Question about Cannon Office Equipment & Supplies
Where do I find the wps pin number on the canon MX892?
3 Suggested Answers
Rider On Way
  • 1679 Answers
SOURCE: HP Photosmart printer gives me
If your router does not has WPS button, there is another way to Enable it from Router configuration under wireless settings
If you enable the WPS option from Router, you will have to press the WPS option from printer for automatic setup of printer on wireless network.
If you are not able to locate it then the WPS on your printer is of no use ( to connect to router )
Instead, I believe you have wireless router and you want to setup the printer wireless on network.
This is touchsmart printer and it has a setup button
Press SETUP option
Press WIRELESS option
Check for Wireless Setup Wizard
If it has Wireless setup wizard, select it and continue to search for wireless router and enter your network key if your router is secured with a key.
Run the software disk on pc and choose wireless connection and continue with the rest of the installation screen to complete.
If this option is not available, you will have to setup the printer thru usb cable and make it wireless
Run the disk on your pc
Choose Network Wireless connection
It will prompt you to connect thru USB
follow the instructions and it will ask you to disconnect
Continue with the remaining instructions.
Posted on Oct 23, 2010
  • 9 Answers
SOURCE: where is the WPS access button on the canon Pixma MX892 printer?
Here is an excerpt from the manual that describes it. Looks like the printer should auto detect.wbzkins5dfvuwaaaabjru5erkjggg==
Posted on Oct 18, 2012
I am trying to connect my new wifi ext bt600 with no wps button on my router
Since your router does not have a WPS button, it is likely it uses a 9-digit pin number for WPS. The pin number should be on a sticker on the router or maybe in the router's setup guide.
Sep 19, 2014 | Computers & Internet
What is wps pin
Wi-Fi Protected Setup (WPS) is a standard for easy and secure wireless network set up and connections. Some of NETGEAR's products use the name Push 'n' Connect for WPS. To use WPS, your product must support WPS and be compatible with WPA security. WPS can automatically set up a random network name (SSID) and strong WPA wireless security for wireless routers, access points, computers, adapters, Wi-Fi phones, and other electronic devices.
WPS lets you use a push button or enter a personal identification number (PIN) instead of manually entering a network name (SSID) and password:
  • Push button. The WPS button is either a button on the product or a an option on the wizard or utility screen.
Aug 15, 2014 | Sony BRAVIA KDL-52W4100 52 in. LCD HDTV
Where do I find the WPS pin number on the HP Officejet Premium
You can find the WPS pin number on the printer's on-screen display by following these steps (on the printer display itself):
1. On the printer control panel, touch the arrow symbol that's located on the far right.
2. Touch Setup.
3. Touch Network.
4. Touch Wi-Fi Protected Setup. Follow any on-screen instructions. (My printer doesn't have any real instructions on this page. Just some very brief bullets. This may be because my printer is already set up for WPS. On my printer, I simply press Continue at this point. That may be what you have to do at this point, too. But if there are actual instructions on this page, you may be required to follow them first. You can always use the back symbol to get back to any page, as needed.)
5. After you press Continue to leave the WiFi Protected Setup instructions page, you will be directed to the WiFi Protected Setup page. One of the options on this new page is PIN.
6. Touch PIN.
Your WPS PIN will be revealed!
Aug 06, 2014 | HP Officejet 6700 Premium E-All-In-One...
Where might I obtain a Canon Pixma mx892 printer's manual?
http://www.manualowl.com/p/Canon/PIXMA-MX892/Manual/155533
Jan 19, 2013 | Canon PIXMA Office Equipment & Supplies
Where is the WPS access button on the canon Pixma MX892 printer?
Oct 17, 2012 | D-Link DIR-625 (790069292637) Wireless...
Canon MX892 - when I scan, an error code 2156 comes up saying scanner is turned off or usb cable unplugged
Hi.
Try to check up first scanner power cable and network wireless router.
If it are running running good. your scanner have defective parts. like
IC chipset.
Second option : try to general cleaning your Canon PIXMA MX892 Network-Ready Wireless All-In-One Printer. using vacuum.
Hope can help you.
Sep 15, 2012 | Canon PIXMA MX892 Network-Ready Wireless...
How to print address on envelope on canon mx892
Printing envelopes on Canon MX892: Remove paper from rear tray. Adjust gray width handlers to the size of your envelope. Insert a blank envelope in the rear feeder, with flap oriented on the back left side.
May 30, 2012 | Canon PIXMA MX310 All-In-One Printer
I have two laptops and want to set up a wireless network. I have the wireless set up but it isn't secure. When I go in to the Homegroups page it asks me for a 4 or 8 digit PIN number found on the router....
If you don't know it, you won't be able to automate your Wifi Protected Setup (WPS). The pin is a very specific way to prevent yourself from always having to remember codes, keys, passphrases, etc. Without it, its like saying that you want to to connect to Bank of America, and that it's just okay because you want it to happen.
The following is taken from the ESR-9753 manual:
- Wi-Fi Protected Setup (WPS)
WPS is the simplest way to establish a connection between the wireless clients
and the wireless router. You don’t have to select the encryption mode and fill in a
long encryption passphrase every time when you try to setup a wireless
connection. You only need to press a button on both wireless client and wireless
router, and the WPS will do the rest for you.
The wireless router supports two types of WPS: WPS via Push Button and
WPS via PIN code. If you want to use the Push Button, you have to push a
specific button on the wireless client or in the utility of the wireless client to start
the WPS mode, and switch the wireless router to WPS mode. You can simply
push the WPS button of the wireless router, or click the ‘Start to Process’ button
in the web configuration interface. If you want to use the PIN code, you have to
know the PIN code of the wireless client and switch it to WPS mode, then fill-in
the PIN code of the wireless client through the web configuration interface of the
wireless router.
Jun 28, 2010 | EnGenius ESR-9753 SOHO Wireless Broadband...
357 people viewed this question
Top Cannon Office Equipment & Supplies Experts
Cosma Papouis
Cosma Papouis
Greg Cann
Greg Cann
Are you a Cannon Office Equipment and Supply Expert? Answer questions, earn points and help others
