Epson printer error 0x00000709 - Office Equipment & Supplies
2 Suggested Answers
SOURCE: Kodak Easy Share All in one printer 5100 error
Call... customer service... is more effective. They sure will replace the printhead.
Posted on Oct 14, 2009
Can't set HP LaserJet Pro 400 as default printer
I recently had a troubleshooting appointment for an hp printer that could not be set as the default printer. When I tried to make it the default, a message box came up saying "operation could not be completed error (0x00000709)". Other than that, it seemed to work fine. I even removed all the printer software through "Programs And Features"in the Windows control panel followed up by a Windows system registry scan. I then performed a clean install of the hp printer still no joy.
Next, I began to research the "operation could not be completed error (0x00000709)" error message on the internet. I came across a variety of solutions, which I tried in succession with no luck. I finally discovered the one that worked. It was a simple fix to the Windows system registry. This is what I did to solve the annoying little problem:
I. Type "regedit" followed by the enter key in the "search program and files" text box in the pop up menu that appears after clicking the Windows"start button" in the lower left hand corner of the Windows desktop screen.
II. Next, click "HKEY_CURRENT_USER" in the left hand pane of the Windows registry editor.
III. Then click "Software" followed by "Microsoft" and next "Windows NT".
IV. While under the "Windows NT" entry, click "CurrentVersion" and then "Windows".
V. Now, one of the entries you should see in the right hand pane is"Device". If the value for "Device" as noted under the "Data" area is anything other than the printer you are using, then highlight "Device" in the right hand pane with the mouse and press the delete key to remove it.
VI. Restart the computer so it starts with the altered Windows system registry.
After the Windows desktop appears again, you should be able to go into the"Printers" area and designate your printer as the default without receiving the "operation could not be completed error (0x00000709)" message.
Being able to designate the default printer can save you a fair amount of work over the long run. This is because you won't have to specify your destination printer in the printer dialog box - it is already selected since it's been set as the default.
Mar 14, 2014 | HP LaserJet Office Equipment & Supplies
ERROR 0X00000709 PRINTER HP CM6040F MFP
hi,
Error related tray lifting....just check which tray is not lifting and find "is there any kind of abstraction to lift the tray".
Then just refix the tray lifter assy. connector otherwise replace lifter assy.
hope it will help.
Feb 04, 2014 | HP LaserJet Office Equipment & Supplies
Error 0x00000709
Enter registry and set your printer as default.
Oct 28, 2013 | Sharp Office Equipment & Supplies
Error 0x00000709
Click start control panel administrative tools computer management then select event viewer this may vary depending on what operating system you have
extend the events there you will see errors in red you will no what exactly what the error was and at what time it occured
Right click on the error message select properties you will see all details about the error
or click start type in event viewer press ENTER
you might be able work your way through the problem.
Method 1:You may try the steps from the link and check.
Printer problems in Windows
http://windows.microsoft.com/en-US/windows/help/printer-problems-in-windows
Method 2:You may try to uninstall and reinstall the printer and check.
Reinstall printer in a clean boot state with the latest drivers from the manufacturer website.
Uninstall the Printer driver from the device manager.
a. Right-click the My Computer icon
b. Select Manage from the menu.
c. Select Device Manager from the System Tools that are listed in the resulting display.
d. Right click on the Device.
e. Click on the driver tab.
f. Click on uninstall.
g. Restart the computer
Download the latest printer driver from the manufacturer website and check.
http://windows.microsoft.com/en-us/windows7/Update-a-driver-for-hardware-that-isnt-working-properly
Refer the steps from the link to perform clean boot.
How to troubleshoot a problem by performing a clean boot in Windows Vista or in Windows 7
http://support.microsoft.com/kb/929135
Note: After trouble shooting put the computer to start as usual by performing step 7 from the above Knowledge Base article.
Install a printer
http://windows.microsoft.com/en-us/windows7/install-a-printer
Find and install printer drivers in Windows 7
http://windows.microsoft.com/en-us/windows7/Find-and-install-printer-drivers
May 11, 2013 | Dell Precision T3500 Computer Workstation...
Error code 0x00000709
here is the solution for your problem is written in Spanish but has the solution with step by step pictures : http://adf.ly/MXAec
Apr 13, 2013 | Cell Phones
''toshiba e-studio 720 error code c473
This is an overvoltage error....Really need a tech to fix this...could be bad wall voltage....or the thermostat in the IH unit...or the fuse in the IH unit...or the logic board....
Oct 31, 2009 | Toshiba E-STUDIO 720 Copier
174 people viewed this question
jasbo
jasbo
