Beko wm5100w the drum is making a banging noise
SOURCE: kenmore front load washer #44072 drum banging noise
I have the same problem...the solution is called new washer. I was told it could be overhauled to the tune about $600...barrings are going out. Mine is just 7 years old and that's disappointing.
Posted on Apr 03, 2009
SOURCE: my washing machine makes loud banging noise when spinning
there probaely a coin between the drum
Posted on Dec 28, 2009
SOURCE: kenmore washer started making banging noise in
Having same problem with my Kenmore 500. Tomorrow will be the second time a repair man has visited the house. Washer on 5 weeks old. Drum bangs every other load. Load not unbalanced. Avoid this washer, it is a POS.
Posted on Mar 30, 2010
SOURCE: BEKO WM5100W The pre wash light is flashing
hi - mine's just done this too; press and hold the two buttons above the padlock symbol until the light goes out. voila! that cost me 35 quid to an engineer but it's free to you... cheers!
good luck
Posted on Apr 29, 2010
Testimonial: "Thanks"
  • 420 Answers
SOURCE: Maytag Neptune MDE9700AYW Elec. Dryer. Drum Not Turning
the problem is with its motherboard .. i too had the same problem.. ask the repairing persons to change the motherboard if it is warranted. ( but there is no other way)..
Posted on Sep 10, 2010
Drum will not spin correctly
Sounds like the drum bearing is worn out or the rollers that support the drum are worn out.
Feb 13, 2014 | Bosch Neff Beko Dryer 263297
BEKO WM5100W , DRUM NOT SPINNING DURING WASH CYCLE
It could be carbon brushes or electronic fault.
Do you have ability to check carbon brushes?
Feel free to ask if you dont know how to do it.
Apr 07, 2013 | Beko Washing Machines
Beko 510w
the beko washer sometimes the concrete balance blocks come loose and cause a banging noise unplug and take the top off check the concrete block on the top off the outer drum to see if it moves about tighten it up if loose then check the one down the front to see if louse
Sep 20, 2012 | Washing Machines
I have a BEKO wm5100w and it has started making an awful noise when draining. Its definately not the spinning, ust the draining. It also leaves the clothes with a funny smell. What could be the problem?
hello sound like there could be somethink stuck the in the pump like a coin or metal also check the filter if it has 1 and check the drain hose. hope it helps
regards
shaun
Mar 27, 2011 | Washing Machines
I have a beko wm5100w washing machine and it keeps tripping the electricity
Hi, I have just come back from holiday. I turned on my beko washing machine,power comes on and when it starts it switches off the main electric box.before i went away i turned off the main electric box. Is the machine broken and if so expensive job?
Nov 25, 2010 | Washing Machines
Banging noise on spin cycle
My beko washing machine was making a racket like this. What it was was the large blocks of concrete bolted to the drum had come loose. Solution was to get a 13mm socket with a bar and extension and tighten them up really hard as far as I could manage. THen the probelm dissapeared no more banging. Worth a try if your has similar blocks attached to outer drum
May 09, 2009 | Washing Machines
Washing Machines Logo
47 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
