Question about Dell Vostro 1000 Laptop
How do I get my Vostro 1000 to bootup
My Vostro 1000 laptop will not complete boot up to the desktop, it will start booting up, and it will stop, and start the process again, but would not complete the bootup. Please what I can do to get it to bootup complete.
  • Dell Master
  • 3,799 Answers
Try going into safe mode. Press F8 when you start the computer and then select "Safe Mode with networking" you should then be able to run a couple of diagnostic programs or a virus checker. You can even do a system restore from there.
Posted on May 02, 2013
mayviller
  • 41 Answers
SOURCE: Vostro 1510
Possible memory issue. Try Reseating your memory card on the system, it would be helpful.
Posted on Oct 02, 2008
  • 998 Answers
SOURCE: Laptop Won't startup Vostro 1500
See if you can run the Pre-boot System Assessment (PSA) diagnostics. To run the PSA+ Diagnostics on this system, perform one of the following actions:
1) Hold down the <Fn> key while pressing the power button.
2) Turn on the system, press <F12> at the initial Dell™ logo screen, and select “Diagnostics” from the boot menu.
3) Disconnect the AC power and remove the battery. While holding down the power button, insert the AC connector into the back of the system. The system then starts and the message “Diagnostic boot selected” displays. The system then launches the PSA+ Diagnostics.
According to Dell specs, there is no error code listed that you described, (Flashing Caps LED). Also try reseating the memory modules, (you might want to try this first).
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
Thank You.
Posted on Nov 07, 2008
knotbeerdan
  • 413 Answers
SOURCE: Update Dell Vostro 1000 BIOS now wont turn on, nothing on display
Hopefully you can find something helpful on this site. Basically you need to flash or reset your bios now. this site also has some links to remove upgrades. LIke i said i hope this helps.
http://www.user-guides.co.uk/Dell/DellManuals/Dell.asp?keywords=Dell+Vostro+Manual&recor=1
Posted on Dec 29, 2008
heavymetal77
  • 721 Answers
SOURCE: I have Dell Vostro 1000 which won't boot up. Can
Sounds like the hard drive went bad.
Posted on Jul 14, 2009
  • 243 Answers
SOURCE: Dell Vostro 1000 will not boot.
It maybe the power adaptor is loose on the motherboard. Push the cord in and rotate it and continuously push the power button if it starts that is your problrm. You can temporarily fix it with tape once you discover where the cord wants to be or you can use a clamp.
Posted on Aug 26, 2009
Forgot password vostro 1500
Hi
What is the password for is it the log on password or the bios boot password
If its the log on password then there is lots of different software out there that will help spotmau bootup cd is one of them if you can get hold of a copy burn it to a cd make sure that it is a bootable version then boot up with it and it can bypass the password and get you back into windows where you can then adjust your settings
Dec 11, 2010 | Dell Vostro 1500 Notebook
Vostro 1015
Please set the bios : first boot with the USB disk or USB cdrom.
My Dell Vostro 1000 battery can boot with the USB Flash disk
May 13, 2010 | Dell Computers & Internet
I have a dell vostro 1000 laptop. when i turned it on, the screen is dark. i can still see the desktop but it's very dark. i tried the FN F8 and the FN up and down arrows. What next?
Battery in the laptop could be dead. It doesn't have enough charge to boot into windows possibly.
If your into windows then check the power settings. You can adjust the brightness if vista type power in the search. xp go to control panel power and maintenance.
Jan 06, 2010 | Dell Vostro 1000 Mobile AMD Sempron...
My dell vostro 1000 won't turn on the green light
Try to do this: (Draining flea power)
1. Unplug the ac adapter (if connected)
2. Remove the battery
3. Press and hold the power button for at least 10sec.
4. Put back the battery and ac adapter
5. Turn it on
- check if you can now boot to windows, if not there could be a hardware problem and next step would be running some diagnostic test on the computer for hardware problem.
Dec 07, 2009 | Dell Vostro 1000 Laptop
How to fix a back screen on a dell laptop
Press F8 at boot up to get a menu with various options. Select Safe Mode and boot. Once booted, go to display settings and set your monitor right. If that does not work, then F8 at bootup and select the options which says "Last good Bootup". that should do away the new driver you loaded.
Sep 14, 2009 | Computers & Internet
BSOD says boot partition is full, when it isn't
hello
try to boot in safe mode.(press F8 after bios bootup)
if that doesent work run chkdsk.(boot from windows cd and choose R(repair mode) go to the console and write chkdsk /R let that run and try to restart when its done.
Feb 23, 2009 | Lenovo ThinkPad R51e Notebook
You may be in for some trouble, a failed bios update isn't always an easy fix. if you can find the cmos battery try to remove that for a few seconds. you will also need a disk version of the bios, download that from dell on another computer and copy it to floppy or cd and see if you can boot to that and reinstall the bios.
when you press the power button what happens, does it light up and run the fan? Nothing appears on the screen?
Dec 29, 2008 | Dell Vostro 1000 Mobile AMD Sempron...
Acer laptop bootup problems
Please try and bootup your computer in safe mode by pressing the F8 Button just before windows starts to load. a menu appears and you just need to select the safe mode option and see how it goes from there.
Let me know if this helps.
Oct 27, 2008 | Acer Ferrari 4000 Notebook
I'm getting blue screen on bootup
Sometime hitting F8 during boot up brings the safe boot screen. Booting to safe then booting normally sometime fixes the problem.
Aug 23, 2008 | Dell Vostro 1500 Notebook
Dell Vostro 1000 Laptop Logo
81 people viewed this question
Alun Cox
