Question about Dishwashers
I have an H62 Hobart commercial dishwasher. I had it on fill to start it up. There was a loud pop while it was filling and now it has stopped. The power light is still on but the dishwasher will no longer fill. Where should I start looking for the problem. Would it be a fuse that popped?
  • 236 Answers
SOURCE: dishwasher filling up then stopping
is it going into the wash or just filling and thats it? if it fills and does nothing straight after it is probably the wash motor is jammed or seized. if the d/w starts to wash then stops it may be the heater is faulty.
Posted on Feb 16, 2008
  • 112 Answers
SOURCE: Dish washer over filling?
The first thing you should do is clean the level probes in the unit. There are two probes sticking through the back of the unit and the water completes a circuit between these two telling the machine when it is full. If they are clean, you may have a faulty sensor or wiring.
Posted on Oct 18, 2008
subarufamily
  • 6 Answers
SOURCE: dishwasher fills cycle runs for a few seconds and then it stops and motor growls
Check for a deformed shaft on the water level float. Remove the kick plate and look for where the shaft of the float touches a micro switch. Often the shaft is bent sideways and only engaging the micro switch indirectly. Straighten by hand for a temporary fix or reinforce the shaft with aluminum tape and sewing needle. Keep the retrofit light weight to avoid problems with water overflow.
Its also possible you may have debris clogging the check valve that keeps water in the tub during certain cycles. To find the checl valve you'll need to remove the lower rack and completely disassemble the central assembly from the top down. If you are mechanicaly inclined its not hard. If you are worried about proper re-assembly, then video tape the disassembly as a memory aid and stack the parts and screws in careful succession.
Once you reach the steel garburator blade you only have one more plastic plate to remove. Examine both ports on the plate to ensure that there is no jam or debris. Throughout the disassembly, look for any broken glass or debris that could be jamming or clogging.
If neither of the above problems is found then the other possibility is a deflective or melted down circuit board. Check your owner's manual for longer warrantees on the control panel. A long time ago they use to have 3 - 5 year warranty. More recently the warrantees have been only for one year. Check your owner’s manual because if you ask the call centre they will always say one year even if the warrantee is longer. If the part is covered then disassemble the door to get at the control panel. Look for signs of melting/overheating. If the unit is out of warrantee then replace the dishwasher. The control panels cost as much as the dishwasher. Replace your Maytag with a quality brand like Miele. Avoid, Maytag, Jennair, Kitchen Aid, Whirlpool, Kenmore, White Westinghouse. They are all made by the same umbrella company with the same crappy parts, poor reliability, poor cleaning results and short term warrantees.
Use to be you could get 10 – 20 years of service from a North American brand. These days 3 – six months of clean dishes as much as many customers can expect before dishes become progressively more and more disgusting. Poor engineering is responsible because the designs are prone to jams, clogs, water level malfunctions and circuit board failures.
Posted on Jan 27, 2009
SolutionGuy
  • 331 Answers
SOURCE: Dishwasher will not fill
EE,
The most likely culprit in a "no fill" scenario (especially after you've replaced the valve) is the Overflow preventer. It's designed to kill power to the valve if the water level gets too high. It does this by floating up as the water level rises.
Open the dishwasher door and remove the lower rack. You'll see it in the tub on the left side (the round thing that looks like a little hat). If it's stuck in the up (overflow) position, you won't get water. Raise and lower this device a few times... you should hear the "click click click" of the kill switch. Now just make sure it's in full down (ready for water) position and fire up the dishwasher. You should get water now.
If this helped, please rate this solution as "FixYa". BUT if this didn't fix the problem, don't rate it just yet. Write back and we'll go a little deeper into a diagnosis, OK?
SG
Posted on May 01, 2009
SOURCE: Jackson 200B Series Commercial Dishwasher Fills With Water and Drains
Could be one of two things. 1 - The cheap fix might be that the probes in the wash tank are dirty. There might be a "coating" on the probes that prevent the sensors from knowing that the water has reached the proper levels. 2- Replace part "Liquid Level Control" - $$
Posted on Oct 18, 2009
My hobart underbench dishwsaher will not fill or heat
Sound like the inlet water valve is out. So with no water it doesn't sense water to heat.
Nov 30, 2014 | Hobart Dishwashers
How Do I fill the dishwasher with water to first start it
Close the front access door and turn on the power switch. It should automatically fill.
Oct 02, 2014 | Hobart C44a Commercial Dishwasher
Hobart lx30h leaking from bottom
This is a testing for the post on this web site, not a solution.
Mar 27, 2014 | Hobart Lx30h Commercial Dishwasher
Hobart dishwasher LXIH starts filling and stops after 5 seconds or so
Hobart is probably the most user friendly manufacturer out there. Their service manuals are great. Try this.... Good luck Manuals Support
Feb 17, 2014 | Hobart Dishwashers
Water not heating up
see this causes and fix it. God bless you
will not run on cold water or even luke warm water, it has to be hot water. Most will even specify 120F or hotter water temp as incoming water. These new units only use 1.5-3 gallons of water for each fill, so the temp has to be there. Many brands recommend that you run your kitchen sink water until it gets hot, then start filling your dishwasher, we also recommend that. Some dishwashers will stop if it senses too cold of water coming in, others will try to warm the water and if it can't in so much time, the unit will stop and give an error code. Hot water also helps dissolve and mix the soap detergent better, giving you better washing results. Just make sure the water is hot going into your dishwasher, no getting around it.
Oct 16, 2012 | Hobart Am-12a Commercial Pan Pass Thru...
Hobart LXIH dishwasher
You can add a small amount commercial dish soap to the wash chamber before pressing the wash button.
Apr 02, 2010 | Hobart 24 in. LXIH-3 Built-in Dishwasher
Hobart glasswasher: it fills but then nothing
Did you solve your problem?It takes 8 minutes to fill.I'm a hobart tech,let me know.
Apr 11, 2009 | Hobart 24 in. LXIH-3 Built-in Dishwasher
As soon as you turn on power it starts to fill
It will look to the wash tank float to determine the water level and temperature. If the machine is empty, it will fill first. before letting a cycle start.
Apr 05, 2009 | Hobart LT1-1 Dishwasher
E-2 Error on LX30 Hobart Dishwasher
E-2 error is a fill problem. Water did not reach the lower probe within the time out. (innitial fill only
1- Is the bottom probe clean?
2- No fill water (check valve, hose,fill screen in end of hose, and fill source.)
3- low water pressure, should be 20 PSI flow.
4- Fuse 1FU blown.
5- Check wiring to fill valve.
6- Check relay board function.
Feb 15, 2009 | Hobart 24 in. LXIH-3 Built-in Dishwasher
Dishwashers Logo
152 people viewed this question
Top Dishwashers Experts
