Question about Toshiba Satellite A65-S126 Notebook
Only showing 64mb of ram instead of 256
This laptop has been passed down so many times. There are hard drive, screen, and battery problems.
My brother stopped using it because of how slow it was, then the battery died, I brought it back to life by leaving it plugged in with no battery.
I want to use it as a linux machine, but in trying to find out why it was so slow I discovered it is only registering 64 megs of ram for some reason.
Anyone know the solution to this problem?
  • 94 Answers
You laptop shared to much memory to graphics try to look graphics adapter how many memory is use just right click to desktop select properties goto settings click advance and click adapter you can see the amount of memory using of graphics. Use only 64 mb or 128 mb shared memory it depend to memory card
Posted on Mar 12, 2009
When laptop start window 10 boot screen come up and during the process after 15-20 seconds since the laptop was powered on the laptop get shut down.
hi there.
Laptop performance slowing down, or the laptop isshutting off completely because the laptop is trying to protect itself from damage caused by an excessive heat build-up. ... There are times when a laptop will turn offbecause of a virus or malware, hardware or software problems/conflicts as well.2 Nov 2013
Don't panic!... Is your "laptop shutting off by itself" or "slowing down ...
https://www.youtube.com/watch?v=74agkgZdzkI
What is the problem if laptop shuts down automatically?If removing air doesn't fix shutdown issue, it is a faulty hardware (can be anything), related to overheating or serious power related failure, such as bad battery or adapter. Overheat issue will result in unit turning on, but shuts down after about the same time (i.e. 15 sec).29 Jun 2015My Laptop automatic shutdown in few seconds - Laptops - Laptop ...
What would cause a computer to keep shutting down?An overheating power supply, due to a malfunctioning fan, can cause a computer toshut off unexpectedly. Continuing to use the faulty power supply can result in damage to the computer and should be replaced immediately. ... Software utilities such as SpeedFan can also be used to help monitor fans in your computer.5 May 2017Computer turns off without warning - Computer Hope
How do I get my computer to stop shutting down?Cancel System Shutdown or Restart. You cannot cancel a restart or shutdown using the Shutdown Event Tracker Windows interface. It is only possible to perform this task from the command line. To cancel or abort system shutdown or restart, open Command Prompt, type shutdown /a within the time-out period and hit Enter.1 Apr 2013Stop, Cancel, Prevent, Abort System Shutdown in Windows 10/8/7www.thewindowsclub.com/abort-system-shutdown-windowsSearch for: How do I get my computer to stop shutting down?
or go to this link to find out more.
Laptop keeps shutting off after few minutes
Nov 19, 2017 | HIS Computers & Internet
My Toshiba c-55 wont turn on the white button light flashes 4 or 5 times and then stops but it never turns on.
I heard of many power issues with these models. Mostly concearning the battery, it sounds like this may well be the case from the 'light flashing' issue.
The other problem involving slow start up/ being laggy could be down to the machine running hot and Windows is using passive cooling in the power options, or a failing hard drive can also cause software problems.
Dec 25, 2014 | Toshiba Satellite Computers & Internet
Why my laptop runs slow when i disconnect the power cable although the battery is fully charged. After reconnecting the power cable the laptop runs normally at good speed, why? is there any problem with...
When you run on the battery the laptop reduces or stops certain things to conserve battery power. Haven't you ever noticed that once you remove the power cord the screen goes dimmer. The laptop is conserving energy and that will cause it to perform at a slower pace or speed.
Unplugged laptops generally go into power saving mode. They will slow the CPU speed, stop the hard drive more often and lower the brightness of the screen (big power savings) all that good effort is lost when you remember that the power supply you use to charge the battery is making more heat . When you reattach it to the power adapter it goes back to Full Power Mode, and recharges the battery as well.
Here's a rule of thumb that I always follow. If i'm near an electrical outlet, I use the power cord. I never use my battery unless there is no electrical outlet near by. This way my battery is always charged for times that I really need to use it.
May 18, 2012 | Compaq Computers & Internet
Regarding back up of battery
LOL, Nope, there is no problem with the battery. That's the way it's supposed to work.
My HP laptop screen will not do anything. The first time this happened, I was in the middle of something and the screen suddenly became a bunch of black and white random-ness. I shut it down, and tried...
Perform the following:
1. Disconnect the AC Adapter.
2. Remove the Battery.
3. Hold the Power button down for 30 seconds to 1 minute.
4. Reconnect the AC adapter and do NOT connect the battery now.
5. Turn on the Notebook power.
If turned on, shut down the Notebook, insert the Battery and turn it on again. That's it.
Cause:
With an extensive use of the notebook, some times notebook would store some static charges which indeed will stop the notebook from powering up or charging the battery.
Performing above procedure will not effect any personal data or delete any pictures from the hard drive on your notebook.
Aug 22, 2010 | Computers & Internet
My compaq laptop will not charge pass 73% no matter how i plug it in. It just started doing this only this week. Can this problem be solved or do i need to buy a new battery. It has a 1GB memory w/ a...
Yes, your battery is dying, they all do in time. I replace my Dell battery every 18 months.
Your slowness has nothing to do with the battery, it's because it's a Windows PC, and they all slow down as you add more programs.
Oct 25, 2009 | Compaq Computers & Internet
-Was using the laptop toshiba A40 for several hours -The computer shut off on it?s own -Upon restart the computer goes to a prompt screen asking you to choose to boot from one of the following: Safe Mode,...
it is a bad hard drive, 12 hours is too long its a slow drive therfore you just need a new hard drive (new not used from ebay) and format xp and bob is your uncle. dont think that i will try other stuff to still not spend to get a new hard drvie but it is time you cof'up lol good luck
trust me i know
Jul 30, 2009 | Toshiba Satellite L305-S5907 Laptop
Boot up problem
Im suspecting a hard drive problem. try to run diagnostics by holding down fn key + Power button while the computer is off. it should indicate that i failed. if it passes. reinstall the CD's.
Sep 12, 2008 | Dell Inspiron 1501 Notebook
Laptop compaq v2000
your windows install is screwed up. i'd dig up your Windows XP CDand pop that in and do a repair install. if it still doesnt work then i'd enter the bios setup (hit F10 on compaq boot screen) and look in there for "Hard Drive Test" and run that. be aware it will take 70 mins on a 60GB hard drive, and longer for a bigger drive. if the hard drive passes the test then you may want to boot up the XP cd and do a fresh install, opting to format the drive. be aware that formatting WILL delete anything and everything on the laptop.
if the hard drive fails the test, then obviously you need to get a replacement drive and reinstall Windows on that. if the hard drive failed, any data on it is most defenetly toast.
Aug 16, 2008 | HP Compaq Presario V2000 Notebook
Overheating and ac adapter disconnection
try to open laptop and clean the dust off the fan
Jul 18, 2008 | Sony VAIO PCG-K35 Notebook
Toshiba Satellite A65-S126 Notebook Logo
102 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
