I have an emachine and installed airlink 101 ,,keeps kicking me off line..what do i do? i am online for 5 minutes then it kicks me off IE. says i am still connected.. HELP!! thanks
  • 7,733 Answers
The following wireless access points/routers have been tested for use with the SoundBridge and SoundBridge Radio. While Roku is unable to provide testing results for all available wireless access point and routers, the vast majority will work fine with your SoundBridge product. We encourage you to try using your SoundBridge with your existing wireless equipment, regardless of published result before replacing your current hardware.
The current SoundBridge models, M1001 (connections on the back) and SoundBridge Radio R1000, use different wireless hardware than the older M1000, M500 and M2000 models (connections under the endcaps). This newer hardware has proven considerably more reliable than the older wireless hardware and should work out-of-the-box with virtually any 802.11b-compatible wireless equipment you may have. Compatibility of the older hardware has been improved over time and we recommend that you upgrade your SoundBridge's software to the latest version as soon as possible, particularly if your SoundBridge was delivered with software older than version 2.3.44. Upgrading older software may require using a wired ethernet connection or even taking your SoundBridge to a neighbors house or your office to sucessfully perform the upgrade.
To check your software version and perform an upgrade, use your SoundBridge remote control to navigate to the menu Change Library or Configuration -> System Configuration -> Software Version and Updates and follow the on-screen instructions.
If you still experience Wi-Fi connection problems, check the following items:
  • Make sure your access point/router is configured to allow 802.11b devices to connect. This may be phrased as "Mixed mode" or "802.11b +802.11g".
  • If you have wireless security enabled, make sure it is a supported protocol, and make sure you are using the "Hex" key. See your SoundBridge manual for more information.
If, after checking these items, you still cannot get your SoundBridge to connect to your wireless network, we encourage you to contact support or visit our Roku Community Forums where other customers and Roku employees will attempt to help you.
Bold = recommended by Roku for use with the latest version of SoundBridge software.
Red = poor performance or incompatible with SoundBridge
* = customer tested - your results may differ.
Model M1001,
R1000
M1000,M500,
M2000
Notes Airlink101 AR410W Yes Yes Fast! Apple Airport Extreme (Snow) Yes Yes Buffalo WBR-G54 Yes Yes Very reliable Buffalo WBR2-G54 Yes Yes
D-Link DI-514 B1 Yes Yes
D-Link DI 624 Yes Yes D-Link DI 784 Yes Yes D-Link DIR-655 * Yes Yes Set to b/g or b only. Problems reported in b/g/n mode. Linksys WAG300N * Yes Yes Disable wireless AP isolation. Linksys WRT51AB Yes Yes
Linksys WRT54G Yes Yes
Linksys WRT54GC Yes Yes Linksys WRT54GS Yes Yes Works great Motorola WA840G Yes Yes Works great Motorola WR850G * Yes Yes Wireless mode should be set to Compatibility. Problems have been reported with using Performance wireless mode. Netgear DG834Gv3 * Yes Yes Firmware v4.01.06 may be required for internet connectivity and WPA. Netgear DG834G Yes Yes Netgear WGR614 v5 Yes Yes Netgear WGT624 (all hardware revisions) Yes Yes Netgear RangeMax WPN824 Yes Yes Works great. Siemens GigaSet SE361 * Yes Yes SMC SMC2804WBRP-G Yes Yes Needs firmware v 1.956 or greater SMC SMC2804WBR Yes Yes
USR 8054 Yes Yes Needs firmware v 1.64 or greater XRouter Aero WSR-5000 Yes Yes ZyXEL Prestige 335WT * Yes Yes AirLink AR315W Yes Yes Poor performance Airlink AR420W * AP/Router/Switch No
AVM 3070 * AP/Router/Switch No
D-Link DI-524 AP/Router/Switch No Some users report this router works fine for them. Linksys BEFW11S4 No No. Performance is unacceptable Linksys WRT54GL * No No Downgrading to original firmware fixes rebuffering issues. Linksys WRT54GP2 Yes Yes Very slow performance Linksys WRT55AG Yes Yes Works, but some customers have reported issues with accessing the Internet through this device Netgear FVM318 Yes Yes May work for some, does not properly route UPnP discovery packets between wired and wifi Netgear MR814V2 Yes Yes Poor performance Netgear WGR614 v4 Yes Yes May require B-only mode . SpeedTouch 716G * Yes Yes Can connect wirelessly and stream locally, but no internet access. USR 5462 Yes No
Note: If your wireless access point does not work well with the SoundBridge, please make sure that both the SoundBridge and the access point are using the latest firmware available.
