How to connect bose av3-2-1ii gsx media center to HDMI
How to connect a bose av3-2-1ii gsx media center to HDMI
SOURCE: No power to the Acoustimass bass
Hi, have you checked the internal fuse in your sub?
Posted on Dec 22, 2007
quang123
  • 107 Answers
SOURCE: TV audio through Bose Lifestyle 38
Did you select TV input on your AV38 Bose system and same thing for VCR. it should work unless from your TV audio if you watching HD signals some of the program had copy protection so it turn off the video and audio out at your TV output monitor that for TV
For VCR it must work make sure you select VCR input on your AV38
I hope that give some ideas
Posted on Dec 15, 2008
SOURCE: How do I connect my iPod to Bose Lifestyle V20 System
You can only Connect a iPod via a iPod dock
Apple iPod Univeral Dock
and use either
Apple Composite AV Cable or Apple Component AV Cable
based on what Output you iPod Allows.
the list of which iPod that is supported is listed on each page of the AV Cables above.
You can use a IR Blaster Cable with the iPod Dock to control the iPod also.
Posted on Feb 01, 2009
  • 5 Answers
SOURCE: Connection to Bose V30 System
check hdmi setting from ur tv and ur dvd connection
Posted on Nov 11, 2009
SOURCE: Cannot connect iPod to Bose Lifestyle V20 System
On the side of the V20 control box (with all the inputs/outputs on the back), there is a small jack for an input directly from the headphone output from your Ipod - so all you need is a male/male ended cord (like the one used in vehicles with AUX inputs) and plug in - SIMPLE!
ENjoy
Posted on Jan 18, 2010
I have a bose av321 series2 gsx media center and satellite speakers and also have cinemate subwoofer need to connect them is it possible
  1. Probably not. Bose has their own laws of acoustics and all eq. and crossover points are done inside. You need a separate crossover component to accomplish this. From a professional viewpoint, we always say BOSE = Buy Other Sound Equipment and the EQ/Crossover/phasing trickery inside every Bose system is a large reason for this.
Nov 15, 2017 | Bose Audio Players & Recorders
I have a bose 321 system and I want to hook up HDMI cable, is there any way I can hook them up?
You must have been provided with a user guide/manual along with Bose 321 system . Follow the instructions on Set up 4 at page 12 wherein details have been given to connect HDMI cable along with the diagrams. Follow it. If you do not have the manual go to the following link and down load the manual in pdf
http://products.bose.com/pdf/customer_service/owners/AM312515_01_321_SeriesIIIandGS_OG_ENGvo.pdf
Sep 20, 2011 | Bose 3 2 1 GSX System
Have a Bose 3-2-1 Series III. When I put in a DVD, I get sound through the Bose but no picture on my Pioneer TV. This is the second time it has happened. The first time it, we managed to get it going...
Here are 3 things to try and an if all else fails at the end.
1) Make sure the TV is set to the correct Video Input to see the video from DVDs on the Bose system.
• Make sure a DVD is in the disc tray.
• If the TV is connected to the media center using the HDMI cable:
Switch from one Video Input to another and then back to the original input.
2) Turn everything off, then:
Turn on the TV and set the TV Video Input for the Bose system video.
Turn on the Bose system and press DVD.
3) Turn off both the TV and the Bose system and then:
Unplug the HDMI cable from both ends.
Disconnect the power cables from both your TV and the Bose 321 system.
Re-connect power to the TV and to the Bose 321 system.
When the Bose 321 system startup message disappears from the display,
re-connect the HDMI cable to the TV then Bose 321 system.
Turn on the TV first, then turn on the Bose 321 system.
If all the above fail then disconnect the HDMI cable that connects the TV to the Bose 321 system and reconnect the two using a Component cable, an S-Video cable, or the Composite cable provided with the system.
Please leave feedback
Cheers
Andy
Apr 28, 2011 | Bose 3·2·1 II System
I have a Bose 3.2.1. GSX Series 3 system. Recently, when playing DVD's I am getting sound only and a message on the TV screen saying 'No Signal' and on the 3.2.1. display 'communicating with your TV'....
Possible faulty lead or a poor connection. Has the new Sky Box been fitted to the HDMI socket the Bose had? Try switching sockets if there is more than one HDMI socket.
Jun 02, 2017 | Bose 321GS Series II System
Cd music is skipping on bose 321 system and one channel of dvd audio will stop playing. Disk player has also started making loud vibration noise after loading dvd or cd. This didn't used to happen. On CD...
The Bose® 3·2·1 GSX Series III DVD home entertainment system puts you at the center of exciting home theater with just two visible Gemstone® speaker arrays and a hideaway Acoustimass® module. Setup is simple because, unlike traditional five-speaker surround systems, there are no center or rear speakers. An elegant media center features a progressive scan DVD/CD player with an HDMI output and AM/FM tuner. You'll enjoy vivid detail in your movies and sports with video resolution up to 1080p over HDMI.
Apr 04, 2010 | Bose 3 2 1 GSX System
Nov 08, 2009 | Bose Lifestyle V30 Home Theater System -...
Model Av 3-2-1 ii media center will not turn on
Double check the power cable thats plugged into the sub, and all other connections. If thats not problem the unit is toast and you should contact bose about waranty and or parts replacement.
Jun 19, 2009 | Bose 3 2 1 GSX System
Faint sound when watching TV with Bose GSX 321 System
I connected my surround sound to the audio output on my samsung tv and it works fine. Of course I don't have an hdmi input on my surround sound system because its an older model, but it works great. Just got to put the surround sound to audio instead of dvd or tuner setting
May 07, 2009 | Bose 3 2 1 GSX System
Bose 38 with a Scientific Atlanta 8300 HD DVR and Epson Projector
The Bose VS2 does not pass the HDMI audio. Must connect analog or digital audio direct to the corresponding audio input on the media center. Also, verify you have loaded laster Console Software revision provided by Bose.
Jan 17, 2008 | Bose Lifestyle 38 DVD Home Entertainment...
63 people viewed this question
 Grubhead
Grubhead
