Question about Moen 6610 Brantford Two Handle Lavatory Faucet with Drain Assembly Chrome
How do you remove a handle for a brantford moen faucet?
dragonsthatk
  • 547 Answers
SOURCE: single lever moen shower valve -can't remove handle
if you have taken out screw then pull off if you have a handle puller use it
Posted on Feb 23, 2009
  • 374 Answers
SOURCE: Bathroom Faucet Handle Fell Off
There is a small allen screw in the base of the handle- the part the stem screws into to turn the water to the on position. If you have lost the one for your handle call moen at 1-800-289-6636 in the US. Their hours are Mon-Fri 8-8 EST and Sat 8-18:30 or follow this link MOEN. In Canada 1-800-465-6130 and hours are Mon-Fri 7:30-17:00 EST.
Posted on Mar 13, 2009
jj505
  • 195 Answers
SOURCE: Loose handle on my Moen single handle kitchen faucet
Yes it is fixable and easy.To save you time because I belive you will be needing a new part from Moen I am sending you this easy link to quickly resolve your issue. Just be sure to tell Moen you are original owner of faucet and all parts are lifetime free including shipping. Go Moen!!!
http://www.moen.com/contact.cfm?location=TopNavCustomerSupport
Thanks and Please Rate jj505
Posted on Apr 06, 2009
frcs68
  • 1605 Answers
SOURCE: hot and cold backwards on a moen shower faucet
tun off the water.
unscrew teh allen screw under neath the handle. pull out hteh handle. undo the wall plate and gain access to the cartridge in the handle body. turn the artridge around 180 degree and reisntall all parts.
SOURCE: handle won't stay up
I did the same thing recently, that is replaced the cartridge on my moen kitchen faucet to stop and leak, and I also have the same problem. I called moen back and they sent me another cartridge that was supposed to fit tighter, I suppose. I just put the new one in and it still wont stay up. I'm going to call moen one more time and then I guess I'll have to buy another faucet, but NOT moen!!! Good luck with yours.
Posted on Jul 22, 2010
How do I remove the cold water faucet cartridge on a Monen high arch, 2 handle w/sprayer, series 7700 Montecello
  • How to Fix Leaking Moen High Arc Kitchen Faucet -DIY blog.trebacz.com/2012/12/how-to-fix-leaking-moen-kitchen-faucet.html Video embedded · Our Moen high arc kitchen faucet started to leak around the base of the high spout. We had the Moen Monticello 7700 series single handle faucet for 8 ...
  • Frequently Asked Questions (FAQs) Regarding Moen Faucets www.moen.ca/consumer-support/faq ... a cold water filtering faucet, ... tighten the cartridge nut or replace the cartridge. If the faucet has a handle connector: ... Remove the faucet handle.
  • Monticello by Moen - Monticello www.moen.com/monticello/_/N-1z141yd Monticello. Chrome replacement handle knob insert ... As the #1 faucet brand in North America, Moen offers a diverse selection of thoughtfully designed kitchen and ...
  • Installation Help / Animated Tutorials for Moen Faucet www.moen.ca/consumer-support/installation-help Moen's animated tutorials provide installation help for many of Moen's ... How to Remove & Install the 1222 Cartridge. ... Removing a Single-Handle Kitchen Faucet ...
  • Contractor John replaces a cartridge in a Moen faucet ... www.youtube.com/watch?v=FqzpRE-MmEo
    • BY CONTRACTOR JOHN
    • 11 MIN
    • 279K VIEWS
    2011-10-26 · Contractor John replaces a cartridge in a Moen ... Repair Moen Single Handle Faucet, ... How to remove an old kitchen faucet and install a ...
  • May 05, 2016 | Plumbing
    How to tighten set screw on Moen brantford shower lever
    It sounds like the lever handle adapter may be broken or has become disengaged. . Remove the handle and inspect it. If the adapter is broken, it can be purchased at a plumbing supply house. Neither Home Depot nor Lowes will have it.
    Dec 12, 2015 | Moen Home
    How is the cartridge removed on the faucet?
    How To Repair Cartridge Sink Faucets at The Home Depot
    www.homedepot.com/.../project_guide_repairing_cartri...
    The Home DepotJul 22, 2013 - Quickly fix a leaky cartridge sink faucet with this detailed step-by-step ... On some models of faucet you may have to remove the cartridge with a
    Removing a moen cartridge from the faucet! If the plastic tool ...? 2:47https://www.youtube.com/watch?v=vGdExIS3b-oMar 5, 2013 - Uploaded by TheOldkid888This is a video on how to remove a moen cartridge from any moen faucet when the plastic tool does not do ...Installation Help / Animated Tutorials for Moen Faucetwww.moen.com/consumer-support/installation-help/tutorial?id...MoenUsing a Philips screwdriver, unscrew the handle screw and pull the handle up off from the faucet. Using pliers, loosen and remove the pivot retainer nut as well. Remove the washer from the cartridge and use pliers to remove the retaining clip.
    Dec 03, 2015 | Plumbing
    How do I remove the handle on a Moen Brantford doule handle lavatory faucet
    there has to be a small setscrew hole on either handle .otherwise they could not be repaired
    Feb 11, 2015 | Moen 6610 Brantford Two Handle Lavatory...
    How to remove moen bath faucet handle that has no set screws and is all 1 piece
    1.) its not all one piece
    2.) the tower threads onto the valve body, you may need to loosen the mounting nut under the sink top with a basin wrench to relieve the pressure on the handle tower
    3.) this is the exploded parts view for your faucet: http://www.moen.com/shared/docs/exploded-parts-views/s498pt.pdf
    4.) this is the instruction sheet for your faucet, including a technical support number you can call: http://www.moen.com/shared/docs/instruction-sheets/ins1207.pdf
    Aug 26, 2014 | Moen Showhouse S498 Savvy Two Handle...
    Have a moen brantford bathroom faucet. One handle has become very hard to turn. The hot water side turns fine, but you have to use muscle to turn on the cold. Does the handle need to be replaced or the...
    It usually takes a special tool to remove a Moen cartridge. Just getting the handle off can be tough. How long have you had this unit? maybe it would be cheaper just to replace the whole thing. My last Moen lasted a good twenty years, still working good, but finally starting to corrode. Good product.
    Nov 30, 2013 | Moen 6610 Brantford Two Handle Lavatory...
    Leaking CA87681 moen kitchen faucet
    Throw a cloth over the cover to prevent scratching the finish and grab it with a large pair of channel locks and unscrew it.
    Nov 18, 2013 | Moen 7907 Chateau Two-Handle Kitchen...
    Removing flow restrictor from Moen Brantford posi-temp shower he
    How I remove them is take a drywall screw and screw in to the flow restrictor. Then grab it with a pair of pliers and pull out.
    May 16, 2010 | Moen T2153BN Brushed Nickel Brantford...
    Moen 6610 Brantford Two Handle Lavatory Faucet with Drain Assembly Chrome Logo
    214 people viewed this question
    Top Moen Plumbing Experts
    john h
    Donni Steen
    Don Numinen
    Don Numinen
    Are you a Moen Plumbing Expert? Answer questions, earn points and help others