Posted on Apr 21, 2013
kakee
  • 1269 Answers
SOURCE: keep getting kicked off xbox live
You should reduce the MTU of your router. You can simply call Belkin support for them to assist you on how to reduce the MTU.
Posted on Oct 27, 2008
  • 55 Answers
SOURCE: i keep losing my internet
i request u return the router and get anything but a dlink.
that will solve anything
Posted on Jan 18, 2009
kakee
  • 1269 Answers
SOURCE: Can't block url's domains on Airlink 101 router AR680W
You need to update the firmware of your router for this feature to work.
Posted on Apr 01, 2009
  • 55 Answers
SOURCE: my xbox keeps kicking me of line done test and
Try to open ports on your netgear router, here's what you need to do:
Step 1:
Setting a Static IP Address for your 360
The first thing we need to do is give your 360 a static IP address. Turn on your 360 and go to the dashboard. Once you are at the dashboard, go over to the "System" Blade and select "Network Settings".
Under the "Network" Blade, we need to select "Edit Settings".
You will now be presented with the basic network settings for your 360. From here, you need to highlight the first section labeled "IP Settings" and select it.
From this screen, choose "Manual".
Now we will need to change all of the headings in this section 1 at a time. First will be IP addrress. Depending on what type of router you have, the settings will be differrent. Find your router brand below and enter the appropriate settings. If your router brand is not listed below, contact me, and i'll help you find the appropriate settings.
Linksys
  • IP Address : 192.168.1.250
  • Subnet Mask : 255.255.255.0
  • Gateway : 192.168.1.1
  • DNS : 192.168.1.1
D-Link
  • IP Address : 192.168.0.250
  • Gateway : 192.168.0.1.
  • DNS : 192.168.0.1
Netgear
  • DNS : 192.168.0.1
After you've entered all of your settings, select done, and we'll move on to the DNS settings. After selecting done, you'll be brought back to the basic settings menu. From here, you need to highlight the "DNS Settings" section and select it.
In the "DNS Settings" menu, select manual and then primary DNS server. When the entry box comes up, enter the settings listed above for your router brand and select done. A message will come up asking you to test and save your new settings. Select test live and press A. If you are currently signed into live, you will be logged out so the tests can run. At this point if you followed the instructions, everything should pass or be confirmed, and your NAT status will likely still show "moderate". This is normal. You still need to complete step 2 to open this up. We are now done with step one, so click on the the "Step 2" link to continue to the next step.
Step 2 Setup Port Forwarding on Your Router Setting up port forwarding is simple and should only take you a few minutes. During the process you're going to need to be at your computer in order to change your router's settings. The process will be a little bit differrent for each brand of router, so find the instructions for your router and follow those. As always, if you run into any problems, you can contact me using the contact info from the main page. So lets get started. Since at the moment I do not have a Linksys router, the images included below are "borrowed" from a great site, PortForward.com. They have a wealth of information about port forwarding, so if you are interested, check them out.
Once you are in, you should see a screen similar or exactly the same as the one pictured below.
From here, you need to click on the "Applications and Gaming"tab. You will see on this tab a few subheadings. Click on the subheading labeled "Port Range Forward".
