Question about GE Washing Machines
Ge profile washing machine error code E00
Error code E00
SOURCE: GE Profile Prodigy filled with water & won't start
If you don't hear a click when you close the lid, replace the lid switch.
Posted on Feb 01, 2008
SOURCE: ge profile front load washing machine demo mode
I called General Electric and this is the solution:
unplug the machine for 2 to 3 minutes.
Plug it back in the wall
Do not put the power back on.
Open the door
Press the start/pause button 5-6 times
The display will say demo exiting...
This works. Also don't forget to remove the shipping bolts before starting your washing machine!!
Good washing!!
Posted on Apr 10, 2009
  • 130 Answers
SOURCE: GE Profile washing machine not finishing cycles
the OL error is for over load.that is when you over load the clothes in the washing machine. If your washer doesn't spin or agitate on either the delicate or regular cycle, check these:
Selector switch
Clutch assembly
Drive motor
Selector switch If your washer has a selector switch on the control panel, make sure the button for your selection is pressed all the way in, or set properly.
Clutch assembly Many GE®/Hotpoint® washers use a clutch and an automatic shift lever. This assembly is quite complicated. If there's a problem with it, you probably should contact a qualified appliance repair technician.
Drive motor Many washing machines have multiple-speed drive motors. Though it's uncommon, the drive motor may work fine on one speed but not on another. If the drive motor has failed on one speed, you need to replace the entire motor.
Posted on May 07, 2009
  • 47 Answers
SOURCE: ge profile washer has a d5 code that is displayed machine
CHECK THE TIMER. I DON'T KNOW IF THAT IS WHAT IT IS, BUT IF IT IS YOUR TIMER, YOU NEED TO CALL A REPAIRMAN AND SEE IF HE CAN FIX IT FOR YA. HOW OLD IS YOUR WASHER?
RODNEY
Posted on May 15, 2009
hsanfor
  • 71 Answers
SOURCE: GE Profile Performance washing machine does not turn on
Use another device to determine if the outlet you are moving to is good. If it is then try the wash machine in the previous outlet, if it does not work there a fuse may have been blown.
Posted on Jun 19, 2009
My Electrolux washing machine is showing error codes MB Alarm E33, and UI Alarm E00. It has stopped working altogether. Door wont open and clothes are stuck in ther. I have run a diagnostic test and it...
I appreciate your post, Anonymous!
From what you have described your Electrolux washer is displaying an error code of MB, E33, and UI Alarm E00. I have been unable to locate those error codes. May I have your model number, please? With that information I will be able to assist you further. -Matt
Mar 19, 2015 | Electrolux Washing Machines
What is electroklux washer code E00
Hi friend, thank you for your inquiry!
On an Electrolux washer the error code "E00" stands for No code stored. This could be a miscommunication I would recommend you perform a reset on your washer. You can do this by flipping the household breaker for roughly ten minutes. If resetting the power does not correct the issue, could you please inform me of the new error code or if your washer continues to display "E00". I look forward to assisting you. -Matt
Aug 14, 2014 | Electrolux EIFLW55HIW Front Load Washer...
E00 code what does this mean
Hi William, thank you for your post!
If you are getting error code E00, it usually indicates that your washer is experiencing a generic error. One of the best ways to determine if this is a false error code is to reset the power to the appliance by either unplugging it or flipping off the breaker for about 30 seconds. If the error code
Nov 29, 2013 | Frigidaire Affinity ATF7000E Front Load...
Got an error message E43 model WPRB9220D0WW
E43 is for "excessive drive system brake time"
Reset with
1) unplug 3 seconds,
2) hold Power & Start to display "Jr",
3) cycle thru using the Custom 2 button (3 times) to display E43,
4) hold Power & Start to clear code to E00,
5) stop.
Jun 29, 2011 | GE Washing Machines
Ge WCVH6800 front load washer. Power was interrupted during washing cycle. Machine counts down 3.6 minutes, then goes off. How do you correctly reset cpu or test system
Here how you "test" the system: http://www.fixya.com/support/t9576766-found_small_part While in test mode "t02", you can reset all the error codes by holding down Start until it displays E00. If you find errors in the t02 test, make sure you write them down before clearing.
Dec 11, 2010 | General Electric WCVH6800J Front Load...
Washing Machines Logo
91 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
