Question about FUJIFILM Cameras
Only a couple months old, not exposed to water, not dropped, won't hold a charge. won't turn on. any suggestions or is this dead after 4 months? I didn't buy the extended warranty b/c I tr
Finepix AX560
  • FUJIFILM Master
  • 32,281 Answers
The warranty should be at least one year.
Try a warranty repair or replacement.
Posted on Apr 21, 2013
Brand new camera, never used Fuji Film JX650. I opened up it tried to turn it on. It didn't work. I plugged it in and left it charging for about 9 hours over night. I tried to power it up the next day. nothing. no power when it's not plugged in. Plug it in and it comes on. WTH? It is brand new! I even bought a new battery thinking that was the problem. It still won't work. same problem.
Posted on May 27, 2014
1alexh
  • 484 Answers
SOURCE: Nikon D60 won't turn on and the battery is
Usually, when your battery has been in the charger long enough for it to be fully charged, the indicator light either changes color, or turns off. This indicates that the charge is complete.
Does your light do either, change color or turn off?
If neither of these works right, check your user manual, usually in the back, which will tell you what the indicator lights mean.
If your camera and battery are doing what they are supposed to be doing, then you may have bought a faulty camera, or the battery which came with it was faulty.
Be certain to read the manual very carefully, to be certain that you are following the instructions properly. If you have done everything right, then return the camera and or battery to the place from which you purchased the camera, and have them check it out to ensure that all is proper.
Posted on Dec 30, 2009
SOURCE: Camera won't power up
Mine was the microswitch that tells the camera the battery / card door is closed. The tiny, cheap plastic protrusion that pushes on the switch broke off. Jam the switch with the end of a toothpick.
Posted on Feb 07, 2009
  • 6 Answers
SOURCE: Kodak M340 lens extends then retracts immediately
I had the same problem after a day at the beach. What I did was get a can of compressed air (from the computer section) and blow air around the lens as I repeatedly turned it on. It took about five cycles, but I eventually cleared whatever was preventing the lens from fully opening.
Good luck.
Posted on Sep 28, 2009
  • 11967 Answers
SOURCE: my Kodak m1093 is will not turn on. i tried
If it's only 2 months old, it is still under warranty...you should take advantage of that.
Posted on Jul 12, 2010
  • 11967 Answers
SOURCE: I bought a Nikon COOLPIX
Sounds like a defective camera....take it back.
Posted on Jul 17, 2011
Battery will not hold charge
If the rechargable battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced. Rechargeable batteries will fail if stored in a discharged state for long periods.
Nov 14, 2012 | Sony Nwz-w262 Water Resistant Mp3 Player...
I haven't turned the camera on for a couple of years. I've tried charging the battery, but I can't get it to power up. Do I need to replace battery or is it something else?
If the rechargeable battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced. Rechargeable batteries will fail if stored in a discharged state for long periods.
Nov 06, 2012 | Samsung i85 Digital Camera
Built in battery wont hold its charge
If the recharageable battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced.
Aug 21, 2012 | Cameras
Camera won't turn on
check the age of the batteries bc my rechargeable ones only lasted 4 years and they wouldnt even hold a charge for a couple of pics
Aug 15, 2012 | Panasonic Lumix DMC-FP3 Digital Camera
Battery not holding a charge
If the rechargeable battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up at all. OR Thebattery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. If the battery drops to anunacceptable charge level then the battery needs to be replaced.Since you did not supply details of your device and the type of battery I cannot advise where to purchase the battery.
I suggest you Google the Internet for the rechargeable battery you require.
Apr 15, 2012 | Televison & Video
My vivitar x345 wont hold charge
If the recharageable battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% and graduallythe charge reduces until the battery won't charge up at all. OR The batteryshows a 100% charge but when the adapter is disconnected the battery drops offto zero capacity in a very short time. If the battery drops to an unacceptablecharge level then the battery needs to be replaced.
Mar 23, 2012 | Vivitar ViviCam X345 Digital Camera
Uniden battery will not charge
Feb 04, 2012 | Uniden Cordless Phone
Makita 1822 battery not holding charge
If the Makita battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up at all. OR Thebattery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. If the battery drops to anunacceptable charge level then the battery needs to be replaced.
Jan 21, 2012 | Drills
I have a sony cybershot dsc w120 camera and it turns on and maybe lets me take 1 or 2 pictures before shutting off (sometimes with the lens still out). It hasn't been dropped or exposed to water, so I
Things to check first for a camera that won't turn on, or works intermittently are the battery contact points, ensuring that they're clean, and making good contact with the battery. Troubleshooting tips on other things that need to be checked may be seen here. These tips won't work for every case, but they're worth a try.
Nov 23, 2011 | Sony Cyber-shot DSC-W120 Digital Camera
It won't turn on at all. It won't even charge. It's only 4 months old. Wasn't dropped or exposed to water or elements. Was working fine yesterday morning, then about 4:30, it was dead. ...
How long did you let it charge, when the device is completely drained of power it may not turn on at first when you connect it. Let it charge for a little while and come back to see if it fixes it. Failing that, your probably going to have to contact apple for warranty help.
Jun 15, 2011 | Apple iPod touch
Cameras Logo
604 people viewed this question
Top FUJIFILM Cameras Experts
Tony
Are you a FUJIFILM Camera Expert? Answer questions, earn points and help others