The following ports must be available for Xbox Live to operate correctly:
• UDP 88
• UDP 3074
• TCP 3074
Now to the final step...testing. We get to see if all of your hard work paid off, or if it was a waste of time and i'm a bumbling idiot! Now the first thing we need to do is turn on our 360 and get to the dashboard. Navigate over to the settings blade and select "Network Settings" and select it. On the next menu, select, "Test xBox Live Connection". If you are logged into live, you will need to be logged out for the tests to run. After the tests finish running, you should have the following results:
  • Network Adapter: Wired or Wireless (Depending on the connection type used
  • Wireless Network: varies (depends on if your are connected wirelessly)
  • IP Address: Conirmed
  • DNS: Confirmed
  • MTU: Confirmed
  • ICMP: Confirmed
  • Xbox Live: Confirmed
  • NAT:Open
If your tests show everything as stated above, congratulations, you are ready to play. If not, you screwed up and need to go back and read the directions again.
Posted on Jun 29, 2009
SOURCE: I CAN'T ACCESS INTERNET ANYMORE VIA AIRLINK AR325W ROUTER
problem resolved. thank you.
Posted on Oct 15, 2009
Linux driver / cheapset / firmware
Which version and kernel of Linux are you running? That does make a difference. Post back with more info, please.
Sep 17, 2013 | Airlink 101 AWLL5088 Wireless N 150 Ultra...
EMachines eMD620 suddenly shutdown and not boot anymore
When this happened was the laptop overly hot? If the laptop's head got too high it could have shutdown to protect itself. It wouldn't boot until the heat had disparate. Sit you laptop aside for about 30 minutes and see if it will boot then. If it does you might want to check out a cool mat.
http://www.amazon.com/gp/product/B008TO35G0/ref=sr_1_3?ie=UTF8&qid=1358444754&s=pc&sr=1-3
Jan 17, 2013 | eMachines eMD620-5133 Notebook
Refrigerator model bx21vl does not cool. I can hear the compressor kick in but it kicks out in 5-10 seconds. Then after about 102 to one minute it kicks in and out again,
Compressor is tripping on overload. You may just need the overload and relay replaced due to a bad compressor relay. The relay is what switches the compressor from it's start winding to it's run winding. If you pull the relay off, shake it to see if you hear lots of rattling inside, that's a sure sign of a bad relay. I would replace both of them.
Here is the overload relay to order.
Here is the start relay to order.
Nov 27, 2012 | Refrigerators
2004 Pontiac Grand AM Transmission ISSUE
check for a pinched or crushed trans cooler line going to the radiator i have seen them crushed from running the car up against parking curbs, underneath the radiator
Sep 08, 2012 | Cars & Trucks
My 1995 YJ 2.5l m5 is having an electrical problem. when you first turn on the key, nothing happens. If you leave the key on after a while the fuel & shutdown relays start clicking. After a minute...
sounds like a ecm issue. Had the same problem with my 1995 wrangler and the time you had to let it sit before fuel pump kicked in got longer and longer until it wouldn't kick in at all. Ordered a rebuilt computer online and after i installed it i kicked right over.
Sep 20, 2010 | 1995 Jeep Wrangler
After logging in to the dial-up after about 5 minutes it kicks of line.the dial-up company says shows we are online
If you can get cable internet service, it will fix that problem. Your modem transfers 54bps over a phone line that transfers other info over that same line so from the service side of that deal you get the drops time from the internet. It's called (timeout from the internet protocal).
Apr 25, 2009 | Compaq Presario SR1111NX (PC146A) PC...
Need password or paascode
addy is http://192.168.0.1
no user name
password = PASSWORD
Apr 12, 2009 | Airlink Computers & Internet
Apr 01, 2009 | Airlink AR430W Wireless Router
E machine
have you changed your os
how old is the machine
do a virus scan
does it stay on in safe mode
Jan 10, 2009 | E-Machines eMachines Desktop PC
Computers & Internet Logo
126 people viewed this question
David Payne
David Payne
