope this helps..
Feb 18, 2012 | John Deere Garden
Garden Logo
71 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
