My Sharp AF-S85FX Comfort Touch Air conditioner is shutting itself of and displayinf the following: E1 I reset it from the reset button on the electricel cable. It stayed on for a while then shut itself of.
An E1 error is automatically generated after the AC runs for so many hours to remind you to clean the filter. The manual says to clean filter and unplug unit, then plug unit back in and code will be reset.
Ok...so I posted "this solution doesn't work" about 30 minutes ago. I found this answer online. This one worked!! Very poor writing in the instuction manual I guess! Their solution was not even close! "Sharp window A/C - Every thirty days the AFX 12,000 BTU unit is set to turn off automatically and display an E! error to remind you to clean the air filter. To restart, unplug the unit. Hold down the power button and plug in. Wait for the beep and then unplug. Plug in again and the unit should restart. If there is is no beep there may be a mechanical problem."
E1-Automatic filter clean
reminder.
Turn the air conditioner OFF and
unplug it. NOTE: The air conditioner must be unplugged for the automatic
filter clean timer to reset.
Clean the filter. See the Care and Cleaning section in your use&care manual. After cleaning, replace the filter and plug the air conditioner back in.
Display Codes:
reminder.
