The hard drive has recently been formatted and XP Home reinstalled due to an 'Unrecoverable Error'. The laptop ran fine for 2 hours then suddenly showed a blue screen and switched off. I assumed that the unit had overheated so i opened it up, unblocked the fan and reassembled.
Now when the laptop is powered up the hard drive and cd drive start, but the fan doesnt run and the screen is blank. Then after a short time the unit turns off again.
Comments:
Mar 12, 2009
- how would i go about resetting the memory module? Are we talking about the RAM? And is it simple a case of removing it or is there some way of resetting it?
Shortly after I posted the problem on FixYa last night, the laptop worked again for a couple of minutes, then switched itself off and wouldnt start again.
The same thing happened again this morning, shortly after the Windows XP screen it died without any warning.
Thanks for your help
Mar 13, 2009
- The power light still stays lit but its as if power just stops for a second, the screen goes blank, but it doesnt seem to have switched off. If I try to restart the laptop after this has happened it just goes straight into this problem of blank screen, hard drive spinning, dvd-rom powered up, but nothing actually happening.
I had someone from Micro-Nano-IT.com give me a quote based on his assumption of the problem. He says "This needs a motherboard repair with the major BGA chipset", but im clueless as to why it suddenly started acting like this.
Try re-setting your memory module(s). They are usually found in an underneath compartment held in by one screw.
Comments:
Mar 12, 2009
- Hi, yes. It is also called RAM. Not resetting but re-seating. You would have to try and re-seat it. It's under a cover plate that is underneath the laptop. When I say "re-seat" I basically mean remove the memory and place it back in. After you remove the cover plate, you will see 1 or 2 cards inserted into slots. These are the memory modules. You may only have 1. On each side of the modules, you will see a clip. If you press these clip away from the module, the module will release and the memory will pop up toward you. You should remove it and then snap it back in again. Push down so it will lock into place.
Also, when you say "shuts down" do you mean the laptop completely turns off or does the power light still stay lit ?
I have a an Alienware M15X with an integrated webcam, however the webcam was not functioning...
(More)
I have a an Alienware M15X with an integrated webcam, however the webcam was not functioning properly, telling me that it was not turned on. I therefore went into device manager and turned it on, but in my camera software the image I was recieving was just vertical lines of colour. I then went back into device manager and uninstalled the webcam, restarted, and now I can't seem to find it anywhere. What do I do from here?
The 'N' key started to engage and many 'Ns' started to appear making any work impossible. It has got...
(More)
The 'N' key started to engage and many 'Ns' started to appear making any work impossible. It has got progressively worse ,and now it will not switch on even with mains power.
