Question about Sharp R-1470 Microwave Oven
Remove microwave sharp r 1470 - Sharp R-1470 Microwave Oven
2 Suggested Answers
MicrowaveSvc
  • 9085 Answers
SOURCE: Sharp Carousel Over the Range
When you hit Start, does the oven lamp come on but not the fan or turntable?
That would be a problem with the secondary (bottom) door interlock switch or its mount.
This is usually caused by either a bad door switch, a loose door switch mount, or occasionally a problem on the control panel.
Even though a door switch clicks, it may still be bad inside. Its continuity must be checked.
Door switch or mount trouble can be caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
One test that sometimes helps is to gently lift up (and/or push down) on the door or handle as you try to start it. If it works or tries to work, then it's a door switch mount or door alignment issue.
If you or someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa:.
You can probably find exploded views and order parts by entering your model number here at the Sears parts site.
The best place to order Sharp parts is Tritronics.
If you think the problem is on the control panel, we repair these nationwide by mail for $39.95 postpaid in most cases.
Posted on Aug 21, 2008
I need an installation guide for my Sharp Microwave Model R1470. The installation template would also be helpful.
Did you try the Sharp web site?. The manuals for their products are usually there for you to download.
Feb 26, 2014 | Sharp R-1470 Microwave Oven
Fan and light stay on all the time,but everthing works ok
replace the IO circuit board.
thanks
please rate my work
Aug 27, 2011 | Sharp R-1470 Microwave Oven
I was cooking mac and cheese and it made a loud noise and just quit working nothing shows up checked breaker and it was fine so was outlet. Sharp R 1470
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Basic Microwave Oven TroubleshootingTips
heatman101
Mar 19, 2011 | Sharp R-1470 Microwave Oven
Can you please send me an instruction manual for sharp carosel microwave serial number R-1470A , bought it used with no manual ,
mcdevito75 here, Best bet, try to contact Sharp online, or see any store that sells Sharp microvave ovens in your area for contact info.
Jul 09, 2010 | Sharp R-1470 Microwave Oven
I have a Sharp model R-3A52,old but still cooks well. How do I know how many watts it is? I need to know how many watts my oven is?
The power of the magnatron should be on the door it will be about 750 watts. You could check sharp website to get it spot on...
Apr 06, 2010 | Sharp R-1470 Microwave Oven
Lost my instructions for my sharps microwave oven
just check the internet - there are many manuals websites, and sometimes even the manufacturer posts copies of their manuals
Get the model number for your microwave, then use on of the two sites below. hint: #2 Here are two sites: 1) http://www.usersmanualguide.com/sharp/microwave they will have your manual, but they'll charge you a few bucks for it 2) http://www.sharpusa.com/CustomerSupport/ProductDownloads.aspx These guys won't charge you a dime!!! Best wishes, Greg
Nov 28, 2009 | Sharp R-1470 Microwave Oven
More in depth please
All the microwave ovens that I have met come apart from the sides.
Jul 24, 2008 | Sharp R-1470 Microwave Oven
Fan button
Take out the screws holding the sheet metal case on.
Jul 23, 2008 | Sharp R-1470 Microwave Oven
Fans continues to run.
door switches or control circuit, may be loose contact or open check all wiring and circuit...
Dec 18, 2007 | Sharp R-1470 Microwave Oven
Oven stopped working. No lights, no control panel. nothing
It should be worth fixing. A microwave can be dead for many reasons.
If it goes dead for a while during or after cooking then comes back on, the magnetron is probably overheating and causing the magnetron thermostat to open. Then when it cools, it closes the circuit and allows power through again.
If it's intermittent or random, it may be a bad connection, usually on the control board or a loose fuse holder.
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
If it went dead a few seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
If it goes dead or blows the breaker when you plug it in or open or close the door, then there's a problem with a door switch or door switch mount.
If the fuse is good, it may be an open thermostat or thermal cutout on or near the magnetron or on top of the cavity / body of the oven.
If you or a friend decide to look into it, we have critical safety information and disassembly information at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
You can probably find an exploded view by entering your FULL model number (R-1470) here: http://www3.sears.com (the 3 is correct)
You can order Sharp parts from Tritronics at http://www.wehaveparts.com
Please write back with more details if you need further help.
We're happy to help and we appreciate your thoughtful rating of our answer.
Dec 17, 2007 | Sharp R-1470 Microwave Oven
Microwave Ovens Logo
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
