I have an unregistered Emailer plus. Is there anyway to bypass this so that the great phone book and answer machine can be used?
SOURCE: answering macihne won't answer, disconnects after a few minutes
unplug your unit and allow it a few minutes to reset it's self. than call it using a cell phone and see if it does the same thing. If so check you menu option and make sure that the anserwing machine is not set up to only record for a certain period of time before disconnecting the call.
SOURCE: BINATONE ELITE PLUS MICRO DECT WITH ANSWERING MACHINE MANUAL
I have a Unidan Dect 6.0 and I can't get a dial tone and I can't find my manual.
SOURCE: My Amstrad Emailer Phone is
I've had 3 of these phones and I can tell you that if the phone is unable to make regular contact with its system provider, then it will display what you are seeing on its screen. I got fed up with paying for the phone to make daily checks to see if you have any e-mails so asked BT to stop the phone from making contact with headquarters so to speak. This was duly done and it was great for about 6 months, but because the phone could no longer make contact with headquarters it simply died. They get you one way or another. If you want to pay for it to check for e-mails each day then it's the best phone around. I've tried loads since but am now going back to my Amstrad and will have to pay for its daily checks.
Hope this helps. Mike.
SOURCE: I have a,Amsrtad Emailer phone,problem,its
ive just solved my problem and have restored my e mailer to full use. but have now discovered that my e mailer does not like Talk Talk ,for when i plugged my e mailer into my next door neighbours B T phone line it restored everything. however ive got another problem , my e mailer keeps randomly dialling for e mails and although it doesnt connect, im still getting billed for them on average about 200 a month so ive unplugged it from the phone line any advice?. bob
I previously had one of these but the screen died. To 'start' the phone software the first call was to Amstrad to register the phone, which also set it up to call in on a regular basis using a premium rate number to collect emails etc. You could set it up to call a minimum of once a week in the evening so cutting down the charges. Support for these ended in 2011 http://www.amstrad.com/emailer_faq/index... I have obtained a new 'unregistered' phone and wondered if anyone knew how to by pass the registration process and 'kick start' the software.
