Question about Refrigerators
Roper rs22cfxtq remove drip tray - Refrigerators
2 Suggested Answers
  • 323 Answers
SOURCE: Fridge drip tray removal
remove toe kick on bottom of fridge, should be some screws on both sides. tray slides out, maybe not all the way dont force, there is a float mechanism that will stop it from coming out all the way, use some paper towels or rags to soak up the stagnant water, this pan should have a heater hooked up to it to evaporate the water, the installer should have hooked this up on installation, they dont hook it up at the factory to get a better EER out the factory door, just trace back to the pan and hook up any unplugged wires going to it, good luck
Posted on Oct 31, 2009
Model# kfcs22evms8 kitchen aid fridge- how to clean drip tray? Can't get at it.
Clean Refrigerator Drip Pan, Clean Walls - YouTube
? 2:55
https://www.youtube.com/watch?v=I9YP0iH_zho
Aug 5, 2008 - Uploaded by Handyman Matters
Scheduled Home Maintenance: clean refrigerator drip pan and wipe ... leaking,Kenmore,Sears,Whirlpool,KitchenAid,Roper,10677292790 ...
How to Find the Drip Pan on Refrigerator ' Home Guides ...
homeguides.sfgate.com > Real Estate Rentals & Leases > Get out of Leases
The drip pan on your refrigerator is a receptacle that catches condensation flowing from ... Occasionally you may need to get to the drip pan to clean it, remove a ...
KitchenAid refrigerator drip pan Questions & Answ
Dec 16, 2015 | Refrigerators
How do i get to and remove the drip tray on my liebherr KIU 1640 fridge?
Should be in the back at very bottom of refrigerator, remove back panel to access the tray....
Feb 27, 2015 | Liebherr KIU 1640 Premium Compact...
Trouble shooting kirkland refrigerator
If it does not have an ice maker the drain hose that goes from almost the top to the bottom tray is clogged up clear the hose If you can remove the top of the drain hose you should be able to blow the clog out. Then replace hose on the top drip tray.
Dec 31, 2012 | Roper Refrigerators
Roper RS25AGXNQ00 icemaker leaking. It's not the tray, could it be solenoid bad?
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze blocking the fill tube.. You can take the water line off the valve and watch to see if it drips.
Jul 20, 2011 | Refrigerators
Water dripping from freezer into refrigerator
Just fixed my refrigerator last week that was doing the same thing. Water was dripping from the back top of the refrigerator and it was the drainage line in the freezer had frozen up and was plugged. Emptied the freezer and removed the bottom panel from the freezer and found large layer of ice. Turned freezer off and let everything melt. Then the hole in the back bottom of the freezer on the metal tray became visable. Contined to thaw until warm water would drain into the tray under the freezer. Was not hard at all and much better not cleaning up the water dripping all the time.
Jun 07, 2010 | Roper RT21AKXKQ Top Freezer Refrigerator
Roper Dishwasher leaks from float or float switch onto floor
you could be usiong way to mauch soap try filling only one of the soap trays or even try doing one wash without any soap at all
this unit tends to do this if you have to much soap in the unit left over from the last load...
beyond that your machine is proibaly tilted to far forward you can lift it, by lowering the front legs begind the toekick
Oct 25, 2009 | Roper 24 in. RUD4000M Built-in Dishwasher
Freezer leaks into refrigerator
The most likely cause for this is the defrost condensate collector tray below the evaporator is frozen over and the back panel in the back of freezer will need to be removed after disconnecting the power. Then defrost the tray and pour warm water with a mixture of Clorox in the drain to make sure the water drains to the pan below the refrigerator that is near the compressor. If you continue to have problems I will send links that may be more helpful for this problem. Sea Breeze
Jul 24, 2009 | GE Hotpoint® HTS18GBS Top Freezer...
Strong odour coming from non-removable tray under new fridge
do not frustrated .firsly you should look for any THING THAT block the drip tray from geting out. usually it can be pulled out by PUSH ASIDE THE DRIP HOST SOMTIMES BLOCKING THE DRIP TRAY MOVEMENT IN OR OUT.
LATER CLEANED THE DRIP TRAY & REINSERT IT BACK TO ORIGINAL SITE
Sep 24, 2017 | Kenmore 44273 Side by Side Refrigerator
Roper Ice maker wont kick ice cubes out of tray.
Remove white plastic cover on ice maker. On bottom you will notice the heater connections, check for voltage. If good, heater is most likely bad.
Apr 16, 2009 | Roper RS22AQXKQ Side by Side Refrigerator
Freezer ice
If the freezer is on top then empty out the freezer and remove the bottom and back liner of the freezer compartment usually phillips screws. In the back you will see the freezer coils along with a defrost element. Below these two items u will see a drip tray that collects water from the coils on defrost cycle, in the center of the pan will be a drain hole that connects to a hose that leads to a pan under the refrigerator.Normally the water is collected there and evaporated. The hole in the tray in the freezer is clogged. Thaw it and clean it until you can pour water in it and it goes to the pan down below. please rate me
Jan 08, 2009 | Roper RS22AQXKQ Side by Side Refrigerator
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
