Question about Whirlpool Ovens
What are the dimensions of a RB770PXYB-6
Is a RB770PXYB-6 24" or 27"
What are the dimensions of the space required to install an Omega Europa 20-1 oven under a bench
installation dimensions are included on the brochure of the unit
the brochure will be available from a retailer or on line and those dimensions are what builders use to make the right sized opening
Sep 09, 2016 | Ovens
I have an old 24 single wall Tappan oven from around 1985 that needs to be replaced. There is no model or serial number. Where can I go to figure out the measurements of it?
Built in ovens come in three standard widths, 24, 27 and 30.
Look at the installation guide in the link for a sears for the 24 inch and confirm the width of your opening along with the depth. Make sure the new does not exceed your dimensions..
The problem is usually in the height. There is a lip that extends outside the inside dimensions so the over all width and height need not to extend beyond you cabinet. You can jack up the bottom with spacers to minimize any upper gap.
http://i.sears.com/s/d/pdf/mp-tc/10031951/prod_1502240512
Jan 13, 2016 | Tappan Ovens
Please tell me if Electrolux EKG5547XN Cooker Main Oven Glass Door would fit my EOB6632U
Glass oven door is not compatible.
First of all, the oven door EKG5547XN has only two glasses, inner and outer, while the oven door EOB6632U has three glasses; inner, middle and outer.
EKG5547XN
Inner glass oven door, part number: 349 00 30-01/6, silkscreened; dimension: 456 x 323 mm, tempered glass.
Front glass oven door, part number: 349 10 45-14 / 6, stainless.
EOB6632U
Inner glass oven door, part number: 899661 92 68-78 / 3,
silkscreened; dimension: 479 x 391 mm, tempered glass.
Middle glass oven door: dimension: 447 x 380 mm.
Front glass oven door: dimension: 589,5 x 466 mm.
Dado
Mar 28, 2015 | Electrolux Ovens
How many tablespoon in 27 grams?
Tablespoon is a unit of volume while gram is a unit of mass. The conversion between them depends on the density of the substance.
27 grams of water is about 1.83 tablespoons. 27 grams of mercury is about 0.135 tablespoons.
Mar 12, 2014 | Ovens
Installation instructions and manual
Most of the installation manuals for GE appliances are available on their support page: http://www.geappliances.com/ge/service-and-support/literature.htm . I found several double wall oven models with the JKP27 designation. However, the G0J4BG does not fit as part of the model number. There should be 4 letters after JKP27 in the model number. These letters primarily indicate the color of the exterior. For the JKP27 models, the installation manual says that the cut-out should be 32 1/2" above the floor. The depth has to be 23 1/2". The cutout width should be between 25" and 25 1/4" (these are an absolute minimum and maximum). The cutout height should be between 27 5/8" and 28 1/8".
The direct link to installation manual for one of these ovens is here: http://products.geappliances.com/MarketingObjectRetrieval/Dispatcher?RequestType=PDF&Name=003675840.PDF . See page 6 for the cut-out dimensions.
I hope this helps.
Feb 05, 2018 | GE JKP27 Electric Double Oven
Bosch wall oven turns on when mcrowave is on
Contact Bosch website and ask customer services if they have had this problem before. It may be subject to recall if there is a fault. Also have a word with the installer. If there is any leakage of radiation it MUST be stopped.
Dec 10, 2017 | Bosch Appliances 27 in. Wall Oven Electric...
Need dimensions on Jenn Air built in oven model w30400b. Not sure if it's a 27 in or not. Serial 14352004QZ
Hello, diane
I was trying to help you out here. Maybe this will help some? I was going back to some customers that asked questions in the recent past and farther back, It appeared that no one answered some of them, So, I thought I would take some of my personal time to see if I can help. Even though this site may not have your exact model or brand, This link will help you tons. Here is a link to about everything you want to know about your oven, from repair to trouble shooting it. Even pictures and video's. Just scroll around and you will see tons of information to almost any question you might have on your Oven. If you go to this link and click around, I am sure you will find out so much about your oven, you will know more than the company that made it. The good thing about this link is, then you can make the decision of DIY or hiring a pro. Here Is the link for you to click on>>
http://home.howstuffworks.com/dishwasher.htm
Please if this helped you at all, if you can find the time to rate my help and some kind words written would be appreciated for my free help , I would appreciate it. Here is also my direct link to my own pages of other areas of my expertise for other problems you might have in Automotive,Appliance, and Electronics. Drop In anytime for my help. Thanks,Mike
http://home.howstuffworks.com/how-to-repair-an-oven.htm
Thanks,Mike
http://beta.fixya.com/users/mc1bean
Feb 14, 2011 | Jenn-Air 27 in. Electric Single Wall Oven...
Is this model 27" or 30"
It is a 30". Your model number has the dimensions for your oven included in it.
The best of luck to you. Please check us out at:
www.accurate-appliance-service.com if we can be of any further assistance.
Oct 24, 2009 | Amana AOES3030 Electric Single Oven
Jenn-air w156, displays f1 fault code. how do i
This is a Defective touch pad or membrane
Replace touch pad or membrane (this problem is usually the touch pad)
Jun 17, 2009 | Jenn-Air 27 in. Electric Single Wall Oven...
Ovens Logo
154 people viewed this question
Top Whirlpool Ovens Experts
Dan Webster
Dan Webster
ashburton
Sal De
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
