Question about Samsung SyncMaster S22B150N - LED monitor - 21.5""
I have a black screen and blinking blue light
I have a Samsung SynMaster S22B150 LED Monitor, and it when I woke up this morning to turn it on, it has a black screen and the blue light is continuously blinking. I noticed that when I touch the menu button, that it does recognize and displays a "test good" message, but goes right back to the black screen. Please help! This is monitor is only 1 week old!
  • Samsung Master
  • 27,725 Answers
WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL. http://www.kitchentablecomputers.com/static.php - rules Test all power and data leads that attach to your hard drive IDE,SATA the leads from your (motherboard to your hard drive) make sure they have secure dust free connections and are not faulty if its a 40 pin flat ribbon type it will be the first to fail make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even something as small as a faulty electrical fan and its lead can cause you problems computers need all power and data to continue through every working device and to have an end so any faulty leads will end up with a computer error Check your RAM. The RAM is located in the middle of the motherboard. There are tabs that you can push to release the RAM. Remove it and put it back in place until the tabs pop out. Loose RAM can cause your computer not to start properly where you want to see a video signal.
Make sure your graphics card is securely seated with no dust built up or in the socket if you remove your graphics check the socket to make sure its dust free Restart your computer then reinstall it this should activate found new hardware wizard Check the vga lead for secure dust free connection or try another vga lead.
Posted on Apr 20, 2013
5 Suggested Answers
chamboard
  • 557 Answers
SOURCE: how can i know my
look on the back for the monitor there are a sticker with the info.
change setting from computer display to lower resolution and display syse
by starting to save mode F8
Posted on Dec 18, 2010
benwabnick
  • 2404 Answers
SOURCE: menu keep on blinking
Disconnect the monitor from the computer. Then turn on the monitor, if the menu keeps on blinking then that means the screen is starting to go bad and the monitor needs to be replaced.
You can also hook up the monitor to another computer. If the blinking stops then that means its an issue with the video card in your original computer.
Posted on Feb 05, 2012
SOURCE: My Samsung SyncMaster 205 bw monitor was working a
Sounds like your monitor has croaked. Borrow a monitor from a neighbor, friend or family member just to see if it works. If it works, your monitor is bad. If the borrowed monitor has the same issues then your Video Card in the computer is bad and needs to be replaced.
Posted on May 02, 2012
  • 3 Answers
SOURCE: My crt monitor displays colours after i shutdown
maybe a bent pin in connecter
Posted on May 22, 2012
How to change to monitor analog syncmaster s22b150?
Refer its user manual for details. If you haven't it with you now; just download it for free, from www.retrevo.com/
Nov 10, 2014 | Samsung SyncMaster S22B150N - LED monitor...
Black screen and blinking blue light
blinking blue lights means the monitor is stand by.for the black screen
you should check your cabels from monitor to computer.they should be seated tight.if still no picture your videocard is proberly brooken.
it should be point out at LCD-monitors are fragile.
Apr 20, 2013 | Samsung SyncMaster S22B150N - LED monitor...
22 samsung syncmaster S22B150 led monitor color settings problem how to fix
I have the same monitor. It was working just fine for almost a full year and recently I started to play games on Furg Games Play Free Online Games for a few hours a day and my eyes started to hurt. I've tried to change brightness and contrast several times but still I can't stay more than an hour in front of it.
Oct 11, 2012 | Samsung Computers & Internet
My Acer AL2216W monitor this morning went blank. I woke up, turned on pc and went to sleep like an hour more, when I woke up, the screen was black and light orange, as usual, when pc is not used for a...
Go to Control Panel, (top right View Small Icons). Then look for Power Options. On this page, you'll have the option to leave the monitor on. You should also check "Advanced Power Options". Don't be afraid of the word, "Advanced." It only means "customizeable"
If your mouse isn't waking your monitor, try the keyboard's space bar. I found it works better than the mouse at waking a sleeping computer
Apr 04, 2017 | Acer AL2216W LCD Monitor
Samsung SynMaster 740NW monitor, 02 years old, shows blue vertical line on screen, what may be reason & solution
The contacts on the lcd panel for those columns of pixels are defective. That cannot be repaired, the entire monitor will have to be replaced.
Feb 20, 2011 | Computers & Internet
My monitor was fine last night, when i woke up this morning it would not come on, the blue light is flashing, help
Press and hold the button, until the monitor turns itself off.
Then, turn it on, and hope that it works correctly.
Aug 21, 2010 | Proview PL926WBi 19" LCD Monitor
Samsung monitor blue flashing light, black screen
The picture board of your monitor has developed fault. That is why the screen is black.
The best thing for you to do now is to take the monitor to a local repairer within your vicinity, because the fault is not something you can fix in other not to complicate issues..
The repairer will help diagnose and replace the faulty picture board and your monitor is back and better.
Take care.
Apr 19, 2010 | Samsung SyncMaster 203B LCD Monitor
Samsung Syncmaster 710n no display and no LED light
The power button should be on the FRONT BOTTOM RIGHT. and there should be a little led/light next to it. make sure everything is plugged in correctly and press the power button, the led should light up, and then boot your computer.
Let me know --
If this helped please mark this thread as FixYA
Dec 26, 2008 | Samsung 710N V2 (Ivory) 17 in. Flat Panel...
Synmaster 740 n green line on the monitor
This may be part of the OSD (on-screen display). If you don't have your manual you can download it here: http://tinyurl.com/yzerbd I would check the manual.
Jan 07, 2007 | Samsung SyncMaster 740N 17" LCD Monitor
Samsung SyncMaster S22B150N - LED monitor - 21.5"" Logo
182 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
