Question about Mitsubishi VS-60703 60" Rear Projection Television
My tv wont switch inputs - Mitsubishi VS-60703 60" Rear Projection Television
Mitsubishi tv WD-73640 wont turn on. 4 red light then 8 yellow lights
Hi, if you power your TV on and see a black or grey screen, it may be on the incorrect input. Inputs get changed when switching the TV input for dvds or video game consoles. Look for a Source or TV Video button on your TV remote, not the cable remote. Before doing this, please make sure all connections are secure. I hope this helps or reply with more questions.
Jul 26, 2016 | Mitsubishi WD Televison & Video
Soyo tv won't change between inputs
The main board is having an issue thats why the inputs wont switch.
Apr 05, 2013 | Soyo 26 in. LCD TV
My tv wont turn on , power is there but screen wont come on ?
Try changing the input device to something you are sure works. Switch off TV manually, switch off power, remove plug and retry after 48 hours. If problem persists, please refer it to a qualified service technician.
Jul 25, 2012 | Televison & Video
Mitsubishi CS-35301 35 in. rear projection. can't switch inputs
if you have s video connected some tvs wont allow you to use input 1 or 2.disconnect s video cable and try that other wise you got something wrong.
Apr 25, 2010 | Mitsubishi CS-35305 TV
My dish 322 receiver wont work 2 tv,to get service
  • There are two satellite inputs on the back of a 322. There may be a single cable going to a splitter connected to these two ports or two individual cables.
  • If there are two cables swap them, if you still get signal on the same input only then the receivers input is dead.Otherwise follow the bad cable and ensure it is not damaged or disconnected. Swap the location on the other end and see if the issue stays on the same cable. If so replace the cable, if not replace the LNB or Switch.
  • If there is a splitter bypass it and connect the single cable directly to the input that does not work. If there is no signal the port is bad, replace the receiver. If there is signal then reconnect the splitter, press menu 6-1-1, check switch, and then test. Allow the test to finish. If the two inputs do not match replace the splitter... Its called a DP Seperator
Jan 24, 2010 | DISH Network 322 DTV Receiver
My audio input works fine but for some reason my video input wont work when i plug anything into it
You may have a broken solder connection at the video input jack that is if you are sure the TV is switched to the correct input. Make sure the label on the input you are using matches to the display on the TV. Thanks for using fixya.
Dec 07, 2009 | Philips Televison & Video
How to make tosiba tv show the movie that is playing on a tosiba
You may need to manually switch the input on your tv via the menu on the front panel switches if your universal remote does not have an input button or it just wont respond.
Aug 25, 2009 | Toshiba 27AF43 27" TV
The game wont go on my tv
Chances are you are not on the correct input on the TV. Look for a button on your TV remote that says "input" or "source" and try switching the inputs while the TV is on. If you don't have a button similar to this try going to channel 3, and going down in channels, sometimes inputs are "below" the lowest channels.
Jun 05, 2009 | Microsoft Xbox 360 Elite Console
I cant change my TV from Input to output...
Quick fix - Should be an "Input" button on the TV itself that can be used to switch between inputs. Depending on model of TV, this may also be done by going to channel 3 then going down to see if it cycles through inputs.
Other than that, may want to try another universal remote that has a "TV Input" button on it.
Mar 19, 2009 | Sanyo DS31590 31" TV
Televison & Video Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
