I NEED A SERVICE MANUAL FOR A ABIT NF8-V PRO MOTHERBOARD
I NEED THE WIREING TO TURN ON & OFF BOTTON & HDD SPEAKER WIREING & POWER & LED WIREING .
Via abit-nf8 motherboard manual
Hello download the manual here:
http://www.elhvb.com/supportbios.info/Archives/MANUAL/ABIT/nf8_series.pdf
You need a PDF reader to read content.
Good luck
Oct 14, 2012 | Asrock ALiveNF6G-VSTA (MB-ALVNF6G)...
Reconnecting the pwr switch and HDD Led wires,etc
Hello here are the manual in pdf:
http://pclap.hu/driver_files/nf7_series.pdf
You will need adobe reader, to read content.
The front panel connector, look likes this:
Here are the abit homepage:
http://abit.ws/page/mi/download/download_driver.php@pFUN_KEY=9000&pTITLE_IMG=_2Fdownload_2Fimages_2Fdownload.html
Good luck
Sep 24, 2012 | Abit nForce2 NF7-S2 Motherboard
I have installed my abit nf8-v2 motherboard into my computer but i can not get my computer to power on. LED 2 is turning on but not LED1
Please verify that you have completed the following:
  1. Connected the cables from power supply to the motherboard
  2. Connected the processor fan power connector
  3. Installed the memory correctly
  4. Connected IDE/Sata cables correctly
  5. Processor installed correctly with fan sitting correctly
Feb 08, 2011 | Abit NF8-V2 ATX Motherboard with NVIDIA...
I have an Abit NF8 series motherboard and am using a amd 3200 --- I am wondering if I can but in a bigger processor as I am running 2.2 ghz and I need 2.6 for a game I would like to play. Is it...
You can put in bigger processor, Any AMD Athlon or Sempron will do.
If you are planning to run big games, then I suggest you get
- A new motherboard with PCI Express 2.0 support
- A new processor
- A new graphics card (maybe 512 MB or 1 GB) with DirectX 11 hardware support and Shader Model 5
You may make that DirectX 10 or 10.1 and Shader 4 if you want to reduce cost.
Aug 13, 2010 | Abit NF8-V Motherboard
Trying to install Windows XP SP1 onto HD with this Motherboard. System will not boot from HD to start install.
Make sure your IDE hard disk drive is connected to IDE1 port and that the data cable is fully connected. Also check the jumper on the IDE drive. If you are using only one IDE hard disk drive set the jumper on the drive as a Master without a slave. If you are running two IDE hard disk drives set the primary drive's jumper as a Master with a slave. Set your second IDE disk drive's jumper as a slave. The master drive should be connected at the end of the data cable and the slave drive should be connected to the next data connector. Than check your bios settings. Power on the system and press the Delete key every 2 seconds until the bios menu loads. See page 3-1 in your manual. If you need the manual for the NF8-V MB click on the link provided below and download it;
http://www.abit.com.tw/page/en/motherboard/motherboard_detail.php?pMODEL_NAME=NF8-V&fMTYPE=Socket+754
You'll also need the program Adobe reader to view the manual. Adobe reader is a free download; http://www.adobe.com/products/reader/
Once you’re in the bios go to page 3-4, Standard CMOS Features.
Follow the instruction listed for IDE HDD Auto-Detection. Your HDD should be listed here. Than see page 3-7 in the manual. Open Advanced BIOS Features. A normal boot menu for the Abit would read;
First boot device Floppy disk drive (If one is connected). 2nd boot device should be (CD-ROM/DVD-ROM). Third boot device should list your primary hard disk drive's (Model number). Load your windows CD into your CD-ROM drive.
Once the settings above are set, press the F10 key to save your changes and exit the bios. Your system will auto restart. Windows should begin to load.
Cheers!
Mike
Nov 18, 2009 | Abit NF8-V Motherboard
Cant find the manula anywhere. can you help?
Try visiting http://www.abit.com and fnd the users manual from support or download section.
Jul 11, 2009 | Abit IC7-MAX3 Motherboard
Light comes on but doesn't power up
Do you have both power connectors plugged in? The main is a 20 or 20+4 pin that is located near the front of RAM sockets. The other is either a 4 or 8 pin plug that should have a connector near the cpu socket. Both need to be plugged in for the board to boot up.
Jul 10, 2009 | Abit NF8-V Motherboard
Abit nf8-v keeps beeping when turned on. no video
How is the beep sounds? Long beep and three short beep or one (-...) or all long beep?
For the first, usualy the VGA connector is not correctly seated, so the motherboard can say it has no output device and beeping.
The last is usually memory problem. Try, unplug your memory board and replug it again, make sure that it is correctly seated.
Dec 10, 2008 | Abit NF8-V Pro Motherboard
Computers & Internet Logo
44 people viewed this question
David Payne
David Payne
