Question about Garden
Need valve settings for 13.5hp ohv vanguard
Briggs and stratton, vanguard, 13..5 hp ohv. Need valve settings.
  • 1 more comment
  • Dennis Key
    Dennis Key Apr 21, 2013
    Tells you the valve setting. I wound go with .004"
  • Dennis Key
    Sorry .004 on both intake and exhaust.
  • Dennis Key
    Dennis Key Apr 25, 2013
    Go to briggs&stration.com And download a Check Chart. Lots of infor.
  • Garden Master
  • 2,478 Answers
Your owner's manual tells you
Posted on Apr 20, 2013
  • earl Apr 21, 2013
    Hi there...thanks but all I get here is.."Your owners manual tells you..." Tells me what?
  • earl Apr 22, 2013
    Thanks for the needed info. Old second hand machine and no owners manual.
jgwhomeequip
  • 1902 Answers
SOURCE: 31p777 18.5 hp briggs & stratton valve cover leak
Both can cause problems. It is recommend that you do not go on a grade more the 10% for your safety and the safety for others around. But if the valve cover is leaking this can lead to major problems if not repaired on a timely matter
Posted on Apr 29, 2009
panilling9
  • 284 Answers
SOURCE: hard to start 18 hp briggs &stratton
cold engine
loose .002 exhaust
loose .004 intake
be sure both valves are closed and you are on top dead center TDC of the compression stroke when setting
Posted on Jun 21, 2009
SOURCE: wiring diagram for a E2000 greenfield, OHV Vanguard motor
Hi...How did you go? Did you end up getting one? I need the same if you can helkp me out. Cheers Glen
Posted on Dec 05, 2009
MNfisherman
  • 11896 Answers
SOURCE: lack of power and ''pops'' back through carb
I believe you have an air intake gasket leak or your carb is not properly adjusted. How is the spark?
Posted on Jan 13, 2010
  • 12104 Answers
SOURCE: My 24hp Briggs and Stratton ohv engine has bent push rods.
unable to answer if valve opened or not but does sound like ur bottom valve is bent or piston made contact and bent it to fix need to remove head and replace valve also need to inspect piston face is not damaged from possible contact
Posted on Apr 12, 2010
Briggs and Stratton 23 hp lawnmower engine exhaust valve keeps sticking
it is possible that the valve stem is bent or has a build up on the stem that is jamming in the guide. Pull the head and replace the valve.
Sep 27, 2013 | Briggs & Stratton Briggs Stratton Vanguard...
Runs good-but has no power under load
reset the valve clearance to .010 and .012 as they will holding open when hot and upsetting the carby flow
May 27, 2013 | Briggs & Stratton Briggs Stratton Vanguard...
Will not start. but if I pour gas in carburetor it will. stop after the gas is burn of carburetor
Could be that the needle is stuck in carb, or else the fuel pump diaphragm is bad. Check the pump, thats what I would check first.
Jan 24, 2013 | Briggs & Stratton Briggs Stratton Vanguard...
Torque specs. for a briggs @ stratton 24hp. head bolts
WHAT IS THE VALVE CLEARANCE ON A 23 HP. BRIGS MOTOR AND THE TORQUE ON THE HEAD BOLTS?
Jul 17, 2012 | Briggs & Stratton Briggs Stratton Vanguard...
Briggs and stratton vanguard 16 hp v-twin starter replacement
It most Likely is located under the engine cover..it mount just below the flywheel. Good luck
Apr 11, 2012 | Briggs & Stratton Briggs Stratton Vanguard...
18 hp vanguard 165lbs and 180 lbs compression have to hand turn engine past compression or starter wont turn engine over
if its hard to get the engine to turn past the compression release then pull your valve coversand try setting your valve lash
.006 on intake
.008 on exhaust
Oct 25, 2010 | Briggs & Stratton Briggs Stratton Vanguard...
I have a 23 hp Briggs vanguard engine-V Twin Model 380447/type 76-E1 code 4241. The engine is less than two mowing seasons. The engine will not turn over properly and I have used another start I have and...
It will probally be your valve setting might be off so pull the valve covers off and try setting your valve lash
Heres the factory settings
.006 on Intake
.008 on Exhaust
Sep 05, 2010 | Briggs & Stratton Briggs Stratton Vanguard...
Valve clearance?
The Briggs & Stratton website should be able to provide this information.
Aug 30, 2010 | Briggs & Stratton Briggs Stratton Vanguard...
How to change electric starter on vanguard 14 hp v twin vertical shaft.
Please, help me to regulate valves on Vanguard B&S 14HP OHV model:294446 tip:1141-a1. I don't know how. Thenks. My adress kolya-kolyanof@rambler.ru
Mar 31, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Garden Logo
130 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
