Question about Vacuums
Ciroa steam release button - Vacuums
Sc20 trigger does not release steam
Clean jet(s) where steam comes out from . They may be clogged.
May 19, 2015 | Top Vacuums
I'm not able to release the steam head. I push the button but it will not release.
You will have to take the trigger mechanism apart as the catch has jammed. If it's less than a year old, take it back and get a new one under warranty.
May 13, 2015 | Shark Rotator Vac-or-steam 2-in-1 Hepa...
My compact steamer does not let the steam out when I press the black release button help?
I examined mine. There is literally NO hole in the steam wand for the steam to exit. It's a wonder the thing didn't blow up. Take it back and be glad you still have your face.
Jan 01, 2015 | Top Vacuums
I have a Shark Steam Mop S3501CO model. When I press the release button to exchange mop heads, the mop head does not release. Nils Friis
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
That head can stick very tight...get someone to hold the head and you pull the mop...
The heating element may have died or there is an obstruction...
Here is a tip that I wrote about the Euro-Pro Shark Steam Mop and why it may not be getting steam to the head...
Euro-Pro Shark Steam Mop Problem
heatman101
Aug 02, 2010 | Euro-Pro Shark Steam Mop - Gray/ Purple...
When I push the button to release steam on the handle it feels soft and no steam is released. It has been going out for a while now.
I didn't fix the problem but I did take the handle apart. There is a little metal piston that is pushed down by the button on the outside of the handle. It was very sticky and stuck in the off mode. I freed it when I took it apart but obviously it just stuck again. I am going to take the handle apart and see if a little WD40 will make it easier to push. Either that or glue it in the "on" position. I really love this appliance and if I can't fix it, I'll probably just buy something similar.
Jun 29, 2009 | Steam Fast SF-275 Steam Max Canister...
Edmark steam brush
Hi
press small release button on steam supply cotroller lever and pull the lower portion towards you
. now inyour righthand is your water filling tank . open the cap 7fill baout 100ml of water & close the cap put this back to the main unit just by gently pressing towards to the unit
It is done nolw wait for 30 sceconds & start using
Thanks
Aug 03, 2008 | Vacuums
Heats up and produces steam but the release button does not open the flow of steam.
To remedy this, I did the following:
1) Removed screws from: a) Lower area of handle (1 screw), b) Top of steamer, under round rubber flap around fill hole (2 screws), c) Front of steamer where nozzles attach (2 screws)
2) Removed back of handle, top of steamer, front of steamer where nozzles attach
3) Once all parts are removed, you can see a brass button that is pushed by the trigger
4) Using a needle-nose pliers, grasp and rotate the button several times in both directions (you may hear it cranking against the interior spring). Do this until it turns fairly easily with the pliers.
5) Once this is done, you fill find that the brass button can be very slightly depressed with a bit of force. You may also need/want to unfold a large paper clip to push into the nozzle hole to help unsticking the brass button (not sure if that helped in my case, but it was something I tried along the way). When the brass button moves in and out (again, it won't move much), the steam release mechanism is unstuck!
6) Reassemble all parts (everything snaps back neatly into place).
This worked for my unit!
Nov 11, 2007 | Scunci 52067 Handheld Steam Vacuum
No steam release
I solved the problem, the metal (hot!) release rod gets stuck & needs a little push.
Unfasten the top by prying off the rubber gasket after removing the top. Remove the 2 small phillips screws, then remove the front that holds the nozzle, & remove those 2 phillips screws.
Carefully pry up the top with a putty knife, inside you will see the tip of a metal piston that the plastic release knob is supposed to contact. Set it on its front, & soak the piston with a light household or sewing oil, giving it a few taps with a blunt object occassionaly to loosen, heat up & test before reassembling, but remember, the piston is very hot. When you push on the piston with a screwdriver, it should release the steam, but also stop when you let go. Work with it a little & it will come back to life.
Dec 12, 2006 | Euro-Pro Super SC710Z Steam Vacuum
Vacuums Logo
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
