Question about Whirlpool Ovens
Dimensions of RB770PXYB-6
Trying to see if this is a 24" or 27" oven
I need to replace my 1987 approx. Chef wall oven Balmain fan forced and grill. Does anyone know the cut out dimensions. I want to buy anew oven that will fit the existing opening. Thanks
when you buy the ovens replacement
instructions are given in the paper work how to adjust the cavity to suit
there will have to be an air gap on back and sides of the new oven
you should call an electrician to wire in the new oven
to check , even replace the 1987 wiring and connections
if needed to meet the 2016 house wiring standards
you will need
tape measure
pencils
a square
straight edge
reversible hand drill and bits
two levels .... for inside the cavity to level oven
approx a 15 inch .one 6 inch
a hand saw or circular saw
, i found a jigsaw helpful
self tapping screws different lengths
as per the oven fitting requirements
you can use any paint to finish the job
white board or MDF board is ok
some extras strips of timber to level the new oven
maybe required
if imperial was used for the cavity of the old oven
metric might be for the new oven
some DIY about wall oven installs are found on youtube
Oct 14, 2016 | Ovens
What are the dimensions of the space required to install an Omega Europa 20-1 oven under a bench
installation dimensions are included on the brochure of the unit
the brochure will be available from a retailer or on line and those dimensions are what builders use to make the right sized opening
Sep 09, 2016 | Ovens
What size circuit breaker for rbs305pr oven?
If you're connected to a 240V source, a two-pole 40 amp circuit is required. If connected to a 208V source, a two pole 30 amp circuit is required.
But the limiting factor here will be the wire size. If installed with #10 copper wire, 30 amp will be maximum. If a #8 copper (or #6 aluminum) 40 amp is maximum. See the link below for details.
http://www.whirlpool.com/digitalassets/GBS307PRB/Dimension%20Guide_EN.pdf
Sep 24, 2015 | Ovens
Please tell me if Electrolux EKG5547XN Cooker Main Oven Glass Door would fit my EOB6632U
Glass oven door is not compatible.
First of all, the oven door EKG5547XN has only two glasses, inner and outer, while the oven door EOB6632U has three glasses; inner, middle and outer.
EKG5547XN
Inner glass oven door, part number: 349 00 30-01/6, silkscreened; dimension: 456 x 323 mm, tempered glass.
Front glass oven door, part number: 349 10 45-14 / 6, stainless.
EOB6632U
Inner glass oven door, part number: 899661 92 68-78 / 3,
silkscreened; dimension: 479 x 391 mm, tempered glass.
Middle glass oven door: dimension: 447 x 380 mm.
Front glass oven door: dimension: 589,5 x 466 mm.
Dado
Mar 28, 2015 | Electrolux Ovens
Ovens Logo
73 people viewed this question
Top Whirlpool Ovens Experts
Dan Webster
Dan Webster
ashburton
Sal DeAngelo
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
