Question about Splendide Washing Machines
Instruction manual for a splendide washer dryer combo, model#WDC1026
  • 3 Answers
SOURCE: Broken door handle on Splendid 2100 RV Washer/Dryer Combo
The Splendide distributor in OR sells handles for about $45.
Posted on Jan 28, 2009
SOURCE: need operating instructions for supra washer/dryer
I can forward you the PDF manual for this unit. There doesn't seem to be a way to post the file here.
Posted on Jun 07, 2009
SOURCE: splendide 2100 washer/dryer now fails to dry -
Remove the top - two screws in the back then slide forward
In the front right top you will see the air box and the terminals for the heater coil along with other wires and sensors. Start the washer on a dry cycle and check the voltage to the heater terminals. You will be looking for 120 AC. If voltage there but no heat the heating element is bad. If no voltage there follow the wires to the overheat switches and check the voltage on the other side of these switches (round devices with two terminals on top). If there is voltage there then the switch has tripped. Unplug the machine. Look for a spot of paint on this switch, scratch it away and you will see a small hole. Insert a strightened paper clip into this hole and push to reset the switch. Re-power and test the results.
No power to these switches probably means a bad circuit board $$$.
Posted on Dec 21, 2009
SOURCE: Need Manual for Frigidaire Gallery Heavy Duty Washer/Dryer Combo Model #FLSG72GCS0
my washer make a loud sound when spinning
Posted on Feb 11, 2010
blueextc3221
  • 15935 Answers
SOURCE: Kenmore 98702 Stacked Washer/Dryer Combo Model 417.98702890
There is an EXTERNAL fuse on the back of the unit.
Service manual is inside the machine's shell in plastic.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 10, 2010
I need a door handle for a Splendide Combo washer/dryer. %036552563
I may be able to help as I just removed a washer from a motorhome -- in pieces-- contact me if you'd like Dwight 209-531-6943. - Presently in Calif.
Feb 25, 2015 | Splendide 2000S Front Load Washer / Dryer
I just moved into a home with a Hirundo wdc1026 model washer dryer combo and I have not the first clue of how to operate it. Someone please help!
Never heard of them in Australia. All I can suggest is try the Internet or maybe a local Retailer who sells them may be able to assist with who makes them or where they come from.
Feb 03, 2015 | Washing Machines
Wd2000 washer dryer combo timer advances around timer
If the program selector knob keeps turning, the machine needs to be reset.
Wait a few minutes for the drain pump to empty the tub, switch the washer-dryer OFF. Select one
of the Reset positions on the knob, then switch it back ON.
The link below will take you to the manual.
Hopes this helps.
http://www.splendide.com/manual_wd2100_2000s.pdf
Oct 12, 2014 | Splendide 2100 Vented Washer-Dryer
Can i use a cheaper alternate control board for my Splendide 2000S Washer Dryer Combo?
to do what you are saying is to remove controler and by pass every thing with individual switches would work in a fashion but is not feasable best dump it now or repair propely for safety reasons remember a life is worth more than any money when playing with electric and water repair or get new dont take chances a family menber is is loved and would be missed
Aug 14, 2012 | Splendide 2000S Vented Washer/Dryer
I need a wiring diagram for a Splendide Washer-Dryer machine, model WD2000 S. Someone can help ?
Just finished fixing mine. Found a broken wire at one of the high temp limits. Found tech service manual at Splendide,.com/service/TECHMANXC. It's a pdf file that will walk you through any repair.
Nov 03, 2010 | Splendide 2100 Vented Washer-Dryer
My motor yacht's Splendide Washer Dryer combo has nerver dryed the clothes
Thor Appliances - www.thorappliances.com - and LG both have machines that can replace the Splendide.
Aug 04, 2010 | Splendide Comb-O-matic 6200 Non-Vented...
Need operating manual for Bendix WDC1025 Washer dryer combonation
This is the same machine or nearly identical machine as the Splendide Comb-o-matic 6100, for which you can find the manual here:
http://splendide.com/request_manual.htm
Mar 31, 2009 | Dryers
Jan 27, 2009 | Splendide 2100 Vented Washer-Dryer
WDB1043M Bendix Washer/Dryer
I had the same problem. Then I discovered that the Bendix USA WDS1043 / WDC1024 is the same, or almost the same, as a Splendide Comb-o-matic 6000. You can find an extensive parts manual at
http://www.splendide.com/service/Combo_PartsBreakDown.pdf
and an owners manual at http://www.splendide.com/manual_wdc1024m.pdf
I think Splendide is still in business, in which case they may also be able to supply parts for the Bendix WDS 1043 M - check them out at
They can also supply a replacement washer/dryer combo when your present unit finally dies.
Good luck with a great washer combo!
Colin
Jul 28, 2008 | Tricity Bendix WDR1040W Front Load Washer...
Washing Machines Logo
119 people viewed this question
Top Splendide Washing Machines Experts
Philip Diggins
Level 1 Expert
Are you a Splendide Washing Machine Expert? Answer questions, earn points and help others
