Question about Electrical Supplies
I HAVE HOBART SERIES R CHARGER THE "ABNORMAL SHUTDOWN" LIGHT NOW IS BLINKING AND IT IS NOT CHARGING THE FORKLIFT WHAT COULD BE THE REASON
SOURCE: Mouse blinks red even when it's placed in the charger
http://www.fixya.com/support/t244267-laser_mouse_mx_1000_logitech
Posted on Sep 15, 2008
  • 5 Answers
SOURCE: ny hp530 is having a charging problem. if i put
this is the problem of adopter . replace from the service center
Posted on Jun 17, 2009
craxtech
  • 33 Answers
SOURCE: I have a Casio Exilim EX-Z75 digital camera and
Try replacing the battery, it seems a battery issue
Posted on Jul 25, 2009
  • 12 Answers
SOURCE: abnormal shutdown
Ok, we are presenting a corrupted window and you reformat your Pc.
Back up you software and any other applicaiton.
1 Put you windows disk in and just after the logo appear depress f9 and answer yes to boot from cd. Follow the onscreen instructions to format hard disk and install windows/
Posted on Jul 26, 2009
jonsnell4
  • 22812 Answers
SOURCE: My 5312 series retro lantern charging light won't come on when plugged into charger.Also charger not charging
What make of laptop is this?
Posted on Mar 12, 2016
Charger seems to have both red and green lites flashing at the same time no sequence and both batteries connected read 4.0 VDC, are these chargers repariable or throw aways
Your manual is here. The section on charging states, that green blinking means your battery is fully charged but blinking red means that your charger is faulty. I would say repairable.
1. Plug the female connector of the AC power cord (supplied) to the AC receptacle on the charger and plug in the male connector on the AC power cord into the wall outlet.
2. The On/Off LED indicator is blinking RED, this is abnormal. Unplug AC power cord from the on-board battery charger and wall outlet. Charger may need to be replaced. Contact an Invacare dealer or qualified technician.
3. When the On/Off LED indicator light is Off, charger is Off.
4. When the Charge LED indicator light is YELLOW, the batteries are charging.
5. When the Charge LED indicator light is solid GREEN, the batteries are fully charged (as their condition will allow).
6. When charging is complete, unplug the male connector of the AC power cord from the wall outlet and then unplug the female connector of the AC power cord from the AC receptacle on the charger.
http://www.invacare.com/doc_files/1125085.pdf
Mar 24, 2016 | Invacare Pronto M51 Power Wheelchair
Charger will not charge radio, has red blinking light
If the radio will charge on one charger and not the other, the one with the blinking light is bad or has a dirty or defective battery contact. Check your charger for debris and clean your battery contacts with a pencil eraser and try charging again. If this fails, replace your charger.
Best regards.
Jan 31, 2014 | Kenwood KSC-37 Replacement Charger for...
Iam using Energizer 15min charger. I have used for a longer time. Now the charger red light blinks while trying to re-charge batteries. I have tried various batteries but red light blinks. Failed to charge...
A flashing light indicates that the charger seems to detect a problem with the cells. (two or more cells form a battery). Since you've tried other cells, it can be reasonably assumed that the charger is faulty and should be replaced.
Feb 14, 2011 | Energizer 15 Minute Battery Charger Combo...
12v 1.5amp fully auto, alwyas worked, hook up to battery 12v 8.5amph, alwys red light flashed, went solid while charging, then off, or flashed, and off cause was already fully charged. now red light just...
I really don't have any idea as to what you're talking about here other than a battery and maybe a charger. Seems as if you're saying that you have a 12 volt 1.5 amp automatic battery charger connected to a 12 volt, 8.5amph battery but the red light on your charger is blinking. The blinking red light indicates that the charger is not seeing a proper connection such as crossed polarity connection or simply a poor connection. You say that the battery voltage has dropped from 12.5 volts to 9.1 volts with the charger connected. If this is the case, the battery is badly discharged and the charger is not charging the battery for some reason. The charger may be bad but check the connections to make certain they are correct and good. If they are, I'd replace the charger.
Good luck
Steve
Aug 10, 2010 | Harley Davidson FXR Super Glide...
Hobart battery charger
model # 750H3-18 hobart charger gets a abonormal shut down light after overnight charge on different machines.
Feb 11, 2010 | Hobart 24 in. LXIC-5 Built-in Dishwasher
I have connected a heavy duty charger (3 phase elec) to our forklift and it will not charge but is flashing a fault error number 64 but only the 6 is flashing how can I tell what this mean or where can I...
check on the door panel inside the charger there should be wiring and code diagram,if not you should be able to contact the charger manufacturer listed on the charger
Oct 14, 2009 | RTO Forklift and Pallet Construction...
Wont charge
There are 2 possible reasons. Charger is incompatible/defective or Battery is no longer charging due to its 500 cycles life. You may check the output of the charger with Voltmeter/Multimeter if its stable 5V, If its stable then best thing to replace the battery.
Good Luck
Jun 11, 2009 | Kyocera Finecam SL300R Digital Camera
Blinking battery light
Green is charged, Orange is Charging and Red indicates a low charge or a possible weak or defective battery. All modern batteries are controlled by a microprocessor that monitors the health of the cells. Even if the battery is holding a workable charge, it can still be deemed "bad"
If the battery is fairly new you might get a replacement from Dell, if its a year or more old, it could be dying an early but not abnormal death. If more than 1.5 years old, be sure to check the Dell battery recall list as some of these are recalled and you'll get a free battery replacement if its on the list!
-Good luck
Jan 05, 2009 | Dell Inspiron 9300 Notebook
Electrical Supplies Logo
80 people viewed this question
Top Electrical Supplies Experts
ken skalski
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
